Oil Spray = Dead Car / Wont Start. Help Troubleshooting
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by John Pinkertons, Jan 27, 2020.
  1. John Pinkertons
    John Pinkertons New Member
    Phoenix
    I
    Hey all,
    Longtime lurker, first time poster. Usually there's a thread for every common issue, this one... not so much.
    I was topping off my oil for my 06 Prius before we drove from Phoenix to CA. Usually I burn 1.5 qts for every 5k miles. However, due to negligence, I forgot to put the oil cap back on.
    Needless to say, I drove to CA, saw some oil dripping when I arrived, and found the cap lying in the hood. I put it back on, topped off with oil, and drove back. Everything was fine, just super messy.
    After starting / stopping the car a few more times when we got back to AZ, the car will not start. The 12v is fine, lights come on, beeps come on, ECU Skid unit makes it's normal sound when you put your foot on the brake. But the button will just not work. I tried cleaning the engine compartment and replacing the spark plugs (recommended in another oil spill thread) to no avail.
    I'm thinking something electrical had to have happened? I checked the fuses for the starter / ignition, and they are good. Could the oil have leaked on the Alternator or Starter? Just have no idea what to do at this moment.
    Any ideas of what to check / try would be appreciated!
    EDIT : I have had some combo meter issues in this car, maybe 1/5 starts. I also have a weird quirk where the car will NOT start with the key in the ignition, but only with the key in a pocket / drawer / nearby etc.
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Welcome to PriusChat!!
    Are there any warning lights on the dash, or codes stored in the ECUs?
    Raytheeagle and jerrymildred like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    The Prius has no starter. It has no alternator.
    But, as @SFO mentioned, it might have trouble codes. If so, you should get some sort of light on the dash and you'll need a code reader that can read the Prius codes.
    One idea that just occurred to me was that the battery in your fob might be dead. But I wold think you'd be able to start the car with the fob in the slot if that was the case.
    You might have oil down in the sparkplug wells which would interfere with ignition. If so, that would throw a code and you'd get a light on your dash.
    SFO likes this.
  4. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Any codes?
  5. John Pinkertons
    Phoenix
    I
    No codes because it won’t go into accessory mode or start.
    the fob battery is fine b/c the lock and unlock buttons work and the car responds.
  6. bisco
    52,785
    how much oil did topping off take?
  7. John Pinkertons
    Phoenix
    I
    1.5 qts
  8. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Have you had a chance to check all of the fuses in the cabin and under the hood, pay attention to the AM2 and Dome fuses.
    Could be that your combo meter finally gave up the ghost, if not DIY then : Prius Speedometer Replacement
    jerrymildred likes this.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
  10. John Pinkertons
    Phoenix
    I
    I've only checked a few fuses under the hood relating to the ignition. I'll check them all tonight
  11. John Pinkertons
    Phoenix
    I
    Would a bad combo meter completely shut the car down? It used to run fine without it.
  12. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Yes, they will do that when given enough time. How long has you been driving with a failed combination meter?
    If you're into the DIY thing, you can purchase the capacitors online. Or you can get a lifetime warranty with Texas Hybrids.
    Check the fuses first, but that could be your issue.
    You can also try Steve at http://phoenixhybridbatteries.com/ - he may also have an option, and please tell him everyone at "PriusChat says Hello" :love:
  13. John Pinkertons
    Phoenix
    I
    I've been driving with a bad combo meter for maybe 1-2 years now. It was only 1/10 drives before, then moved to like 1/5. I'll check the fuses soon. I've had steve repair two of my Prius' batteries before :)
    SFO likes this.
  14. John Pinkertons
    Phoenix
    I
    Pulled every single fuse last night and tested with a meter... they're all good. Next best guess for everyone is a bad combo meter? All the lights, headlights, hazards, brake lights, etc work. Including on the dash : the turn signal lights, car with key logo
  15. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Is the combo meter blacked out?
  16. John Pinkertons
    Phoenix
    I
    I've had a bad combo meter for 1.5 years or so. Usually comes on 4/5 times. It's "blacked out" now b/c the car wont start or go into accessory mode at all.
    I just ordered a combo meter from Texas Hybrid Batteries. Fingers crossed it fixes it! If not, well I had to replace it anyway.
    Priuslover09 and jerrymildred like this.
  17. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Glad it worked out for you!
  18. jerrymildred
    11,517
    14,164
    Tampa, FL
    I hope that does the trick!
    Priuslover09 likes this.
