Ok I get 487 miles a tank
Discussion in 'Gen 3 Prius Main Forum' started by MansTer420, May 9, 2013.
  1. MansTer420
    MansTer420 Junior Member
    119
    this is my 2nd tank now and i am sure the miles that you get is vary highly depend on your driving environments.
    I do mostly 30 miles commute round trip and about 90% is on hwy.
    I turn on a/c all the time at 76 degree.
    when I fill up, the gas I put was 9.6 gallon.
    Am I getting descent mpg? or i am missing something big...?
    SAMSUNG-SGH-I317 ? 2
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    That's what the EPA rated the car for so I'd say 50mpg is good. Sure it could be better but there is nothing wrong with your car if that is what you are asking.
  3. snoctor
    snoctor Member
    126
    27
    Davis, CA
    50 isn't bad at all for your second tank. You have to learn how to take advantage of the feedback the car gives you. Accelerate slowly (and safely of course), anticipate stops, coast to slow down when safe, use the regenerative brakes as much as possible, brake early so that the 'charge' meter doesn't fill as you are stopping (a full meter indicates you are using friction brakes and thus losing energy). 76 is a great temp, highway miles are good. My commute is 80% highway and my most recent tank was 57.9 at similar temps. Keep at it and enjoy!
  4. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    "turrible" as Charles Barkley would say... because it's better than mine! lol..
  5. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    Answer: Your missing something big. You don't get something for nothing. You're getting 50MPG without adopting any new driving practices. If you want better than advertised mileage in your Gen 3 Prius, you'll need to turn off the A/C and adopt more economical driving practices. You can't have your gas and burn it too.
  6. MansTer420
    119
    Well addition to my driving habbits, I dont turn on ECO mode.
    Will turning on ECO helps?
  7. fuzzy1
    10,678
    It depends on driver style. It works for some of us, but not for others.
    Separate from driver style, ECO also alters the A/C somewhat, which may help slightly.
  8. bisco
    52,706
    with 90% of your driving being highway, speed is the main factor in mpg's. if you you can slow down, you'll do better, otherwise not. 50 seems pretty good to me for your commute.
  9. Chaloney
    Chaloney Junior Member
    Look for info in "driving with load" and "super highway mode". These seem most helpful on the highway for me
  10. SalixIncendium
    SalixIncendium Tree Hugging Environmentalist Wacko
    155
    68
    Dayton, OH
    Someone else can chime in if I'm wrong, but the regenerative brakes fill the battery during light to moderate braking while the friction (hydraulic) brakes during heavier braking result in lost energy. Having the battery meter fill while you're braking is a good thing, as this is stored energy. If it doesn't fill while you are braking, you are losing energy.
  11. Chaloney
    On the other hand, ANY braking means wasted energy (=wasted gas). Regenerative braking lessens the waste but if you can avoid the need to brake you waste even less energy. This requires looking much farther down the road than most people are used to. It also means leaving a much larger (and safer) gap between you and the car in from of you than most people do--they brake, you coast. It works quite naturally with the more gentle acceleration mentioned above.
    F8L likes this.
  12. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    Please help me understand this... 1) Braking is a waste of energy... 2) Regenerative braking lessens waste... 3) If you can avoid the need to brake, you waste even less energy...
    It is my understanding that as Prius drivers, we want to brake smoothly to capture what we can and send it back to our battery so the "wasted energy" can be used to improve our mileage! Why do people want to coast to a stop without using their brakes when a long slow brake with the regen display a little less than 3/4 sends the maximum amount of what WOULD be wasted energy to our battery? I see this all the time, and it makes NO sense to me!
  13. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    On large hills / mountains, the Prius battery will fill to max and the engine will then go in to engine brake mode
    where the engine will turn. There is really no way to get around this unless you have a plug in prius which has
    a larger batter capacity and will continue to charge on long downhill grades.
    On normally flat roads or rolling hills I use brakes very little, similar to driving a manual shift vehicle where
    you naturally time your stops and traffic lights.
  14. Eclipse1701d
    645
    224
    Three Touring
    First, thank you for responding to my question and not taking it the wrong way... I read your reply and understand why you would not regen if the battery is nearly at max, but why not regen on flat surfaces to capture energy for your battery? Or, do you keep a close eye on your State of Charge and regen when needed?
  15. retired4999
    2,652
    627
    Eau Claire, Wi.
    It uses more energy to get up to speed just to put on brakes to regen. It's more effective to not have to brake at all. I don't know how else to explain this. For best mileage drive like you have no brakes, impossble to do but gets you the best MPG.
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    It's quite simple.
    You have kinetic energy in the form of motion. By applying the brakes you steal this energy and convert it to another form Which suffers from conversion losses. You have now reduced the distance you can travel without applying more energy. Better to allow the original form of energy to carry your further without suffering conversion losses.
    In most cases you will eventually have to apply the brakes and you will recapture some energy anyway.
  17. Eclipse1701d
    645
    224
    Three Touring
    Thanks for the reply. I'm going to try this on the next tank and see what happens...
  18. CygnusX-1
    CygnusX-1 Junior Member
    Here is another way to put it using a hypothetical situation:
    There are 2 stop lights lets say 2 miles apart. I'm sitting behind stop light #1. When the light turns green, most people stomp on the gas and get up to 60 MPH between the stop lights. Then when they get to the next stop light (since it just turned yellow or red because traffic engineers just love to F with us this way :sneaky: ) they have to slam on the brakes to come to a stop to wait for the light to change back to green. Me since I don't like wasting gas, slowly accelerate to 30 MPH and go no faster. I of course am pissing off everyone else on the road behind me, but I don't care I'm getting the best gas millage this way. They can always fight to go around me in the other lane. Now what happens before I make it to the next light is that the light turns green. Everybody that was at that light jack-rabbits off from the stop and accelerates to 30 MPH before I get there. Therefore I don't have to hit the brakes on my car. I'm being the most efficient in my driving habits. It is not the braking that wastes the gas, it is the acceleration.
    It's Newton's First law of motion paraphrased sometimes as: A body in motion wants to stay in motion. It takes the least amount of energy to keep your car in motion at the same speed then having to speed up and slow down.
    MansTer420 likes this.
  19. MansTer420
    119
    yup. word
    i dont care what other people behind me thinking as long as I keep speed limit in city.
    I barely hit brakes on local except when I see red light.
    I use counter reactions when I hit gas and let go especially Prius keeps going with very small decrease of speed.
    Gliding. thats what it is
  20. Eclipse1701d
    645
    224
    Three Touring
    That makes total sense, but it wasn't what I was referring to... If I am traveling down the road at 50MPH and I see a red light ahead, I gently brake to capture as much energy as possible back to the battery. However, I have seen people post that instead of braking, they coast to a stop, as if they had no brakes. That is what I don't understand. Isn't thoughtfully applied braking to capture more energy better than just coasting to a stop?
