Ok I get 487 miles a tank
Discussion in 'Gen 3 Prius Main Forum' started by MansTer420, May 9, 2013.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    No.
    Pretend there is a stop sign a 1/2 mile ahead. You can either lift off the gas then reapply a little throttle to go into a glide (using no gasoline) now or you can continue applying throttle to maintain speed then start your braking at the 1/8th mile mark. You tell me which one is more efficient.
    A: Go into a glide and coast for 1/2 mile using no fuel then brake at the last moment and recapture a tiny amount of energy.
    B: Continue to use fuel until the 1/8th mile mark then recapture a little more energy which then undergoes conversion losses.
    Theory and practice will say that option A uses the least amount of fuel.
  2. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    Now I get your point. Thanks for the clarification. I do glide as much as possible, although learning to glide the Gen III was a little more difficult than the Gen II. I can be a little thick headed sometimes!
    52,821
    the more you brake, the more energy it costs you. sounds counter intuitive, but it simply means you saw the red light too late. if you see it soon enough, you coast as long as possible. no one is saying you never have to brake, you can't coast to a stop unless you're going uphill.:LOL:
    and you have to consider the people behind you. if you see the light a long way off, you can't coast down below the speed limit. you have to maintain it until a reasonable distance, then start coasting, then gently braking.
  4. snoctor
    snoctor Member
    126
    27
    Davis, CA
    Not the battery meter, the charge meter. You don't want the charge meter to fill while braking.
  5. spoolinq
    spoolinq Junior Member
    23
    2019 Prius Prime
    I've read this before a couple times on the forum but never understood why. So the goal is to not fill the charge meter? How does one accomplish this?
  6. Eclipse1701d
    645
    224
    Three Touring
    On the display, the meter that goes right when accelerating and the left when braking. If you break lightly and make the meter go no more the 3/4 to the left, you are sending the max amount of energy to your batteries, without engaging the friction brakes, so it's regenerative only.
  7. spoolinq
    23
    2019 Prius Prime
    So if I understand correctly, one should step on the brakes hard to avoid sending energy to the battery? Isn't this how Toyota designed it to be though? I thought the point was to be more efficient and store this energy when braking. Am I missing something?
  8. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Use the brakes sparingly. Jamming on the pedal is not going to be mpg friendly. Keep the gauge from being pegged all the way to the left when possible.
  9. Eclipse1701d
    645
    224
    Three Touring
    No, you should do just the opposite. Brake lightly to capture energy and not engage your brake pads.
    spoolinq likes this.
  10. spoolinq
    23
    2019 Prius Prime
    ah that makes more sense. Thanks for the clarification.
