OK strange noise
Discussion in 'Generation 1 Prius Discussion' started by ronlewis, Jul 23, 2023.
  1. ArCanSawDave
    ArCanSawDave Junior Member
    2003 Prius
    SE
    On my 2003 Prius I had a brake warning light and constant warning tone. I didn't have much history on the car, and wasn't very familiar with their general operation. On a hunch I placed a screwdriver handle on the booster pump assembly (on the passenger side of the firewall) and tapped the screwdriver handle with a hammer. To my delight, the booster pump kicked on and ran enough to build pressure and the brake warning light extinguished (along with the annoying warning tone). Unfortunately it was short lived, as the pump only operated that one last time. Since I knew the pump assembly was bad I went ahead and removed it and inspected it. I disassembled the section with the electric motor and found that the commutator bars were extremely worn (some copper commutator bars were totally missing). I searched around for parts online because I found a used booster assembly to be expensive and possibly no better than my booster. What I found is that you can buy a new armature assembly to replace the worn one. The mid 2000s 4runner and GX470 used a similar pump assembly for the ABS system, so I used an armature for that application. I've since put 23k miles on my car and have had no further issues with the braking system. So I'm basically saying if you can determine that the motor isn't running, you should probably look into replacing the motor/armature section of the brake booster pump. I'd imagine this is probably the source of most brake issues due to the age of these cars.
  2. Cameron L
    Cameron L New Member
    Nc
    My wife's 2012 Prius V seems to have a. Internal leak as you described. Is there a way to fix it myself?
  3. Tim Jones
    Tim Jones Senior Member
    1,760
    565
    SE Texas
    2011 Nissan LEAF
    $1500 for parts 5 to eight hours labor and Toyota Tech Stream
    #23 Tim Jones, Aug 16, 2024
  4. Tombukt2
    Tombukt2 Senior Member
    13,597
    2,457
    Durham NC
    Yes you cannot fix internal leaks inside of the brake actuator and the other part I mean there's no coverage for rebuilding so either Toyota doesn't give that information out and A1 cardone can't pick up the work or something I don't know how it works but no I don't think you're going to fix it but have at it see if you can take the parts out and see what you can do but I highly doubt it there are people saying that they can somebody will give you a link to somebody hybrid pit or somebody claims they can rebuild them
