Ok to leave car on while pumping gas?
Discussion in 'Gen 2 Prius Main Forum' started by jgod12, Apr 15, 2009.
  1. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    In EV mode you still have 200V flowing from HV battery to inverter, through the DC/DC converter down to 12V, powering all the electronics. When off, only a small amount of power at 12V is running battery back-up for the various configuration settings. It's a lot safer with the car completely off.
    Chances of a spark are probably very minor, but it's still possible.
  2. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    I think we would have gotten quite a few reports of damage by now if this was true. Might want to give the Toyota engineers credit for thinking ahead and preventing damage if this is detected. Just lighting the Engine Check light while driving with a loose gas cap is proven by others and myself (not intentionally).
    I can usually count on the wider population to try every combination of dumb things. It's very clear that running the NHW11 out of gas and then the battery does do damage. Fortunately, I have not done that dumb experiment or try to find what happens when refueling with the car on.
  3. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    Well, the chances of something bad happening is probably well below 1%. I've probably put gas in with the car in READY a couple hundred times with no ill effect. I don't do it for fuel economy.... I just don't want to reboot my carputer.
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Yep, been there done that.
    Strictly for fun, I've built up enormous static charge on a carpet, just to sneak up and touch a booby
    I had you thinking about that, didn't I?
  5. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    If you're that worried about cycling the computer, leave the car at home... Argh... You're going to start the car many many thousands of times for other reasons. You're going to fill the car with gas a few hundred times. Turn it off when you do. Do you leave it on when you run into the store for some milk, too?
  6. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    There are three things to consider for risk management:
    What's the worst thing that could happen? (car bursts into flames)
    How often does it happen? (very rare)
    What's the cost of mitigation? (pressing one button)
    A typical analysis looks at how often the button would have to be pushed so that the total cost of the button presses exceeds the cost of destroying a car (plus possibly a gas station, plus possibly killing someone). My guess is that this number is really, really large.
  7. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Actually the worst thing is for someone to get hurt or worse.
    Here are different conditions for refilling a car
    1) Car turned off (ensuring the parking pawl is engaged if a Prius)
    2) Car on and In Park
    3) Car on and In Neutral, Parking Brake engaged
    4) Car on and In Neutral
    5) Car on, not in neutral/park, and Foot on Brake
    6) Car on, not in neutral/park, and not moving
    I know which is the right answer.
  8. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    That's not how it works.
  9. Presto
    1,326
    24
    Vancouver, BC
    It's a risk I'm willing to take. It's probably less risky than driving around regularly, with the possibilty of some idiot driver crashing into your car.
  10. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    Consider the number of complete starts and shut downs you do between fill ups and see if that makes sense to save one such cycle.;) Not considering the other real factors, especially the fill up reconfiguration cycle.
  11. Mike Dimmick
    963
    249
    Reading, UK
    It's your responsibility not to risk everyone else's lives by leaving open the possibility of a spark.
    SWITCH IT OFF.
  12. patsparks
    10,664
    567
    Adelaide South Australia
    Wouldn't the child be in a child restraint in the back seat?
  13. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    The kid's dad is an NBA player - long arms can reach all the way up to the dash. :rolleyes:
    Tom
  14. patsparks
    10,664
    567
    Those are some full on long arms!!
  15. zonie911
    zonie911 Member
    585
    Nashville, Tennessee
    I, too, am not going to address the legality issue with leaving your car running.
    I'm addressing the safety issue! Tell me where you buy gas and I surely won't go there. The reason it's illegal is that safety is such a major concern that we, obviously, cannot be held responsible for making good decisions at certain times, like when we are on a cell phone and get out of the car and start pumping gas!!!!!!!!Here we have just multiplied our risk of an explosion by about !00% with the car running too.
    The reason that it's illegal is that after an explosion someone can't say "I didn't know I shouldn't do that", hence the laws ----- plus you are held responsible, morally and legally.
    And also the long run damage reasons that others have mentioned,
    hence, the reasons that your company has been buying a lot of new cars over the years, may be the fact that you, along with fellow employees are affecting the life of the vehicle.
    Think about it.
  16. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I believe the Mythbusters already debunked the "cell phone igniting the gas station" scenario. NASCAR & Formula I drivers refuel while the engine runs. How many of those have you seen explode?
    The ICE in the Prius under any NE weather conditions will not start or run in the time it takes to pump a tank of gas as long as the climate control is off & it took at least 5 minutes to drive to the gas station. I believe that NOT going through the restart cycle has improved my FE.
    It's real easy to say it's illegal. Do you have a reference? If the sign says "TURN ENGINE OFF" then IMO I'm in compliance because my ICE is off and the silence is proof.
  17. KTPhil
    KTPhil Active Member
    1,379
    See if those arguments work in court where the insurance company declines your coverage, and the deceased survivors are looking to take your house away.
    According to information compiled by the Petroleum Equipment Institute, more than 175 fires occurred, between 1992 and 2003, when fuel containers were being filled or vehicles, machinery, or equipment were being fueled.
    California Code of Regulations (CCR) Title 8, Section 3319:
    "No internal combustion engine shall be refilled with a flammable liquid while the engine is running."
    running
    In READY mode your engine can start at any time to heat the catalyst, run the defroster, or recharge the battery.
    Gamble with your own life if you want, but you have no right to gamble with others'.
  18. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    Yes, I see a good number of news videos where cars burst into flames while refueling, but due to static electricity:eek: Haven't seen one to engine being on while refueling, but, there is a first time for everything;):D
    Even airplanes go up in smoke while being refueled, engines off. Not sure how many such fires when they are hot refueled. I have done a good number of those myself in my time; that is not illegal.
  19. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    Hey, but they are professionals, no ;):D
  20. patsparks
    10,664
    567
    I drive down the road and walk on the street every day and I haven't been killed yet, but every year about 100 people die on the road in South Australia. Just because it hasn't happened to you doesn't mean you aren't taking a risk.
    But I live on the other side of the planet and I don't know you, so feel free to continue to add unnecessary risk to your life, some people need that.
    Please try to find deserted fuel stations when you fill up and fill up as far as you can from the poor console operator.
    Good luck.
