Okay for car to sit?
Discussion in 'Gen 3 Prius Main Forum' started by nudriver, Sep 20, 2025.
  1. nudriver
    nudriver Member
    283
    32
    los angeles
    I remember in the old days you'd have to start a car's engine or drive it around a bit if it was sitting for long periods of time, say, when you were on a trip and left it at home. Is this true with the Prius? Will the battery stop working if I'm letting it sit on the driveway for weeks without using it?
  2. ASRDogman
    ASRDogman Senior Member
    8,069
    4,092
    The 12v battery WILL eventually be drained. Same for any car. But the Prius 12v is not
    a large capacity battery, it doesn't need to be because it doesn't turn the engine over for it to start.
    The hybrid battery can go several months before it too will eventually drain.
    If you must leave it, perhaps a 12v solar charge could be installed to keep it charged up.
  3. Mendel Leisk
    42,369
    Our usage is “sporadic”, the car idle between usage, sometimes just a few days, occasionally up to two weeks. It’s garaged and the 12 volt battery on a smart charger. When we do use it’s usually a good drive, say at least 10 kms, sometimes 50~100, getting the engine fully warmed.
    the current 12 volt battery was installed in September of 2015, and still tests well above specd CCA.
    the hybrid battery seems to behave as always. Owners manual mentions hybrid battery and downtimes, says (paraphrasing) as long as it’s not months of downtime it can handle it.
    #3 Mendel Leisk, Sep 20, 2025
  4. PriusII&C
    PriusII&C Active Member
    432
    147
    San Jose, California
    I parked my Prius and Prius-C in garage for 1.5 and 2 years respectively. I checked the traction battery SOC levels every 3 to 6 months. The SOC barely moved, staying at 5 - 6 bars.
  5. bisco
    52,889
    a 13 year old hybrid battery is in danger of going bad if it sits too long. you can't predict it.
  6. bisco
    52,889
    be careful of vermin as well. they move in when you move out, and can devastate the wiring et al
  7. nudriver
    nudriver Member
    283
    32
    los angeles
    So what do I do?
  8. nudriver
    nudriver Member
    283
    32
    los angeles
    Huh?
  9. nudriver
    nudriver Member
    283
    32
    los angeles
    Huh?
  10. nudriver
    nudriver Member
    283
    32
    los angeles
    Huh?
  11. nudriver
    nudriver Member
    283
    32
    los angeles
    Huh?
  12. ASRDogman
    8,069
    4,092
    See Post #1...
  13. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    Didn't hurt my car yet to be driven only every 4/5 weeks for like 30 miles /
    Just put some battery tender/minder on your 12v battery /
  14. nudriver
    nudriver Member
    283
    32
    los angeles
    I'm not getting this whole 12v battery thing. Do you or don't you have to drive it every couple of weeks so the battery doesn't die?
  15. ASRDogman
    8,069
    4,092
    The 22v battery is keeping power to the computers, to keep the settings, among other things.
    If it dies, you lose all the setting. And the car won't start, or go to the READY mode.
    A weak 12v battery will trigger all kinds of codes and warnings. Computers don't like lower voltage
    than they need.
    So you NEED to keep it charged up. It's never good for ANY car to sit idle for long periods of time.
    The 12v battery gets weak and eventually dies. Seals lose lubrication and harden, rust starts.
    Rats/squirrels and bugs make nests and eat wires.
    Keeping a battery maintainer on it will save you a lot of issues. "IF" you have someone that can drive
    it for you at least once a week, for 30 minutes or so, it will be good for the car.
  16. bisco
    52,889
    if it were mine, i would ask someone to drive it for 15 or 20 minutes every couple weeks, and disconnect the 12v negative, or put a maintainer on it
  17. nudriver
    nudriver Member
    283
    32
    los angeles
    Okay, that all makes much more sense. Is it expensive to tack on that gadget to keep the battery going?
  18. bisco
    52,889
    it just clips onto the charge point in the fuse box under the hood, and you plug it in
  19. nudriver
    nudriver Member
    283
    32
    los angeles
    How much?
  20. bisco
    52,889
    30 bucks genius1
