Okay. Who HASN'T had a 12V battery issue with their 2023-24 Prime?
Discussion in 'Gen 5 Prius Main Forum' started by REBobBecker, Mar 30, 2024.
  1. Gokhan
    Gokhan Senior Member
    6,216
    2,465
    Paramount CA
    Much more expensive BMWs, Audis, Mercedeses, etc. are a lot worse in 12-V-battery longevity than Gen 4 and Gen 5 Priuses and Prius Primes.
    Again, there is no problem with the Prius battery 99% of the time—you only need to observe certain precautions. The main two things are (1) to use a battery maintainer at least once if the car has any history of not being driven for more than a week in order to bring the battery SOC back to a level maintainable by the car’s native charging system and reduce the sulfation and (2) not to have a persistent habit of leaving the car plugged in for longer than overnight.
  2. Gokhan
    6,216
    2,465
    Paramount CA
    Exactly, you must use a battery maintainer after everytime the car has been sitting for longer than one week, as the car’s native charging system is not capable of fully charging or healing batteries with a low SOC.
  3. Gokhan
    6,216
    2,465
    Paramount CA
    My guess is that the 12-V-system operation during solar charging is very similar to that during AC charging.
    This means that the DC–DC converter is on (possibly at a low voltage such as 12.92 V, albeit reportedly higher in Gen 5) during traction-battery charging and turns off when the traction-battery reaches 100% SOC. So, once the traction-battery is at 100% SOC, the parasitic drain on the 12-V battery will increase due to the charging computer still being on but the DC–DC converter being off.
    This brings an interesting question: Do the vehicles with a solar roof have a higher parasitic drain on the 12-V battery, as they must constantly monitor the status of the solar roof?
  4. AndersOne
    AndersOne Active Member
    335
    195
    Europe
    2023 Prius Prime
    So to answer the inital question - I recently came back from a 3 week vacation. For the whole time the car was parked outside with temperatures slightly below freezing at night. Fortunately no battery issues.
    The car has solar panel and there was sun but probably not enough (~25W when I checked today) to go over the threshold (50W?) so no solar charging during my absence (and generally not in winter months).
    The traction battery was left at ~40% SOC and did not change - the tires lost a little bit pressure though
    #224 AndersOne, Jan 16, 2025
  5. RandyPete
    RandyPete Active Member
    403
    167
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Just wondering how you determined that the battery was left at ~40% SOC ?
  6. Gokhan
    6,216
    2,465
    Paramount CA
    No battery issues? You don't know that.
    Three weeks is a long time. There is a 2.3% parasitic drain everyday in my Gen 4 Prime. Chances are that your starting SOC was around 80%. So, after three weeks, your SOC would be about 30%, which means your battery has had serious sulfation and capacity degradation. If you couldn't connect a battery maintainer because you didn't have a garage, you should have disconnected your battery before you went on vacation.
    Your car's charging system will never be able to bring the SOC to a healthy level now. You should hook up a battery maintainer like Noco Genius for a couple of days to bring the SOC to 100% and remove some of the sulfation. It is unlikely that your battery will survive the same thing with the capacity degradation caused, but again, use a battery maintainer to eliminate some of the sulfation and bring the SOC back to 100%. Your SOC is probably stuck around 60% at the moment.
  7. Gokhan
    6,216
    2,465
    Paramount CA
    That is the traction battery.
    AndersOne likes this.
  8. AndersOne
    335
    195
    Europe
    2023 Prius Prime
    You might have a point, I will not doubt your knowledge... but then you kinda miss the point. People have long vacations here and none really cares about battery maintainers or even disconnecting the battery. Especially not the typical Toyota customers. You dont buy one of the most reliable (and boring brands) brands (which is kinda expensive these days) with a 15 year warranty to deal with this kind of stuff.
    If the battery stops working after my next big break I will just call Toyota so they can come over to fix it.In worst case nothing too bad happens besides the battery having to be replaced earlier - which is an insignificant price to pay compared to everything else this car costs. No point in overthinking it now though.
    Gokhan and Trollbait like this.
  9. Gokhan
    6,216
    2,465
    Paramount CA
    Not just knowledge—but also experience with such long-vacation situations with my Gen 4 PHEV. The first few times the battery was still alive, but it eventually completely drained. I then investigated what was going on.
    I don’t know if the solar roof charges the 12-V battery when parked. If it does, perhaps it helped.
    You say that, but you will find out that it is not fun to come back to a dead battery from your vacation to say the least—especially if you need the car right away. It is not just about money.
    My recommendations stay: Use a battery maintainer now to recondition and fully recharge the battery. In the future, you probably want to disconnect it for long vacations if you can’t garage and hook a battery maintainer to it. You can also leave the key with a friend and let them turn the car on to the ready mode for half hour a couple of times a week.
    By the way, even if you do not have a garage, you can simply remove the battery and take it to your apartment and hook up a battery maintainer in there.
    Noco Genius 2-ampere on Amazon DE
    #229 Gokhan, Jan 17, 2025
  10. schja01
    schja01 Senior Member
    1,834
    1,221
    Chicagoland
    2024 Prius
    Limited AWD-e
    At what 12v battery voltage does sulfation begin or at least get to a level of concern?
    I have a Bluetooth monitor on my 12v. I have a 2023 Prius (not Prime) and this monitor says the battery is low when it reaches 12.39v. The car is brand new and only takes about 2 days to go from 100% to 64% which, as I mentioned above, the BT monitor calssifies as "low".
    Gokhan likes this.
  11. Gokhan
    6,216
    2,465
    Paramount CA
    Sulfation can start at any SOC below 100%, but it gets worse and worse with decreasing SOC. I would say you should start worrying if the SOC falls to the light-green zone.
    If 12.39 V for your flooded cell is at least after 16 hours of rest, you are looking at about 78%, which is typical with the Gen 4/Gen 5 BMS. My AGM cell is falling down to as little as 12.57 V after 16 hours, which is 74%.
    I am thinking of hooking up my Noco Genius to bring the SOC to 100+% to reduce/prevent sulfation issues, as 74% is a little too uncomfortable for me, but then, again, that's what the Gen 4/Gen 5 BMS does.
  12. schja01
    1,834
    1,221
    Chicagoland
    2024 Prius
    Limited AWD-e
    I'll put my battery tender on the 12v and when it completes it's charge cycle I'll set a 16 hr alarm and see what things look like.
    Thanks for your expertise,
    J
    Gokhan likes this.
  13. MyPriusMarvin
    MyPriusMarvin Member
    82
    87
    Washington, D.C. area
    I haven’t had a single problem with my battery or with anything really, except when I drove over a nail and needed to replace a tire.
    Gokhan likes this.
  14. Gokhan
    6,216
    2,465
    Paramount CA
    That is exactly the point—you don't have a problem until you have one. ;)
  15. schja01
    1,834
    1,221
    Chicagoland
    2024 Prius
    Limited AWD-e
    How often and how long do you drive the car?
    My issue is I don't drive the car enough for it to keep the 12V charged sufficiently.
    If I drove it daily for 10->20 minutes I too would have no issues but I don't. I'm retired so, homestly, an Uber would probably be more cost effective but I don't want to totally give up my independence.
    RandyPete and Gokhan like this.
  16. Gokhan
    6,216
    2,465
    Paramount CA
    In that case, you should hook up a battery maintainer once a week, as you lose about 2.3% SOC everyday. Noco Genius can be left hooked up indefinitely. The 1-ampere version is cheap.
  17. MyPriusMarvin
    82
    87
    But I don’t do anything special though. This is a multi-page thread about batteries with all sorts of advice and instruction to limit potential problems. I just don’t do anything special with my car and I haven’t had any issues with my battery, or with anything else.
    AndersOne and Gokhan like this.
  18. reservoirblue
    reservoirblue Member
    95
    76
    Woodacre, CA
    2024 Prius Prime
    SE
    Same here, but I imagine the folks who do have problems appreciate both the arcane and the practical info in this thread.
    MyPriusMarvin, Gokhan and schja01 like this.
  19. Paul Gregory
    Paul Gregory Senior Member
    2,154
    565
    Alberta
    2024 Prius Prime
    XSE
    Shortly after I got my 2024 Prime, about a year ago, I had problems with my 12V battery going dead. My dealer said the battery passed the test, and a second dealer replaced it, but the problem persisted. One incident I remember as the worst; I parked for 2 hours to go on a hike, and I returned to a dead battery. By "dead" I mean the voltage fell below the threshold where I got a message saying the battery level was too low to start. I measured parasitic drain to be highly variable, probably due to over the air updates.
    I installed a battery maintainer, and an auxiliary battery, which quadrupled my battery capacity. I haven't needed a boost since.
  20. Bill Norton
    Bill Norton Senior Member
    2,154
    734
    MONW, Ks.
    Nothing like installing lots of parts to fix your new car. :unsure:
    Why not have toyota fix this problem?
    Gokhan likes this.
