Old hybrid battery modules
Discussion in 'Gen 3 Prius Main Forum' started by rjh427, Dec 13, 2022.
  1. rjh427
    rjh427 Junior Member
    39
    Earth
    A seller near me is offering up to 38 Gen3 hybrid battery modules. These are loose, not in the carrier/holder. Seller claims they're still holding 6 volts after a year of sitting around.
    What are the odds that they are good modules, if they've really sat that long and are still holding that much charge?
    52,855
  3. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    RE: used hybrid battery modules.
    Without extensive testing, there is no way to predict.
    I have had an extensive conversation with the Service Manager of my Toyota dealership, I am left very disappointed that the vehicle designers failed to include any form of internal diagnosis capability. With laptop batteries, you can always use a diagnostic to tell you the 'health' of the battery. It should not be any different when discussing an automobile.
  4. PriusII&C
    PriusII&C Active Member
    432
    147
    San Jose, California
    How to judge a battery's condition based on its voltage change over time?
    My Price-C has been parked in the garage for the last 2 and a-half years. I check and charge its traction battery once a few months. Never see SOC bar change. Last time I left it at 6 bars. Today it is still at 6 bars after 4+ months.
    The battery is overe 10 years old and has 110k miles.
  5. rjh427
    39
    Earth
    From what I understand, the "life" is based on charge-discharge cycles, the 10-years thing is an approximation based on time and operating hours, which are themselves approximated from mileage.
    Given all of that, it makes sense that an older battery in a seldom-used, low-mileage vehicle still has some life in it after +10 years. I welcome correction from any gurus who know better than me.
  6. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
    How much for the modules? Also where on earth are the modules currently located or where were they previously located. Modules from southern heat zones have a degraded shortened life span.
    I've had modules at 6 volts that were basically junk, 7.2 volts after sitting for a year is even better. Mind you I had a pack that had been sitting for a year, 3 even at 7 volts after load testing turned out to be unusable. Can't say definitively unless you load test them, so take a load tester with you.
    #6 alftoy, Dec 13, 2022
  7. strawbrad
    953
    1,007
    The short answer is zero.
    Modules that self discharge below 7.2 volts are non recoverable junk.
    gdanner likes this.
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Do you have a code I can use and will you pr vide me 24/7 support if I use it on your website?
    #8 Grit, Dec 13, 2022
  9. rjh427
    39
    Earth
    So with that low of a voltage they are probably paperweights that should be taken to Batteries Plus, got it.
    Seller was wanting $5 each, but I think it was a scam. I asked what year vehicle they came out of, no answer. Instead, seller claimed they were traveling to Wisconsin and they asked me to send "honest" money. I passed that up without looking back. Tampa Bay area.
