Old spark plug still clean?!
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Bicycles, Jul 2, 2020.
  1. Bicycles
    Bicycles New Member
    Los Angeles
    Hi all, while replacing my spark plugs I noticed one of the old ones came out completely clean, as if it had never been used. I'm guessing this is a sign that something is going on. I am getting the P030X codes intermittently as well. I'm trying to figure out my next move, any suggestions are greatly appreciated!
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,031
    6,919
    Texas Hill Country
    Either someone replaced it recently or its not firing. Not firing will give you the code for that cylinder and the engine will run really bad. Could be the coil, injector or other issues. You need to put in your plugs, clear codes and see what comes up. Verify against the cylinder number.
    prius firing order.png .
  3. Bicycles
    Bicycles New Member
    Los Angeles
    Thank you for that diagram! I simply disconnected the coil from cylinder 1 and cleaned out the contacts with compressed air. Plugged it back in and started the engine... no knocking, seemed smooth. Cleared the code (only P0301 was showing this time) and drove up and down the street at a fast pace. I'll post an update after the weekend.
  4. Mendel Leisk
    42,293
    How many miles on it, and what cylinder did the clean spark plug come from?
  5. Bicycles
    Bicycles New Member
    Los Angeles
    just about 160k, I didn't take note of which cylinder it came from (huge oversight on my part, I know)
  6. Tim Jones
    Tim Jones Senior Member
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    Have you checked your antifreeze level?
    #6 Tim Jones, Jul 3, 2020
  7. Bicycles
    Bicycles New Member
    Los Angeles
    I've had to top off my coolant a couple of times this year.
  8. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    I hope this isn't the beginning of the dreaded Blown Head Gasket......
  9. Bicycles
    Bicycles New Member
    Los Angeles
    Is the misfiring cylinder a symptom of that?
  10. Bicycles
    Bicycles New Member
    Los Angeles
    would the spark plug issue be related? That timeline wouldn't make sense... I bought the car at 54k with the original plugs. The fact that one of the plugs had ZERO wear would mean it hadn't been working since the start, right? And the engine knocking didn't start until around 150k. Thoughts / theories? Thanks
  11. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    No way the plug has not been working..... the car would run terrible on three cylinders including CEL's....
  12. Mendel Leisk
    42,293
    The head gasket failures are often cylinder one or two. That end also tends to have EGR passages clog up fastest.
    Do boroscope inspection of cylinders, looking for exceptionally clean cylinder and/or coolant.
    mjoo and Tim Jones like this.
  13. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    You need to get the CEL codes.
    Where's Grit when you need him....?
  14. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    Could be..... : (
  15. Bicycles
    Bicycles New Member
    Los Angeles
    Would an EGR unclogging do any good at this point, or should I start looking for a new engine (I've heard that's more effective than fixing old head gaskets, correct?)?
    Thank you both
  16. Bicycles
    Bicycles New Member
    Los Angeles
    I'm getting P0301 and P0300, I got P0302 and P0304 a few months ago but they haven't been back.
  17. Mendel Leisk
    42,293
    EGR cleaning would keep combustion chamber temps lower, which in turn stresses head gasket less. Still, head gasket assessment is first priority now, my take.
    Tim Jones likes this.
  18. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    Does the car use any oil?
  19. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    You should never have to top off engine coolant. It should stay right where it is for months and months possibly years. If your losing coolant it is going somewhere. Head gasket.
    My g2 engine coolant level has not needed any topping for the last 5 years. it should not move at the rad cap.
  20. Bicycles
    Bicycles New Member
    Los Angeles
    oil seems to be staying at a normal level.
