On models with no spare tire, what are folks doing?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by dpbsmith4, Apr 21, 2016.
Tags:
  1. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    AAA Plus membership with 100 mile towing including for me.
    jtg61 likes this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    What happens for the next 600 miles? And how do you contact them when there is no CellPhone service?
    ETP and Frederickdawg like this.
  3. Frederickdawg
    Frederickdawg Active Member
    596
    335
    Florida Unfortunately
    Plus the hassle of a probable grease monkey bottom out your front end while towing jt
    LG-H901 ?
    alanclarkeau likes this.
    51,935
    smoke signals.
  5. Frederickdawg
    596
    335
    Ok , so I removed the Prius 4 rear bits and bobs. I'm left with a rather shallow looking area to accommodate a space saver wheel 135/80/16 Toyota spare ?
    Looks like the parts needed for the project and will be the bolt that screws down the spare, new polystyrene foam parts and I'm thinking also the rear black plastic trim that sits around the hatch latch horizontally?
    Pics taken, since it would rude not to share. uploadfromtaptalk1462413567715.jpg uploadfromtaptalk1462413572422.jpg uploadfromtaptalk1462413576590.jpg uploadfromtaptalk1462413580865.jpg uploadfromtaptalk1462413584590.jpg
    LG-H901 ?
    Dragon Rider and bisco like this.
  6. bisco
    51,935
    look around, i think someone has done this for you.
    ETP likes this.
  7. dalea
    dalea Junior Member
    Washington, USA
    Four Touring
    ETP, bisco and Frederickdawg like this.
  8. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    number 11 on your spread sheet.
    Also someone deleted/moved my GEN 2 2009 Touring spare tire thread. Really needed that info today before I trade.
    Should I keep my 2009 Gen 2 Touring spare for my new 2016 Four Touring? Or forget about it. Sucker is getting really old like me.
  9. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    I suddenly realized that the size (circumference) of the donut spare is not that critical if you use it on the rear wheels. If the sizes of the two front tires are different, the car's "differential" will be constantly working as though the car is in a turn, which might cause wear if the car is driven far. On the rear, that is not a problem.
    Putting a donut spare on the front worries me because its contact patch is probably much smaller than that of the regular tire. So if you slam on the brakes in an emergency, it would break traction more readily than the regular tire on the other side, sending you into a spin away from the donut spare side. Which could be inconvenient in an emergency. If I had a front flat, I would always swap tires around so that the donut would be at the rear.
    For the same reason, on the road I stay away from cars that have a donut spare on the front. Actually a donut spare anywhere on the car, because on the highway they are usually running much faster than the 50mph the tires are rated for.
    I was surprised to read in the Owners Manual that Toyota recommends avoiding putting donuts on the front only when driving on snow or ice. But the manual has a long list of things that may not work properly when a donut spare is attached (p.685), beginning with "ABS and Brake Assist". I think they should have added "Brakes" to that.
    ETP likes this.
  10. ETP
    2,802
    1,170
    Auburdale FL
    Yep/OBE/ that would require two tire changes. I am not going there. I will just die by the side of the road. Easier solution.
  11. Frederickdawg
    596
    335
    A donut spare is only used to get me to the tire store. Unlike some of the hill Billie's around me .
    LG-H901 ?
  12. ETP
    2,802
    1,170
    Auburdale FL
    Bet 4 donuts would get great mpg
  13. bisco
    51,935
    not if you eat them, they'll weigh you down.
    4GP2ECOBP, PriusC_Commuter and ETP like this.
  14. ETP
    2,802
    1,170
    Auburdale FL
    hot Krispy Kreme falling off the conveyor belt:)
    3 dozen please
  15. bisco
    51,935
    and more coffee!:coffee:
    ETP likes this.
  16. Mendel Leisk
    41,457
    I wouldn't worry about putting a compact spare on the front, it gets done with no ill effects. Does 4th generation manual specifically caution against against this? I scoured 3rd gen manual, found nothing.
    Our (procrastinating) daughter drive her 4wd Pilot for MONTHS with temp spare on front. Drove to your country. Twice.
    You can imagine my opinion. Even shot her some $'s, but hey: busy, lol. Finally got it done.
    bisco and ETP like this.
  17. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    As long as you don't need to brake really hard, especially if it is raining, you should be just fine. If you aren't planning on having an accident you won't need any of that silly safety stuff like ABS, Brake assist, VSC TRAC, EPS, PCS, LDA, TPMS, etc. that Toyota says won't work with the compact spare mounted.
    As I said, on ice and snow, yes it does.
    Glad she made it! The laws of physics don't apply to the young, or at least they think so. The reason the compact spare says "TEMPORARY USE ONLY" on the side is that it's for temporary use only.
    Personally, I like it here and would prefer to stay a while longer.
    Come to think of it, visiting this country was pretty dangerous too. Maybe the compact spare was the least of her worries.
    #77 JohnF, May 6, 2016
  18. zmre2b
    zmre2b Junior Member
    70
    US
    This is the way to go.
  19. MichelleStone
    MichelleStone Senior Member
    549
    818
    Mariposa, CA
    I'd like to pop for a trim level 4 but I too am worried about the lack of a spare. I happen to live in an area that does not have cell service. As a result, I don't have a cell phone. I check with the providers every year... still no service where I live. Odd, since I live next to one of the largest National Parks (Yosemite). I'm pretty meticulous when it comes to taking care of my tires. But in 2009, I did get a flat on my current car. I picked up a half inch bolt. That little donut spare did come in handy. I'll probably ask the dealer if they can add a spare as part of the deal. I'd be willing to pay for it.
    ETP and bisco like this.
  20. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    ...odd isn't it - re no cell phones? We were just up there a month or so back...nice territory!
    If you're following the recent threads, you can convert 4 for spare via a couple options, or just carry one.
    ETP likes this.
