On models with no spare tire, what are folks doing?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by dpbsmith4, Apr 21, 2016.
Tags:
  1. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    :( :( :( $27,500 for a Prius, and they give me a $2 Jack?! :ROFLMAO:
  2. Coast Cruiser
    2,267
    2,571
    I still don't understand why Toyota didn't put a compact donut spare in ALL Prius models. When I took mine out to look in there, I couldn't believe how light it is!
    So I don't believe their baloney that NOT having a spare tire improves gas mileage. Horsefeathers!
    What's funny is, the folks that don't have a spare, they load up that space with all kinds of stuff that probably weighs MORE than the donut tire! :LOL::ROFLMAO:
  3. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    Yep, cheaper than towing all these cars for 3 years. Lot of wasted space under that mat and my wife hates the lower back floor board.
    Coast Cruiser likes this.
  4. Topp Cat
    Topp Cat Member
    71
    66
    It's looks like today's new car are w/o spares cost cutting? I carry a bottle of fix a flat, plug kit and a compressor! Not offen you get a flat! Depend on your luck! I recall my wife jeep one stretch she would get 3 flats a month! I learn to get really good using tire rope plugs!
    ETP likes this.
  5. ETP
    2,802
    1,170
    Auburdale FL
    Reminds me, I forgot to buy a deluxe HD plug kit.
  6. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    I got a Corolla donut from a car headed for auction at my one job. Had it ever since. It was like new and I couldn't beat the price. I had to put my jack back in though (under the drivers seat). I had originally removed it since there was no spare. I had kept the tire kit in the car though.
    iPhone ?
  7. Mendel Leisk
    41,502
    Get a lightweight pair of wheel chocks, use them on the tire diagonally across from the flat. It actually shows that you should use wheel chocks in the Owner's Manual, but they're not supplied.
    The Toyota jack is poor for sure. What's frustrating with it is just the torque rod connection style, where the rod hooks onto the jack. It's a cast, single eye, and the rod hook dances around with every revolution. Our Hondas came with a similar construction scissor jack, but instead of the cast piece there was a U-shape bent plate with two holes, about 3/4" appart, that the rod hooks through. Immensely more stable as you crank it.
    Another good accessory to bring along: a small square of plywood, to act as a sub-base for the jack, on gravel or dirt.
    Merkey, ETP and bisco like this.
  8. Frederickdawg
    Frederickdawg Active Member
    596
    335
    Florida Unfortunately
    Was a good film that.
    SM-G928T ?
    trentofdestiny and ETP like this.
  9. Mendel Leisk
    41,502
    I got this one:
    Kt-340 - BlackJack Tire Repair
    You can get a bubble pack kit at Walmart for $10, but hey you only live once. It does come with a ton of plugs, in 2 diameters, spare needle, nice case.
    ETP likes this.
  10. ETP
    2,802
    1,170
    Auburdale FL
    Watched a person with a flat tire break 3 plug kit tools off in the tire.
  11. Mendel Leisk
    41,502
    You could end up running your hand into the broken-off needle. :eek:
    ETP likes this.
  12. ETP
    2,802
    1,170
    Auburdale FL
  13. Mendel Leisk
    41,502
  14. MichelleStone
    MichelleStone Senior Member
    549
    818
    Mariposa, CA
    How bout carrying a tire iron and an inner tube? That's a lot smaller than a spare. And it would really satisfy that need that some have to "do it yourself." ;) I suppose I'm going with "I hope I never get a flat outside of cell phone range."
  15. bisco
    51,986
    now that, i would like to see.:p
  16. MichelleStone
    549
    818
    Mariposa, CA
    When I was 8 or 9, my father insisted that I learn how to fix a flat with tire irons and inner tubes (a hammer came in handy). That's when I learned how to properly use curse words.
    trentofdestiny and bisco like this.
  17. bisco
    51,986
    i had trouble changing my bicycle tube.:oops:
    Mendel Leisk and ETP like this.
  18. fuzzy1
    10,475
    Taken one at a time, 10 pounds here, 5 pounds there, these design and marketing decisions don't make enough MPG difference for any single customer to notice. But the designers accumulate a hundred of these decisions, which really do add up. And when they are tasked by the marketing department with meeting a specific EPA label rating, even rounding errors must be tracked.
    ETP likes this.
  19. ETP
    2,802
    1,170
    Auburdale FL
    Probably would die before I attempted to put a tube in a low profile tire. Man that's a lot of work:ROFLMAO:
  20. Mendel Leisk
    41,502
    I don't think an inner tube has a chance, just the TPMS for starters, and no one but no one is doing bead breaking by the side of the road. Kind assume this was in jest? Plug repair yes. Or spare, my preferred.
    ETP likes this.
