On the Psychology of Personal PV and EV ownership
Discussion in 'Environmental Discussion' started by SageBrush, Aug 9, 2013.
  1. SageBrush
    SageBrush Senior Member
    11,627
    2,531
    Southwest Colorado
    This is a personal reflection.
    Today I funded (loaned) the money for installation of ~ 8 kW of PV, expected to produce about 15,000 kWh a year. I live in NM, while the installations will be in NJ and CA. For anyone interested, the loan is through a 'crowd funded' venture called Mosaic.
    I hope it works out, that the energy is produced for decades to come and helps to turn coal plants off. I might even make a percent or two over inflation, although that is debatable.
    After I sent off the money, I asked myself if now I am comfortable buying an EV for local driving, since the PV production is way beyond what an EV would consume and my home is already carbon negative. Somewhat oddly, I have to say 'no.' On the other hand, if I had put PV on my roof, or was able to participate in a collective solar farm in my city, the answer would be 'yes.' I think the position is illogical and is based on reverse NIMBYism. That is, knowing that a local EV in isolation at my home will increase electricity demands that will be satisfied with coal keeps me from buying an EV, even though I know I have offset that coal use elsewhere. Or another way to look at it: I am loathe to do something that increases coal use, unrelated to what I have done to decrease coal use.
    I presume somewhat similar opinions are behind the common finding that EV owners are personal PV owners.
    Comments ?
  2. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    I've thought about this quite a while, because I'm in the opposite situation. I own a PHEV, but my roof is not suitable for solar. I ended up with the PHEV because, at the time, I was able to buy clean power from the grid. But really, I ended up with it because my thinking was unclear.
    Put that aside.
    If there is a connection between owning grid-connected PV and an EV, it has to be psychology. Because there should be no logical connection. There's nothing about owning grid-connected PV that makes an EV any cleaner. It's the carbon intensity of the local grid that determines the impact of the EV, whether you have grid-connected PV or not.
    A lot of people don't believe this or refuse to get it. But just sit down with a paper and pencil and work out total carbon emissions for the entire system -- PV plus grid.
    Every KWH your PV puts onto the grid displaces a grid-produced KWH. So, you put a KWH onto the grid, you reduce carbon emissions by that much. (In Virginia, by 1.1 lbs CO2 per KWH). Every KWH you you don't put out onto the grid requires the grid to make that up with a grid-produced KWH. And so increases emissions by that much.
    In short, if you're connected to the grid, every KWH you use in the home requires the grid to produce another KWH of electricity. Grid-connected PV reduces the average carbon-intensity of the grid, by adding a clean power source. But at the margin, consuming another KWH in your home still generates the average carbon emissions of the (now somewhat cleaner) grid.
    Restated, the more you use in your home, the less fossil-fuel-fired KWH you displace off the grid. I guess that's obvious. But it seems to elude a lot of people when it comes to grid-connected PV plus an EV.
    So if you put 10 KWH/day into your EV, and you have grid-connected PV, then, one way or the other, the grid now has to produce 10 KWH/day more electricity. Than it would have, if you hadn't charged your EV. So to figure your carbon savings from an EV versus a Prius, that's the figure you have to use.
    Here in Virginia, PV or no PV, if you're grid-connected, an EV at 3 miles per KWH has emissions that are maybe 30% less than a Prius. (That's operating cost only -- if you toss in the carbon penalty for manufacturing the batteries, pro-rated over battery life, the advantage is modestly smaller.) If you then work out the arithmetic of dollars per ton of CO2 avoided, EVs are way down the list, way below well-sited PV.
    The conclusion is that if the CA and NJ grids are similar to VA (and CA is), you get much bigger bang for the buck investing in PV than in an EV (assuming the alternative to the EV is the next best alternative, which is a Prius). What you've done is completely rational, from the standpoint of getting the greatest CO2 reduction per dollar invested.
    usbseawolf2000 and SageBrush like this.
  3. SageBrush
    11,627
    2,531
    Southwest Colorado
    I have been making this exact point for years, but to my knowledge you are the first person to adopt my position. LOL
    Well, not exactly the same point. While one kWh extra will approach the average carbon intensity of your local grid, I think it is more accurate to say the intensity will be however your local grid generates that extra marginal kWh. This is why I use 100% coal for my locale, even though the state-wide average is 40% coal. An interesting question is what happens with the converse: what is the carbon intensity of a saved kWh ? Here the utility would take out the most expensive kWh they could find, whereas an added kWh would be the cheapest kWh they can generate.
  4. wjtracy
    wjtracy Senior Member
    11,329
    3,593
    Northern VA (NoVA)
    I am highly supportive of smaller decentralized power plants (like solar on roof) and just plain anything smaller than the huge plants the utilities insist on for "economies of scale". You can see how the utility's approach worked at Fukushima with 10 GW and 5 or 6 rxrs in one spot on the map and more to be built same spot. I call this gotta-be-humongous syndrome the "Kinsley Landfill Syndrome" and/or PITBY "Put it in Their Back Yard" (Kinsley Landfill closure being my first eco-victory).
    I am less supportive of the idea that EV is green because you can fill it with solar. As per Japan, we may need elec for electric needs, and fossil fuels/gaso may be advantageous for cars especially of course Prius efficiency.
    CHOGAN2 I am thinking VA/Dominon is not yet big on supporting solar on roofs?
  5. SageBrush
    11,627
    2,531
    Southwest Colorado
    Wjtracy,
    I understand your point, but 'large scale PV' by a utility is still pretty small with a few exceptions compared to say a coal plant let alone a nuclear plant. And the differences in price as $/watt are typically less than 50%.
    I think CHogan will now agree with me that EVs are not a clear environmental choice until there is excess clean energy on the grid. And I don't mean shutting down wind so that coal plants can be profitable.
  6. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I like what my local utility, PG&E, is doing for their renewable energy option. Based on the power consumption of the customers opting into the renewable plan, they will enter into long-term contracts with 3rd party companies that will build small to medium sized solar generating facilities within the utility's service area.
    So, the PV is relatively local to me rather than being invisible (and being based on a tradeable RECs). If I use more energy at home and to power my car it collectively results in specific new contracts for regional PV installation.
    This plan is a redo of an earlier REC-based plan and was a result of negotiations with various utility reform and environmental groups. This is my superficial understanding anyway. I plan to read more about the details soon.
  7. kenmce
    kenmce High Voltage Member
    1,536
    511
    NY
    Your personal EV may be run on coal, (for the moment), but by buying it you are doing the heavy work of establishing a market for (potentially) extremely clean vehicles.
  8. SageBrush
    11,627
    2,531
    Southwest Colorado
    That is a standard argument that I think has some merit.
    However, it ignores opportunity cost. Money I spend on an EV is not spent on PV; by the time the future grid is able to support an EV cleanly (if ever) the one I bought is rusting away in a dump.
  9. Zythryn
    Zythryn Senior Member
    6,287
    4,286
    I disagree with your statement that there is "no" advantage.
    I do get the argument that grid tied PV panels automatically mean the owner has offset the dirty power from the grid.
    However, at the very least, the PV owner's use of his own solar power is better than the grid tied power simply because there are fewer losses.
    As for the general argument, the PV power definitely makes the EV very 'green' if any of the following are true...
    The PV panels would not have been installed if it were not for the purchase of the EV.
    The EV owner has become more aware of their electric bill, and thus has made a reduction in other areas to lessen the impact of the EV on their bill (this one really doesn't matter if they have PV panels or not).
    The PV owner generates enough power to offset all of their homes use plus at least some of the cars use. The greater the percentage of the cars power needs supplied the greener. Ideally it would cover all of both the house and transportation.
  10. SageBrush
    11,627
    2,531
    Southwest Colorado
    YEP
    Absolutely
    Nooo. This is the logical fallacy that Chogan and I were highlighting.
  11. Zythryn
    6,287
    4,286
    Ok, well 2 out of three isn't bad.
    You are right, on its own, 3 doesn't mean a persons EV is cleaner.
    For me, building a net zero house which includes cost of transportation incorporates the first point. So, it is a shortcut way to state it, but is not synonymous, therefore not logically valid.
    So I withdraw that one.
  12. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    I have a different viewpoint. It is entirely based on this question: What endpoint of sustainability are we after?
    Non-polluting vehicles (of which EVs are a big component) and clean power generation are both essential. It is not a high personal priority to constrain both of these to be in lockstep as long as both are addressed. If one starts to progress faster than the other, then that actually puts pressure to resolve the lagging side.
    Zythryn likes this.
  13. SageBrush
    11,627
    2,531
    Southwest Colorado
    I just finished reading our threads from 2010 and 2011 on this and related questions. We remain consistent ;)
    Electricity production from just coal in the US is in the 2 * 10^12 kWh per year range. It's replacement by clean energy, ignoring infrastructure requirements, will cost around 2.5 trillion dollars at todays prices. So we are not just lagging, we are darn near standing still. From a perspective of where to spend the public budget EV subsidy is difficult to rationalize.
  14. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    I'm not sure we are totally standing still. Most of the power plants close to me have been making the switch to Natural Gas. The Crystal River Coal plant has recently finish installing the long NG pipeline down the coast of Florida and the Weedon Island plant has finished making the shift from oil (!) to NG a few years ago. The other thread paper Plug in Prius - Most Environmentally Friendly Vehicle in Study, has an interesting graphic where the
    Leaf EV friendly states took a big increase from 2010 to 2012. (So our old threads address a dynamic in action.)
    Meanwhile the renewable mandates in a number of states are still driving wind and solar installations. One of the real subtile aspects is distributed solar and wind developments get virtually no press while big plant news makes it seem like only big plants are being built or not built. Installing a lot of solar panels on an old factory roof just does not make the national press....or even the local papers.
    I will keep looking out for the inflection point where solar generation costs become less than fossil fuel cost. I cannot predict when and where this will occur, but I know it will happen. At that point I expect new fossil fuel plants will experience a significant slowdown and (distributed) rooftop leasing will suddenly become a huge industry. It will be a very good thing if the EV industry has lots of choices when that occurs.
  15. SageBrush
    11,627
    2,531
    Southwest Colorado
    ^^ I was perhaps too free with my wording, I meant to convey that we have a *loooonnng* way to go to get coal off the grid, even if we accept NG as one of the substitutes instead of actual clean energy. If we want clean energy instead of coal I'll take a WAG that we are 100 years away at current rates, perhaps much more if energy demand grows as it has to date.
  16. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    I will fully agree about the long way to go, but I'm willing to bet that it will take about the same amount of time to get to equivalently broad carbon free vehicle (lack of) emissions.
    Obviously, I'm not disagreeing with the logic of the present situation. What I am saying is waiting on supporting EV vehicles until we reach a national point of only improved emissions from driving EVs has issues. Not having an auto industry able to build huge volumes of EVs when that point is reached should be avoided.
  17. icarus
    icarus Senior Member
    4,884
    976
    earth
    In most areas, PV is nearly a no brainer, assuming you have a satisfactory site (lack of shading etc) Given the tax credits, FIT rates, utility rebates etc the pay off is pretty quick, irrespective of future price increases in utility rates.
    That said, I am a big fan of pooling resources and investing in solar co-ops that are ideally suited. for example, instead of putting PV on YOUR house in say Seattle (assuming your house has good exposure) putting the same KWs of PV in Yakima or Ellensberg would yield about a 25% gain in total annual harvest, simply because there is more sun in Eastern WA.
    We get hung up on having "our own" PV we (both consumers and policy makers/utilities etc) ought to be looking at, and encouraging the most efficient options. Another side benefit of
    Co-op solar is the economy of scale makes it even more cost effective. Instead of costing say $5/watt installed, you might drop the price to say $3.50/watt, allowing your investment dollar go further and make the payoff faster.
    The bottom line is, even considering transmission loses, a large installation in a better location just makes economic as well as environmental sense.
    Icarus
  18. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
  19. SageBrush
    11,627
    2,531
    Southwest Colorado
    yep.
    As Icarus mentioned, local solar collective farms sound like a wonderful idea as well. I hope they come to NM soon.
    JMD likes this.
  20. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Start by asking yourself how different the world would be if long-range BEVs were economical, remembering that:
    - BEVs don't require petroleum
    - BEVs don't have a tailpipe
    - BEVs are quiet
    - BEVs can be charged at night and it's a natural time to charge
    - most electricity is used during the day
    - electricity can be generated from many sources
    - renewable electricity generators are getting cheaper
    - you can have PHEVs
    - BEVs use a lot of batteries
    - recycling exists
    - the world is more than the USA
    To, me, it's a real no-brainer why there's so much support.
    BTW, I'm sure that a significant fraction of PEV owners are PV owners because
    - they live in warm, sunny places
    - where they live having a PEV improves PV economics
    - where they live having a PV improves PEV economics.
    - they're somewhat altruistic
