One Bar on the Highway
Discussion in 'Gen 2 Prius Main Forum' started by qmanqman, Jun 15, 2020.
  1. qmanqman
    qmanqman Active Member
    444
    153
    CO
    Drove the '07 on a 40 mile highway round trip. I had it on cruise control at 80-85 mph and noticed that the battery was at one purple bar. The display would show the engine always providing power to the drive train. It would also go back and forth from charge to the battery from the engine and charge from the battery to the drive train. The battery level stayed at that single bar.
    As I exited the interstate I think I got two additional blue bars on the exit ramp alone. It's a long exit ramp. Then about 8-10 blocks into town the charge was back to the 4-6 blue bars and kinds stayed around in that neighborhood as I made it to my own neighborhood.
    Is it typical on the highway that the bars bottom out?
    52,854
    no, it usually bottoms out during stop and go traffic, and closer to full at highway speeds. how many miles on her?
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    the only times I've seen it do anything similar to that is if most of it was up hill.
    srellim234 and qmanqman like this.
  4. PriusCamper
    PriusCamper Senior Member
    13,463
    5,431
    Pacific Northwest, USA
    A poorly maintained hybrid system in a 13 year old car that's being driven 80-85 mph in the mountains of Colorado is going to exhibit the same symptoms. Assuming you have no warning lights you still have time to get everything healthy again by eliminating corrosion on the outside and poorly conducting crystalization on the inside (replacing hardware - three increasingly deep discharge cycles of the battery aka: reconditioning).
    Currently your pack is probably down near 50% of it's original capacity and you can get that back up to 96%.
  5. qmanqman
    444
    153
    CO
    285,000 miles on her.
    This was not driven in the mountains. The car has been in Seattle it's entire life until about a month ago.
  6. Mendel Leisk
    42,345
    With gen3 one bar displayed is never normally displayed, indicates a seriously depletion? Is gen2 similar?
  7. davecook89t
    davecook89t Senior Member
    1,093
    832
    Washington State, Florida
    I have seen one bar on multiple occasions in our Gen 2. It always worries me some, but so far no codes. I have never seen 0 bars and wonder if the software even makes provision for that. Has anyone else ever seen that? If there is at least one bar showing, does that automatically mean there is enough power to start the ICE?
    Graeme1949 and Mendel Leisk like this.
  8. qmanqman
    444
    153
    CO
    Someone posted something here a while back that explained the bars. One bar meant 40% charge and full 8 bars means 80% charge. Something like that anyway. They didn't mean zero and 100 percentages.
    Please explain how you conclude all of this?
    How did you conclude the system is "poorly maintained"? How is a hybrid system maintained anyway?
    What is "eliminating corrosion on the outside" mean? Outside of what?
    What is "poorly conducting crystallization on the inside" mean?
  9. davecook89t
    1,093
    832
    Right, but how would a 30% SOC be represented on the Gen 2 display is my question.
  10. qmanqman
    444
    153
    CO
    Now that I've read this twice the drive back home is from an altitude of 4700 to an altitude of 6300 ft. over about 35-40 miles. Even though the climb isn't steep it is pretty constant.
    I didn't pay attention to it going the other way. I'll make sure to do that next time.
    davecook89t likes this.
  11. PriusCamper
    13,463
    5,431
    There 'ya go.... And if you're doing that climb at 80-85mph, that explains one bar on the charge.
  12. PriusCamper
    13,463
    5,431
    It's Toyota's fault... Rather than properly maintaining the nickel-based battery to maximize it's lifespan Toyota decided to get the car's computers to keep running the car even when battery is so poorly maintained it only has 50% capacity remaining so no maintenance is required and they can sell you a brand new battery for thousands of dollars rather than maintain the old one for hundreds of dollars. It's very greedy and wasteful.
    The science that explains this is here: BU-807: How to Restore Nickel-based Batteries – Battery University
    And an in depth explanation of how to recondition batteries specific to Toyota and Honda Hybrids is here: FAQ (Frequently Asked Questions) | Hybrid Automotive
    SFO and srellim234 like this.
