One of my Prius won't start the engine....
Discussion in 'Gen 2 Prius Main Forum' started by priuslyfe, Aug 29, 2025.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,654
    789
    Southern California
    Electrically. (Or both in a way, electrically isolated by the mechanics of an electrical relay.)
  2. ChapmanF
    18,246
    Even, one could say, electromechanically.
    dolj likes this.
  3. pasadena_commut
    2,654
    789
    Southern California
    I'm trying to think of a case where actual mechanical isolation is controlled using electromechanical means. The only thing that immediately come to mind are release/capture mechanisms (solenoid controlling a lock or latch for instance), scaling up to docking clamps (albeit mostly in sci fi). I guess a robotic "hand" would be in this category too.
  4. priuslyfe
    priuslyfe Member
    233
    57
    Thanks and DAMN! again.
    I kept putting off driving it and I guess this is the lesson for everyone else. In my defense that stupid car has always started before. I have an idea if I use a different 12V (basically swap the 12V from my dailydriverPrius) it might start. wish me luck.
    tl;dr:
  5. PriusCamper
    PriusCamper Senior Member
    12,786
    5,178
    Pacific Northwest, USA
    Two batteries high voltage batteries will likely boost the odds of one of them being good but you won't know until they are charged and balanced. Maybe you can find someone near you to borrow the equipment from if you don't want to buy the gear?
  6. pasadena_commut
    2,654
    789
    Southern California
    The temperature of the battery/car might make a difference, if the car is just at that "can do it only under the most optimal conditions" stage. I'm guessing that freezing cold (as if that is possible this time of year) would be the worst choice. What would be ideal? Looking at the plot here for the battery mostly discharged (closer to 100):
    Nickel Metal Hydride (NiMH) - Euro Energy guide to battery chemistries number 1 - Euro Energy Resources Limited
    it looks like 45C would have the most current, which may or may not be enough current. It would also make the viscosity of the oil in the motor lower. Don't go above that (assuming that is even possible) because the trace for 60C is very close to that for 0C or even lower. Note that the temperature below the hatch floor can be considerably cooler than in the cabin. If the day isn't very hot retract the hatch cover and pull out the floor, and the plastic tray, then allow time for the pack to come up to temperature. It will lag the inside of the car by quite a bit.
    Honestly though, I'm thinking this pack will need to be charged, and most likely also balanced.
    priuslyfe likes this.
