One of them days.....
Discussion in 'Generation 1 Prius Discussion' started by EbonBetta, Jul 28, 2018.
  1. EbonBetta
    EbonBetta Junior Member
    47
    16
    palmdale
    2002 Prius
    I
    It is very Hot this summer and I drove 90-100 miles to a park in Long beach CA. On the way home all was well till I stopped to get food. I ordered my food and and drove up to the window . Soon as I went to pay I got the triangle of death and other fun stuff. I drove it home, which was just about a mile and looking in the HV coolant res. did not look like any bubbling. I'm hoping thats all it is. A few hundred But a relativly easy fix.. will try to get codes read later.
    52,891
    i hope so! how many miles on her?
  3. EbonBetta
    47
    16
    palmdale
    2002 Prius
    I
    213,000 give or take
  4. audiodave
    audiodave Active Member
    800
    272
    US
  5. EbonBetta
    47
    16
    palmdale
    2002 Prius
    I
    reason i suspect the hv coolant pump is i see nothing happening inside the the resoviour. and saw no indication anything was wrong till i sat in line on a dive up for food. figure as i was moving at speed it was getting some cooling and standing the cooling just went away...
    . yes 1 mile from home isnt bad.
    audiodave likes this.
  6. audiodave
    800
    272
    US
    I think the fuse for it goes as well so you'll want to check that too.
  7. EbonBetta
    47
    16
    palmdale
    2002 Prius
    I
    will chel the fuse also I went to pep boys and they read the code as p 3130
  8. EbonBetta
    47
    16
    palmdale
    2002 Prius
    I
    does anyone happen to know what size tubing I can use to route the coolant from the bleeder back to the resoviour ?
  9. EbonBetta
    47
    16
    palmdale
    2002 Prius
    I
    ok hoping other continue to read here....I have to change the hv coolant pump I got the area open and waiting on a pump but the car doeas have 213,000 miles on it should i change hoes as I go ? And are these special from toyota or does napa have them. ?
  10. audiodave
    800
    272
    US
    The pumps are really available online and most likely auto parts places. 60-80 bucks on Ebay for factory ones.
