One thing I really love about my Prius
Discussion in 'Gen 3 Prius Main Forum' started by stephensprius, Nov 26, 2013.
  1. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    I never realized how wonderful the heat is in this car. Last winter my wife drove the car and I had my Subaru Legacy. This is my first winter with it. It's incredible how fast the car warms up after a long, cold, Minnesota winter night in the non-insulated/ non heated garage. it's literally only a couple of minutes. Any car I've had in the past took at least 5- 10 minutes to get truly nice and warm. Is this something specific with the hybrid technology? Would the camry and avalon Hybrids work the same? Anyone else in the cold North experience similar situations? Either way, still happy. With heat blasting, I am getting 49-50 mpg driving in eco mode.
  2. gliderman
    gliderman Active Member
    751
    223
    What are your heater settings?
  3. CdotK
    CdotK Member
    376
    46
    i run my heat on HI with 2-3 bars (or whatever you call the speed) every morning and get the same 49-50MPG. Its a small car so it takes less time to heat up the inside.
  4. stephensprius
    670
    226
    What do you mean? temp is usually set at 75 in the AM and auto.
  5. stephensprius
    670
    226
    yeah, my subaru legacy wasn't huge by any means. I was just wondering if it had anything to do with the hybrid/electric technology.
  6. CdotK
    CdotK Member
    376
    46
    doubt it
  7. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    The Prius is worse at heating up the cabin that most vehicles because the heat is a byproduct of the waste engine heat. In the Prius the engine is one of the most efficient mass produced. So to begin with there is less heat available. Now add to that the engine shuts down, and therefore starts cooling off, pretty frequently. If you request heat it doesn't have, the engine will turn on and your MPGs will go down. Once operational and up to temperature, it will remain hot enough for people if you request it. Even as efficient as the Prius engine is, you don't want 100% of that heat in the cabin.
    I have had a Subaru before and mine took a while to heat up as well. I could drive 8-10 miles to my destination and the heater would just start to blow warm air. I figured it was just broken since it had a blown head gasket, radiator and water pump problems at the 300K mile mark I was driving it at. I did enjoy the automatic seat belts though lol.
  8. Les_PL
    Les_PL Active Member
    317
    248
    Gdynia, PL
    The technology itself - the excitement, faster heartrate - hence the illusion of Prius having such efficient heating ;).
  9. WE0H
    WE0H Senior Member
    3,247
    527
    All the rental Prii I have driven in the winter have absolutely cooked me out of the car [​IMG]
    Mike
    stephensprius likes this.
  10. Les_PL
    317
    248
    Gdynia, PL
    Well, I did not mention that I'm still balancing between comfort and fuel economy ;)
    WE0H likes this.
  11. stephensprius
    670
    226
    Where in MN are you?
  12. stephensprius
    670
    226
    I would always choose comfort, especially in 10 degrees.
  13. WE0H
    WE0H Senior Member
    3,247
    527
    I'll send a conversation message.
    Mike
  14. WE0H
    WE0H Senior Member
    3,247
    527
    7F here this morning. Chilly. 40F in my garage where my car is snoozin until spring :)
    Mike
  15. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    Have you experienced flat spots on the tires after a long winter snooze?
  16. BreakingPrius
    BreakingPrius Junior Member
    35
    So these are no good in the snow? I've been wondering...
  17. stephensprius
    670
    226
    it's really not that bad. the only issue is with the clearance.
  18. stephensprius
    670
    226
    Do you regularly start it up and let it run? Is that a problem with the hybrid tech?
  19. WE0H
    WE0H Senior Member
    3,247
    527
    No problems with flat spots after about 8 months sitting in the garage. I believe that is how long it sat last winter. Michelin MXM4 tires and I run them about 49 front & 47 rear psi.
    Years ago running tires they made back then; I used to have a few miles of bumpidebump driving until the flat spots worked their way out ;) I have a feeling the tire designs we have today eliminate that issue.
    Mike
  20. stephensprius
    670
    226
    WEOH: what do you drive in the winteR?
