One very good reason to carry the physical key with you.
Discussion in 'Gen 3 Prius Main Forum' started by GregP507, Feb 12, 2015.
  1. GregP507
    GregP507 Senior Member
    3,002
    481
    You'd think; but experimenting around isn't what you want to do in a busy parking lot.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    This is one of the reasons that I try to remember to lock my doors with the door sensor. If there are any issues with the door locks, etc. the car will beep at you and give you a warning message.
  3. GregP507
    3,002
    481
    I don't think it matters if you use the inside lock-button, the door-sensor or the fob-button. Same result. In my case, the seat-belt buckle got caught in the door just right for it to hit the first latch. Electronically, the door is "open" but physically it's "closed."
  4. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Yes it does.
    I know I can lock my wife's key fob in her pocketbook in the car with the remote button but not the door sensor. When I try to lock it with the door sensor it will beep and tell me the Key is Detected.
    I also know that one time the hatchback latch got caught on a blanket in the back and it was reported with the door sensor with a beep and a message saying a door was open.
    Blizzard_Persona likes this.
  5. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Did you try double clicking the remote unlock button? That should unlock the other doors.
  6. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Did you try standing on your tippy toes and clicking your heels together?
  7. Mendel Leisk
    41,473
    ^ He's saying the car's been spoofed into thinking it's unlocked, due to being sorta half-locked.
    Greg, I'll bet somewhere between the factory and you, some salesman was showing a customer the physical key in the fob, forgot to put it back in, test driver's kid got a hold of it, something like that. You should have a physical key in both fobs.
    Anyway, solution: no more leaping outa the car, take your time. ;)
  8. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Does your keyless key fob have a hole at the end where the key is supposed to be like in the other one and like everyone else's? If not maybe it is a knockoff fob that was programmed to to the sks...
  9. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Hey?
    Carrying the fob...or a fob, WITH the physical key is a good idea.
    So the OP's scenario contains more variables than my receiving a winning lottery ticket from a disgruntled leprechaun riding a unicorn.
    It still COULD happen.
    I'm not arguing with the advice. And if you'll excuse me, I'm going to check my lottery ticket numbers....
    #29 The Electric Me, Feb 13, 2015
  10. GregP507
    3,002
    481
    Whatever the "best solution" may be, the only one I came up with at the time was to unlock the door with the physical key.
  11. retired4999
    2,652
    627
    Eau Claire, Wi.
    My extra key is under a big gray fake rock in my grass garden. :whistle:
  12. GregP507
    3,002
    481
    Just between you and me and the whole world, I won't tell.
    retired4999 likes this.
  13. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I'd like someone to try this on their car (I've got the Volt with me today).
    Semi-close the front door, lock it, then hit the unlock button on the fob twice. That should give you three doors that you can open, even if for some reason the driver's door doesn't unlock.
    So there's no way to hang that fob on a keyring?
    If I pull the key out of the fob the key stays on the ring and the fob is untethered.
    Maybe that changed in later years?
  14. GregP507
    3,002
    481
    I'm not sure what you're talking about, but I carry one fob on a key-ring, and the other one is in an undisclosed location as a backup.
  15. retired4999
    2,652
    627
    Eau Claire, Wi.
    I don't know if my car is different but when I lock my car and it just latches on the first latch I just push the fob once to open the door.
    You are right thou that if you try to use the touch area on the door Handle it does not work, use the key fob.
    #35 retired4999, Feb 13, 2015
  16. GregP507
    3,002
    481
    Your spell-checker is working, perhaps a little too well. Better get a handle on it.
  17. bisco
    51,961
    it's all a mystery.
  18. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Perhaps he's the Messiah...
    xliderider likes this.
  19. retired4999
    2,652
    627
    Eau Claire, Wi.
    I do like music, does that count!
  20. bisco
    51,961
    of course!(y)
