Only 514 miles and technical issues already?!! (Gas tank always reads empty)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Prius Five Guy, Sep 15, 2012.
  1. Prius Five Guy
    170
    Los Angeles
    2013 Prius Plug-in
    Every morning when I start the vehicle the gas tank always reads empty? Parked it overnight with a 3/4 tank of gas....what's going on??!
    52,822
    what does it read when you are driving? and at the end of the day?
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I know that on the Gen 2, if you never add more than 3 gallons, it never gets full.
  4. Prius Five Guy
    170
    Los Angeles
    2013 Prius Plug-in
    read empty en route to the gas station. was only able to put in 9 bucks of gas. tanked showed full after leaving gas pump
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Empty as in the last bar flashing?
    A few years ago there were reports of sulfur contaminated fuel messing up cars' fuel level sending units. Where did you buy fuel?
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Iwould go refill the tank completely and see what happens. $9 doesn't buy much fuel so you have have confused the tank.
  7. Prius Five Guy
    170
    Los Angeles
    2013 Prius Plug-in
  8. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
    Had a spanking new Honda minivan lo these many years ago. The tank would read full, go down to around 3/4 of a tank, then popped down to zero and stayed there.
    Interestingly, the low fuel light wouldn't go on when it did this, but did go on when the gas tank really did become nearly empty.
    Dealer said gas tank sender; I said it's in the dash. He was wrong, I was right, and they replaced the entire instrument cluster, odometer and all.
    So: do not know if your problem's in the gas tank sender, the computer, or what: But hie ye on down to ye dealer and let them contend with it. That's what they're there for.
    Kbeck
    Corwyn likes this.
