Only Mobil 1 For My Prius
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by priusgto, Aug 19, 2016.
  1. priusgto
    priusgto Active Member
    193
    227
    Northern Arizona
    The first few months we owned our new Prius we could easily hit the 70 MPG range on our 45-55 mile round trip into town with our best ever at 72.4. Then in April I did the first oil change at 3500 miles using genuine Toyota 0w-20 oil and filter. Immediately after that first oil change the ICE developed a rattle for about 1 second on the first start of the day and only the first start. I figured it was either the timing chain tensioner or a vvti cam gear being affected by cold oil flow so a few weeks later I changed the filter to a Fram ultra synthetic but the rattle was still there. I also noticed that the easily attainable 70 MPG now dropped to the 65-69 range but didn't worry about that either as it was getting warmer out and we started using the AC more often.
    Now 3500 miles later, getting ready for a long road trip (4 to 5K miles) I decided to do another early oil change. Since Mobil 0w-20 AFE was on sale I used it along with another Fram synthetic filter. The next morning, yesterday, I started the ICE and didn't hear the rattle. Today, same thing, ICE started without a peep and, on the first trip into town since the oil change, achieved the best ever 73.5 MPG, and with the AC on.
    Coincidence? Fluke? Hard to tell this early but I'll keep you all posted.
    49,500
    i've been a mobil one guy for almost 40 years, since i first started putting it in my 1972 fiat 124. good stuff.
    priusgto likes this.
  3. priusgto
    193
    227
    Northern Arizona
    Sorry for the duplicate posts. I was having a problem with my connection and the thing timed out twice and never showed the thread.
    49,500
    it's not you, it's me.:cool:
  5. Mendel Leisk
    38,728
    Strange. You did the first oil change yourself, bought the oil, saw the bottles?
    All I've use for DIY oil changes (on our 2010), about eleven so far, is the Toyota 0W20 and their oil filter, no problems.
    But I'm not trying to dismiss your concerns. Anything that could be missing from this picture? do not know..
  6. priusgto
    193
    227
    Northern Arizona
    Yes, I do all my own maintenance and don't trust those teenage oil changers, who traded their Fisher-Price tools for Snap-on, to touch my car. Guess it's the aircraft mechanic in me. I bought the oil and filter for the first change at the dealership, still have 1/2 a quart left and will just use it to lube my gate hinges.
    Do you start the ICE before you drive or just let it start when it wants to? After I power up the car, I step on the gas once to get the ICE to start before I drive it and this is when I heard the rattle. Hard to hear it if the car is moving before the ICE starts as my drive is gravel.
    #6 priusgto, Aug 19, 2016
  7. bisco
    49,500
    mine have alays started within a few seconds of powering up. those were gen 2's. the pip starts as soon as you hit the hv button, so, not sure if it's like the lift back.
    ETP likes this.
  8. Mendel Leisk
    38,728
    I just start and go, engine invariably starts around 15 seconds (typical 3rd gen behaviour). We use a block heater almost without fail, but not 100 percent.
    It's a stumper. Bad batch or mislabelled?
    ETP likes this.
  9. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Mobil 1 rebate of $12 off on a 5qt jug Request Rejected
    That reduces oil change costs dramatically! You have till Oct to buy. They don't list walmart as a participating vendor but I submitted them last time and it wasn't rejected.
    ETP and priusgto like this.
  10. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    If you look at the specs (which were posted here a few years ago) I believe the Toyota is "superior" in the sense of being lower viscosity at cold start temps. So your observation suggests that could still be true. Presumably Arizona may not need that, but if you lived in Northeast in winter you might want that.
    After that I have no idea if a little noise is considered a good thing or a bad thing. The best quality would presumably have lower viscosity at low temps, and higher visocity at high temps (hot). The best quality would also retain viscosity without too much breakdown.
    Hey I always use Mobil-1 by the way. If Wlamart had the Toyota as coveniently I would consider that too though.
    #10 wjtracy, Aug 19, 2016
    Robert Holt and ETP like this.
  11. priusgto
    193
    227
    Northern Arizona
    Thanks for the 411 fotomoto. Walmart has the 5 qt jug for $22.88, I bought two so if the 12 dollar rebate applies I'll be doing like they do down south, chittin in tall cotton
    The odd thing is that even when I was down in Phoenix where overnight temps were above 80 the rattle was still there on the first start.
    ETP likes this.
  12. bisco
    49,500
    i got my first two 'free' oil changes at toyota, and two mobil 1 since then. never noticed a difference.
  13. priusgto
    193
    227
    Northern Arizona
    I was told by my local dealership that they use a bulk 0w-20 oil and the brand varies. They also said the Toyota oil doesn't come in bulk so they normally won't use it for dealer servicing unless the customer requests it. Quite possible you have been getting Mobil 1 from the start.
    #13 priusgto, Aug 19, 2016
    bisco and ETP like this.
  14. GaryD1
    GaryD1 Active Member
    302
    138
    Seagrove, NC
    mobil 1 full synthetic 0-20 here since the two free ones on 2011 with 163k on it. The car still goes in between changes without having to add and without it being low on oil every 10k. I guess I got a good one. My 2015 does not go down in between changes so far but only got 18k on it.
  15. Mendel Leisk
    38,728
    On a New Owner night we did a walk-thru the service bays with the service manager. He described their bulk oil as Toyota, noted has a distinctive amber tone.
    I'm buying their bulk oil now, it looks the same color in a graduate, and I believe my invoice is saying it's Toyota. They treat my bulk purchase as a service item:
    (It's an 8 liter purchase, there's a sneaky volume adjustment to accommodate a price quote.)
    ETP likes this.
  16. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    That's consistent with what I am saying though, the Toyota is (according to past info) lower viscosity (thinner) at low temps so concievably it is less clingy on the metals parts at 80F but it'll get pumped over the parts pretty fast upon start-up.
    ETP likes this.
  17. Toppcat
    Toppcat Member
    223
    69
    Northern California
    On my 3rd oil change running Enzo 0-20 w from toyota OEM 0-20w mpg read out and scangage ll around 47mpg actual calculated 41mpg off by 6
  18. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    I was told by my local dealership that they use bulk Toyota 0W-20 oil, "made for Toyota by Mobil1."
    ETP likes this.
  19. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,801
    1,170
    Auburdale FL
    Yep, the specs are different but the dealer I bought it from uses/advertises Pennzoil. Not sure what they use back in the shop. Some use 55 gal drums or larger and some use the plastic bottles. No way of knowing unless you walk into the oil change bay and get run off. Could bring a movie camera and say it is a Prius Chat interview.
  20. ETP
    2,801
    1,170
    Auburdale FL
    BTW/there is a post somewhere on the exact specs. Looking.
