Open Prius C hatch from inside the car?
Discussion in 'Prius c Accessories and Modifications' started by Andrea the Strange, Aug 29, 2020.
  1. Andrea the Strange
    Andrea the Strange Junior Member
    Riverside, CA
    2018 Prius c
    Hi folks! This is my first post.
    I'm on my second Prius C. I like to camp in the back. I want to open the hatch from the inside instead of going in and out of the side doors to push a button and pop the trunk. I can only find videos for the various full-size Prius models. I've Googled. I've tried to MacGyver it. I've accomplished nothing. Has anyone been able to do this? 20200826_105200.jpeg
  2. frenzee
    frenzee Member
    95
    73
    16
    Costa Mesa, CA
    From what I recall (when I had the hatch cover open to replace the license plate bulbs), there is no mechanical linkage for opening the hatch manually from the inside. IIRC, if that servo motor fails with the hatch closed, it will remain permanently closed.
    The only way I can think of is to splice in a bypass switch in parallel with the external push button switch. There is a harness that plugs into the servo motor which opens the hatch. You will have to figure out which one of the cables in that harness go to the switch. Sorry, I don't have any pics.
  3. Andrea the Strange
    Riverside, CA
    2018 Prius c
    Thank you so much! I admittedly understand very little of what you're talking about because you are clearly adept at this whereas I am not, but I appreciate it anyhow, especially since it gives me an idea of who I might be able to turn to for help. I'll update if I'm able to get this done. Thanks again!
  4. topshot
    topshot Member
    142
    56
    Midwest
    2015 Prius c
    Did you ever get it done?
  5. Danny13pruisc3
    173
    27
    maryland
    I could probably figure this out... but.. it's very low on priorities list lol like something ot do right before i die if i have done everything else lol
