OpenPilot + Prius Prime 2020
Discussion in 'Prime Main Forum (2017-2022)' started by followingalex, Sep 19, 2019.
  1. genericuser
    genericuser Junior Member
    31
    San Francisco
    2020 Prius Prime
    Thank you for helping me offline in the middle it the night to resolving my issue. I can try it out on my mini road trip today.
    Big thank you. (y)
    illumiN8i likes this.
  2. Blue-Adept
    Blue-Adept Active Member
    293
    179
    Grand Rapids, Michigan
    2018 Prius Prime
    What was your order number? Still waiting for my unit. I am in the 6000 range.
  3. genericuser
    31
    San Francisco
    2020 Prius Prime
    Me? 66xx. They sent you a tracking number right? I live in CA where they're based so got it in 2 days .
  4. Blue-Adept
    293
    179
    2018 Prius Prime
    No tracking number yet. My connection said since my order number was In the 67XX range I would have it in a week. .
  5. Schrauger
    Schrauger Junior Member
    27
    Once you've used OpenPilot for a few weeks, feel free to try out a fork that takes advantage of the better steering sensor that the 2019 and 2020 prius primes have. It should make for a smoother ride. Search for the zorrobyte fork in discord.
  6. Suspi
    Suspi Junior Member
    27
    2020 Prius Prime
    Our own @illumiN8i also has a custom fork that does a fantastic job
  7. Blue-Adept
    293
    179
    2018 Prius Prime
    How can I get the better sensor?
    Can I upgrade?
    Blue
  8. genericuser
    31
    San Francisco
    2020 Prius Prime
    I just wanted to thank @illumiN8i again for helping me with the fingerprint process.
    Got back from a mini road trip today and I'll say that for any distance driving, this is a must have. It took me a while to 'trust' it and even now I'm attentive to the situation around me and always have my fingers touching the wheel at all times to take over if needed. Well, I haven't needed it one time.
    The one thing I noticed if I was in the slow lane, it would sort of creep to the right on every exit and correct itself due to the lane markings on the right disappearing at the exit. They should program for left hand drive countries to favor the left lane and stay centered in those situations. And vice versa for right hand drive.
    Another thing I found is, I mounted my device near the center top of the windshield which means the actual camera on the device is about 2 inches left or centered which makes the car a tad bit hugging the right lane. I'm sure there is a setting to offset that by SSHing into the device and modifying a file somewhere.
    Overall, happy with the purchase. Guess if your driving is mostly surface streets, then this might not be needed.
  9. Schrauger
    27
    The default code already assumes a 6cm offset, so you should be fine if the device itself is centered. You could try re-running the calibration if you feel it's hugging the right side too much, but it may also be that you're used to driving a little left of center and OpenPilot is trying to stay dead center.
  10. Schrauger
    27
    I don't know if you can get parts from a newer model and install it on your 2018. But if you want a better sensor, search the discord for ZSS, an even better aftermarket sensor from zorrobyte. I think he sells them for ~$200, though I haven't checked recently. The sensor he makes is extremely accurate, and those who bought and installed it (very easy to do, apparently) have said it makes OpenPilot run smoother than anything else.
  11. genericuser
    31
    San Francisco
    2020 Prius Prime
    Unfortunately, I mounted my device just about 1.5 inch off center towards the driver side :(
  12. Suspi
    Suspi Junior Member
    27
    2020 Prius Prime
    You can adjust for it by modifying the CAMERA_OFFSET in selfdrive/controls/lib/lane_planner.py
  13. fotomoto
    fotomoto Senior Member
    5,630
    3,804
    So. Texas
    Never say never. ;) I've found it works well on some city/urban streets too; just depends on several factors including driver confidence. But yes, OP is the shiznits for highway/commuters. (y)
  14. pbasch
    pbasch Junior Member
    40
    Los Angeles
    2018 Prius Prime
    I'm interested in a Comma system for my 2018 PP, but I'm baffled by Discord. What is it, a thing like Slack that I have to download and install? Or is it a website? The website keeps telling me it's reserved a place for me, which is a bit weird.
  15. illumiN8i
    illumiN8i Active Member
    184
    142
    Grand Rapids, MI
    2018 Prius Prime
    Discord is like Slack. You can use it on the website discord.com or download it. To join the comma.ai community on Discord there is a link at the bottom of the comma.ai website. The comma two install process is much more streamlined now. You probably won't even need to ask for help on Discord. Just follow the installation instructions that can be found on Youtube.
    This thread is getting old now the issues that were discussed previously are no longer relevant to the latest versions of openpilot.
  16. fotomoto
    5,630
    3,804
    So. Texas
    The biggest strength of this solution. (y)
    The biggest weakness (for me) is heat.(n) I removed my comma one several weeks ago because it's too hot here to leave it mounted on the windshield and the mount/dismount process is too much of PITA for day to day driving; just use it for long trips now. Will wait to see what comma 3 offers in the future. :unsure:
  17. illumiN8i
    184
    142
    Grand Rapids, MI
    2018 Prius Prime
    Do you mean Comma Two or do you have the old EON? The old EON needs to be removed, but the Comma Two should be fine to leave on the windshield. I read that the openpilot team is committed to resolving any remaining heat issues with the Comma Two through software updates to reduce CPU usage.
  18. fotomoto
    5,630
    3,804
    So. Texas
    Yeah, the original EON that I got 6 weeks before the ONE was announced. :cry: Some Honda Clarity folks (what I'm using it in now) are reporting same heat issues with the TWO. Folks up north or in more temperate climates are OK.
    FWIW
  19. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Do the regular Prius 2019 and 2020 also have the better steering sensor?
  20. eskudo12791
    eskudo12791 Junior Member
    22
    Virginia Beach
    I believe the 2019/2020 steering sensor is an improvement over the 2017, but the upgraded sensor that a member on the discord sells is still superior to it.
