Opinions Wanted: "Unity" Front Strut Assembly $75
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SageBrush, Oct 3, 2014.
  1. exstudent
    exstudent Senior Member
    2,214
    906
    Torrance, CA
    Brave. Glad you didn't get injured.
    Was this the first strut change for this car?
    Do report back at some mileage point and let us know a longer term update, say at 15K and 40K mile?
    Remember, struts wear out slowly and you probably won't notice the difference unless the tell-tale signs: bottoming out, hop scotch marks on tire, etc.
  2. Next GenRacing
    Next GenRacing Junior Member
    Ft. Lauderdale Fl
    I actually didn't really even have a ride start with, but Sunday morning on my way to work I heard a clank and suddenly every bump I hit made a serious racket. I inspected for loose parts and checked the ball joints and tie rods which looked fine so based where sound coming and process elimination I figured was the strut. I'm guessing the mounting bracket or something cause the ride quality was fine, no bouncing or excess rolling during turning, or excess movement during acceleration or braking.
    It was my first strut install on a prius, however I have worked on cars a number of years, this wasn't my first rodeo.
  3. Logangogarty
    Logangogarty Junior Member
    31
    Are you still enjoying these Unity struts? My 2007 Prius has 163,000 miles and I think I'm due for some new struts. The front left tire is making a faint thumping noise only on smaller bumps. I have never changed struts before but I think I may go with the Unity because of the simplicity/price and because I may not have the car much longer as I plan to move to CO this summer. Any regrets or suggestions before I pull the trigger?
  4. thegoldenhand
    thegoldenhand Junior Member
    44
    California USA
    Aside from Unity have you also seen the SenSen struts? Via rockauto, they'd come out to about $141 shipped for all 4 struts/shocks. Just not sure how reliable they are.
  5. Logangogarty
    31
    Did a quick google search and this came up
    made me a little hesitant to go with Unity or Sen Sen after reading the comments and watching the video. Love the price though
  6. Logangogarty
    31
    I think I will order kyb or monroe and then take them to pep boys to have my old coils put on. Does anyone know how reliable the old coils are at 165,000 miles? Is that something I should consider replacing as well?
  7. Patrick Wong
    18,210
    6,526
    Unless you notice that a corner of the car is lower than the others, or believe that the body in general is riding lower than it should, that probably is not necessary.
  8. Logangogarty
    31
    Ok great I will just go with KYB or monroe then and order the parts online and have a shop swap the struts for me then try and put it all back together. Thanks
  9. Patrick Wong
    18,210
    6,526
    Make sure that the shop you have in mind for the service is willing to use parts that you supply. Don't forget to replace the front strut mounts and the front strut rubber pleated covers.
  10. Logangogarty
    31
    Any advice on KYB vs. Monroe? Which website usually has the cheapest price? I'm looking on amazon and tirerack right now. So I need
    1. Struts
    2. Strut Mounts
    3 Strut Cleated Covers
  11. brucebee
    brucebee Junior Member
    84
    vista, ca
    are there no performance shox 4 the prius? offroaded a lot and a set of blown out bilsteins on a vw bug worked way better than stock stuff. same on a toy4x... or a chevy truck. sorry i dont know but limited computer availability.
  12. brucebee
    84
    vista, ca
    i should have added they were 250t for vw and 500t for toyota...bought in 1977.& 1994 respectivly, parts only .
  13. Logangogarty
    31
    I ended up getting my kyb struts and mounts from shocks.com they were only $220 total. I haven't opened the box yet to see if everything is there but I read a lot of complaints about shocks.com because they don't have a phone number and are hard to get a hold of. Saved me like $40 in comparison to other sites.
  14. jichi
    jichi Junior Member
    Could you please tell us how is the unity struts are doing so far and how many miles you put on them becuase I already ordered them and I am kind off worried about the quality since i read some reviews on amazon that they fail after a year. And here in Indiana driving on I65 south from indianapolis to columbus IN is like driving in a parking lot with speed bumps.
  15. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    You chose well.
    I've done a fair amount of suspension work on a number of cars. I wouldn't put Monroe shock/struts on my car if they were free and came with a complimentary travel mug. If you get 2 years out of them, you'll have done well. While I have no experience with the two knock off brands mentioned earlier in this thread, I would expect their quality to be even lower than Monroe.
    In my opinion, cheap suspension parts are a bad value for a number of reasons:
    1) every time you change a suspension part, you need an alignment. That's $80 - $90. So if you have to do it once every couple years, instead of once every 10 years, those alignments are going to eat up your savings. (if you're not getting an alignment after suspension work, your savings will be eaten up by the cost of new tires)
    2) My time is valuable. I don't want to be changing crappy Monroe shocks every couple years.
    3) Upper strut mount quality: Upper strut mounts have a lot of pressure on them. If they fail, that strut is going right through the hood. Back in my Volvo days, cheap strut mounts from ScanTech had a reputation for doing just that.
    When it comes to sourcing quality OEM parts, Toyota's reputation is the best in the automotive business. Admittedly, they charge accordingly.
    KYB is an excellent suspension company -- it doesn't surprise me that they are the OEM supplier for Toyota. If you put KYB or Bilstein on your car, they will likely be the last strut you'll ever have to buy for that vehicle.
    IMHO: do it right the first time, and be done with it.
  16. G's Prius
    G's Prius New Member
    Long Island
    It is the worst product I've ever purchased online. Yes, the price is too good to be true- the product came defective right out of the box. My mechanics took video of the broken strut and the company still didn't react promptly. Customer service was a complete run-around- emails unanswered for weeks, phone calls not returned, and no one owns the issue instead everyone punts. Don't waste your money! Clearly, I'm not happy and willing to share my experience.
  17. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Good post G, the kyb's that come on the car I imagine are inferior to the kyb's you buy aftermarket, I'm thinking Toyota buys them by the million and get's a slightly less expensive version...
    I know my kyb replacements lasted more than the 40,000 that wore out the originals, and had a superior ride, in handling.
