Optima battery bad "again"
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriusGuy32, Jan 2, 2014.
  1. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    SO when I bought my Prius in Sept 2012, I replaced the ailing, occasionally down to 9.9 volts, original 12v battery with a yellow top optima from Advance Auto. (y)
    Got a bad one off the shelf, full of dust and a date stamp 10 months before the date I bought it. Wouldnt hold a charge past 12.1v.
    The replacement wasnt that much better, but I was happy with 12.2v and a newer (still sitting on the shelf for 7 months) date code.
    Well fast forward what - 14 months? And my yellow top Optima is going down to 11.6v. WTH.
    When I exchanged the first defective Optima, the 17 year old kid at Advance Auto gave me a really hard time - telling me 12.1v was "fully charged" "anything above 12.0v means the battery is GOOD". Does anybody get trained anymore or do they just spew anything they feel? Anyways I digress....
    I called Optima today, and just got a pre-recorded loop about their warranty (36 months) policy. I wanted to speak to a person to see if I could exchange the battery direct through Optima and NOT advance auto. Any suggestions?
  2. Patrick Wong
    18,214
    6,530
    So when you saw that the voltage was so low, did you charge the new battery prior to installation? You should expect a fully-charged AGM battery to be at ~12.9V.
    If you didn't, then depending upon your driving patterns, the battery may have been operating in a partially discharged state much of the time which will shorten its service life.
    Even if you did fully charge the battery, if you don't log 12K miles or more per year, it would be good to periodically charge the battery to help extend its life.
    Silver bullit likes this.
  3. PriusGuy32
    1,417
    514
    Thanks Patrick.
    Not only did I originally charge it, but I also periodically use a 1.5amp maintenance (read: float/trickle) charger.
    I also logged a tick under 21k miles in 1 years time.
  4. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Hi Priusguy. What were the conditions under which you measured the 11.6 volts. Was it under no load/acc mode/ ignition on mode etc. Also, were you using the MFD diagnostic mode or measuring with an actual volt meter. Finally, what was the outside temperature prior to the measurements.
  5. Flying White Dutchman
    4,376
    314
    that can be your problen
    what kind of tricle charger
    you can damage your battery with a cheap trickle charger
    go for a C-tek. those stop charging when the battery is full and start again after the voltage drops to some degree.
  6. PriusGuy32
    1,417
    514
    Oh lord. The battery is bad guys. Its nothing I did- I knew it was exhibiting subpar performance when I bought it. :rolleyes: Buuut to answer your questions, I already use a "smart" charger. It does the different steps.. load/unload, desulfate, float, maintain blah blah blah. Its a Even after a successful charge, it will maybe go to 12.5v max and start decreasing over time with nothing hooked up to it. After a day or so in the Prius, when I use my DVM on the battery posts, it will be down in the 11.x volts range. Also, the battery is inside my Prius in our heated garage , which is currently set to 69f degrees.
    My real question is- is there anyway I return it through Optima? I would normally ask Optima this kind of question, but I called yesterday and just got a recording. I figured with all of the people here who use Optimas, and the reported problems Ive read about, has anybody used Optima directly for battery warranty replacment?
    Sezy likes this.
  7. ski.dive
    ski.dive Active Member
    967
    247
    Hutchinson Island,FL. Mt. Snow,VT
    You got a lemon . Take it back to Advance Auto, tell them your story.
    Sezy likes this.
  8. CLUBGUY
    CLUBGUY Member
    293
    50
    Cincinnati
    May wish to try...
    [email protected]
    explain you problem via email since you are unable to contact Optima by phone...
  9. PriusGuy32
    1,417
    514
    Thanks guys. :)
    My problem is Advance Auto Parts wants to "load test" the battery and of course, it passes. When they charged it in the past with their charger and it returned 12.1v, the kid states thats a GOOD battery :rolleyes: Thats why Im trying to contact Optima. I'd rather go through them for warranty exchange because to be quite honest - I seem to get the biggest dolts at the auto parts store. 12.1v is clearly NOT a fully charged healthy battery, especially when Optima states the resting charge of their yellow top should be 12.6-12.8v+.
    Not to mention, who knows how long the battery has been sitting on Advance Auto Parts shelf..... last time it was 10 months without any activity (charge cycles) and likely sulfated.
  10. Mike500
    Mike500 Senior Member
    2,593
    767
    I've had AGM batteries killed by keeping them on the Battery Tender, Jr.
    Surprisingly, I've found the $5 (with coupon) battery maintainer to be one of the best deals out there.
    Battery Float Charger, Automatic
    The maximum output is not more than 13.2 volts, which means that it will NEVER "fry" the battery.
  11. usnavystgc
    3,159
    990
    Tucson, AZ
    Wow, I'm sorry your having this problem. Unfortunately, I don't have a good answer for you. That sucks.
  12. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    The instructions for that charger clearly state "To prevent battery damage. Do not use on AGM batteries use for flooded lead acid batteries only". The Prius battery is an AGM.
    AGM batteries need to be float charged at 13.6 to 13.8 volts.
    John (Britprius)
  13. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Whereas the Battery Tender Jr. specifically claims to be OK for AGM.
    Regarding Advance, maybe the staff has turned over since your first experience there. Can you return it through a different store?
  14. PriusGuy32
    1,417
    514
    I hope the staff has turned over.... over and on to higher education! lol :D
    FWIW, OptimaJim - an Optima battery representative has chimed in these threads before and clearly stated that you should charge an Optima AGM like a regular wet cell. He stated that is isnt like other AGM's and to charge it like a regular ol' battery is best.
    Mike500 likes this.
  15. Mike500
    2,593
    767
    I'll stick with regular batteries and replace them in a few years.
    A NEW battery is always better than a used one that is three (3) years old.
    I hate PRORATED BATTERY WARRANTIES beyond the full exchange period. To me, they are almost worthless.
    PriusGuy32 likes this.
  16. Britprius
    5,194
    1,924
    Optima state there batteries if trickle charged or left on charge indefinitely should be charged at a minimum of 13.8 volts.
    John (Britprius)
  17. Britprius
    5,194
    1,924
    Perhaps we are fortunate in the UK/EU We rarely get prorated guarantees on anything. About the only things I can think of that does are tyres.
    John (Britprius)
  18. PriusCamper
    PriusCamper Senior Member
    13,475
    5,441
    Pacific Northwest, USA
    How many more posts about brand new dead optima batteries are we gonna read before Toyota and Auto parts stores no longer reccomend Yellow top Optima batteries?They are total garbage batteries and the only reason they are popular in Prius is because the hybrid battery does all the heavy lifting in this car... I mean geez... You could take all your batteries out of your kid's toys and duct tape 'em all together and have it run your Prius better than a brand new yellowtop optima made by a company that fired their quality control department to increase profits.
    PriusGuy32 and Britprius like this.
  19. Frank06
    Frank06 Junior Member
    56
    Maine
    DOES Toyota recommend them?
    Nexus 7 ? 2
  20. Patrick Wong
    18,214
    6,530
    No. Toyota would recommend buying replacement 12V batteries from its dealership parts departments.
