Optima Battery Installation
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mike3k, Dec 16, 2008.
  1. mike3k
    mike3k New Member
    Does anyone know of someone in the Fort Lauderdale area who can install an Optima battery and properly dispose of the old one?
    My battery died again for the 3rd time in a month, this time after only one day of not driving.
  2. richard schumacher
    7,663
    1,038
    United States
    You would be wise to find out what's killing the battery before replacing it, lest you kill the new one. Some possibilities: Do you always lock the car, no matter where you park it? Are all of your trips less than 10 minutes? Do you like to listen to the car radio for hours while cleaning it?
  3. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    How old is the battery?
  4. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I believe your car is still in warranty, get on the dealers case, if you havn't been doing anything negligent, the dealer should find the problem and/or replace the battery. Bad 12v batteries do show themselves at various times. But should not within the three year warranty.
  5. maseace
    maseace Prius enthusiast
    191
    Poulsbo, WA
    Were the other batteries you tried the right type of battery for the Prius?
    The Optima battery is not hard to install yourself - when you order it with the Prius kit from eLearnAid.com, it comes with detailed instructions specific to the Prius. Take the old battery to a recycle center or any store that sells car batteries for proper disposal.
  6. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    I've got a whole page about it, which may still help you whether
    it's an Optima or not. eLearnaid's terminal kit will probably
    fit to just about any 12V battery that fits in there.
    _H*
  7. firepa63
    firepa63 Former Prius Owner
    1,761
    208
  8. gussom1
    gussom1 New Member
    36
    SFV
    I just installed an Optima battery in my 05. The installation was fairly easy but you do need to follow the instrauction. Amazon.com is selling the battery for $139.00 free shipping. You will also need the adapter kit that sells for $15.00. Not sure if the change in the battery is doing anything but MPG jumped to over 54 from 47.5.
    Will update after a few tanks
  9. Blinkn09
    Blinkn09 Junior Member
    48
    SoCal
    So amazon ships batteries? Sweet!
  10. Blinkn09
    48
    SoCal
    Is this the battery that you got from http://www.amazon.com/Optima-Batteries-8071-167-YellowTop-Purpose/dp/B00075OSD8? It's the same one from elearnaid right? I'm thinking of getting the battery off of amazon since it's cheaper and coupling it with the kit from elearnaid.
  11. jdenenberg
    jdenenberg EE Professor
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If your old 12v battery was weak, it could have been pulling excessive current from the 14v charging circuit. A 25 amp load at 14v could cost you about 2.5 MPG at highway cruise and more in city driving.
    JeffD
    ps: is it a 51 or 51R battery?
  12. Blinkn09
    48
    SoCal
    I've read on other posts that it is the D51R battery that wouldn't work because of the reversed terminals. So I'm guessing the correct one is D51 battery but I haven't confirmed it.
  13. avocadoman1
    avocadoman1 Member
    217
    36
    Fallbrook-CA
    2022 Prius
  14. avocadoman1
    avocadoman1 Member
    217
    36
    Fallbrook-CA
    2022 Prius
    that's because it's 110 degrees in SoCal today :lalala:
  15. Blinkn09
    48
    SoCal
    Dude tell me about it! I'm glad I just got my windows tinted.
