Optima Battery Problem, warranty replacement location?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JC91006, Feb 23, 2014.
  1. Patrick Wong
    18,210
    6,517
    No. The Optima procedure suggests that you connect a good 12V battery in parallel with the bad 12V battery. The point of that is to increase the voltage visible to the battery charger so that the charger will provide charging voltage to the pair of batteries.
    "Parallel" means that the positive terminals of both batteries are connected together, while the negative terminals of both batteries are connected together. "Series" means that the positive terminal of one battery is connected to the negative terminal of the other. The only reason you would connect the batteries in series is if you needed to produce 24V, which is definitely not the case here.
    Regarding what cables to use, battery jump cables would be OK. The cables only need to carry 10A or less of current.
  2. uart
    uart Senior Member
    4,220
    1,212
    Australia
    What Patrick said about the parallel connection is true, but remember that this customer service tip is only relevant to batteries that have become so far discharged that a modern "smart" charger" can no longer sense enough voltage to detect the battery, and therefore fails to even try charging it.
    This procedure is therefore 100% worthless for any battery that is currently working (albeit at less voltage than you'd ideally like) in the Prius.
    PriusGuy32 likes this.
  3. mycnam
    mycnam Member
    111
    17
    Long Island, NY
    Do you have to pay the return shipping for the battery?
  4. JC91006
    16,924
    8,635
    Yes. The post office has a large flat rate priority mail box that is perfect. About $14
    SM-N900P ?
  5. mycnam
    mycnam Member
    111
    17
    Long Island, NY
    Thanks. I may get one from Amazon then. Although I need to pay tax, I can use up some Amazon gift cards hanging around from last year.
  6. JC91006
    16,924
    8,635
    There's a promotion for a free battery Maintainer this month through optima
    SM-N900P ?
  7. mycnam
    mycnam Member
    111
    17
    Long Island, NY
    Yes I noticed that. See my battery test today.
