Optima battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hoon84lee, Nov 4, 2015.
  1. hoon84lee
    hoon84lee Junior Member
    Fairfax, VA
    this is second purchase of my 05 prius from amazon. First one fit perfectly and didnt have any issue. However i got the second battery recently from amazon again.
    Finally i had the time to install it last weekend, but the positive and negative knob size were way smaller than previouse one.
    Is there any change in recent optima batteries?
  2. JC91006
    16,479
    8,397
    You should call optima's 800 number and ask them
  3. Mendel Leisk
    38,702
    I'm guessing last time around you modified cable clamps to suit larger posts? Or the cables were mod'd before you got it?
    OEM size is the small posts, they're referred to as JIS, maybe. Do you have the old clamps/cable?
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  5. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    Not a good outcome for the Optima batteries. Car 10 years old on it's third battery. Assuming the first battery lasted the usual 4 to 5 years the Optima lasted no longer than the OEM.
    John
    Stevewoods likes this.
  6. Stevewoods
    Stevewoods Senior Member
    648
    990
    Seattle, WA
    John beat me to the same conclusion. And, pair that life with the reports on Optima I have seen on P/C and I think I will stick with the Toyota battery, which, while expensive comes with a few extra perks that one would probably never need, but nice to have anyway...
    • 84-month warranty
    • 24- month free replacement
    • 60-month proration in a two-tiered price plan
    • Coast-to-coast warranty service at more than 1,200 dealerships
    • 24-month emergency roadside assistance/towing and installation labor
    This earlier post by the OP seems to suggest that the cables have been altered from the original.
    replacing battery done! | PriusChat
    #6 Stevewoods, Nov 4, 2015
  7. hchu1
    hchu1 Active Member
    316
    127
    Houston, Tx.
    2014 Prius v wagon
    My experience with the Optima battery lasted just one month outside of the warranty. Got a Exide battery instead , 4+ years now.
