Optima D51 vent tube replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mickey223, Jan 12, 2015.
  1. mickey223
    mickey223 Junior Member
    madisonville
    I purchased the kit to convert to the optima battery 4 years ago for my 08 prius. After a deer vs. car accident, the cars battery completely drained and I had to replace the battery. Since I had the full size post connectors, I purchased another optima D51. Everything was switched out, but the vent tube hole in the new optimus is larger and the plug wont fit.
    Anyone else had this problem? Where can I get a replacement? Searching on the web has not yielded any results on vent tube replacement for optima batteries?>
    Thank you,
    Mike
  2. Britprius
    Britprius Senior Member
    5,194
    1,917
    Herefordshire England
    Optima often tape the adapter between cells on the underside of there batteries where it cannot easily be seen.
    John (Britprius)
  3. mickey223
    madisonville
    No go, took the battery out and nothing there. Weird thing is the old battery had a hole on both sides with a plug on the negative side and the original elbow fit the positive side. Then new battery is solid on the negative side, and has a 10mm hole with a slot at about the 2 oclock position at the positive side.
