Optima Yellow Top Battery Question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Solrokk, Aug 18, 2015.
  1. Solrokk
    Solrokk New Member
    After reading on PC, it appears this is the best battery choice.
    Does this battery still need a modification, or is it's updated version no different than installing an OEM battery? What's the best place online to get this battery? I have a 2008 Prius with SKS.
    I read there are different versions of the optima battery, one for non-sks vehicles and than ones with SKS.
    Any helpful updated tips would be appreciated, thanks.
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    you need to make sure you get the right battery. I got an optima and when I got home I noticed it had normal sized terminals instead of the tiny ones on the prius battery. JIS terminals I think. so I had to replace the battery cable ends too, because the idiots at advance auto didn't have the correct battery and my original one was dead. honestly, the Toyota battery is probably just as good or better than the optima.
  3. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Make sure the Optima battery has vent hole like the picture below. Should be Optima Batteries 8171-767-FFP (DS46B24R). I got my on Amazon
    alekska likes this.
    52,854
    go with the toyota oem, the optima isn't what it once was. the oem now has an 84 month warranty with the first two years full replacement, then pro rata.
    but yes, the correct model optima has the correct posts and vent.
    #4 bisco, Aug 18, 2015
  5. Stevewoods
    Stevewoods Senior Member
    666
    1,267
    where I am
    Follow Bisco's advice...
  6. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    Please elaborate on this point.
  7. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  8. bisco
    52,854
    there have been a lot of complaints of new batteries arriving undercharged or defective. not as many success stories as when they first came out.
  9. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    Classic american business story. Arghh.
  10. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Shop around as sometimes it is cheaper to buy through amazon than through the seller's site.
    I have had no problems with the Optima I bought from elearnaid. Liberty Toyota sold me a crap battery that was replaced under warranty. Liberty's mechanic also broke the positive terminal cap. They offered to replace it but I declined.
  11. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    I'm a fan of the Yellowtops. We have them in two '07s. Never have to worry about them, even when sitting for a week or more.
    Do shop around. At the time, I found a considerable discount from Advance Auto Parts.
    I noticed the DS46B24R seemed just a touch taller than the original. I put a washer or two under the hold-down bracket.
  12. Solrokk
    Solrokk New Member
    That's a shame. Well, I am glad that i asked before making a yellow top purchase. Most of the reviews on the battery were very good, but if it's not reliable as it once was, I guess I'll just go with toyotas battery, which has a discount this month so the battery will cost $178.44.
    I appreciate all the responses in helping this new Prius driver out.
  13. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    About a year ago, I bought an Optima as a replacement for the ten-year-old original, and haven't had any trouble. Installation took more time than it should have, but that was due to discovering a puddle of water in the battery compartment. And, I dropped a nut a couple of times, and of course it fell under the battery...... ;)
  14. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,850
    Hyampom
    Shame, shame, shame, you should have followed my instructions from when I replaced mine and used some white grease on the socket to hold that nut in place (and I stole that advice from a guy that used to post a lot.....dorunron) :p
    kris
    #14 cyberpriusII, Aug 21, 2015
  15. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    You're right, I should have. It would have saved me fishing the nut out - twice. Arrgh - and *then* putting grease on it. But then, I might not have discovered the water problem....
  16. WFBowen
    WFBowen Junior Member
    16
    Southern Calif
  17. akaab
    akaab Junior Member
    FWIW - I've replaced the 12v battery three times on my 2004. The first Optima battery lasted almost two years, but the second went into full meltdown mode after only three months (Amazon purchase). I was on a road trip hundreds of miles from home and had to pull into a dealership for an emergency replacement with an OEM battery. $$$ but it was my only option.
    As someone once said, the Optima isn't what it used to be.
    2004 230k
    Stevewoods likes this.
  18. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Your research needs improvement. There is only ONE size by Optima, made specifically for the Prius (Yellow Top, 38AmpHr). Yes, the initial production of Prius Yellow Tops had the wrong terminal posts, forcing owners to change cables or replace the supplied posts with JIS posts.
    SKS Prius (like yours) came standard with the larger 45AmpHr battery from Toyota. Downgrading to a Yellow Top Optima, you loose 7AmpHr capacity. This 7AmpHr, might be crucial should you leave a door ajar or the map/overhead interior lights on, say overnight, or listen to the radio in ACC mode, for a prolonged period.
    Optima Yellow Top: 38AmpHr, 3 year warranty.
    Toyota Smart Key 12V Battery: 45AmpHr, 7 year pro-warranty
    Bosch AGM Battery (likely made by Exide); 45AmpHr, 4year total warranty, not-prorated; $190 - $40 total promotions going on now at PepBoys
    Exide AGM Battery (FP-AGM51JIS); 45AmpHr, 4year total warranty not pro-rated; $190 at Amazon
    For Convenience and simplicity, just go to a Toyota dealer. You will probably always be near one, and be down a battery for a few hours vs days from shipping back to Amazon or whoever.
  19. EastR
    EastR Junior Member
    85
    Miami, FL
    2016 Prius v wagon
    Any more information on the discount you got? Looking to replace a spotty Optima (now 3 years old) on my 2006 with SKS. Also the exact Toyota part number would be great if you have it handy. Thanks in advance!
  20. Solrokk
    Solrokk New Member
    The man at the parts desk said it was a promotion this month for the battery. I went in there saturday for ATF fluid change, and the man was very nice and printed out a pro-rated discount invoice for me and said they would honor the price whenever I was ready for the battery.
    It was a 15% discount, this is the part number and price on my invoice for California.
    Part No. 00544-21171-325 Net price now: $164.31 for a Truestart battery.
