Optima Yellow Top Battery Replacement
Discussion in 'Gen 2 Prius Main Forum' started by tarheelbuc, Apr 28, 2014.
  1. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    both
  2. TampaPrius.com
    461
    300
    Tampa, Florida
    Next time I get one I will try to take a picture inside the holes on both sides.
  3. fileaudio
    fileaudio Member
    109
    58
    El paso texas
    I have an optima yellow on a Civic hybrid its the same battery that uses the prius? Maybe the size fit but what about the sides plugs? + and - same side?
  4. TampaPrius.com
    461
    300
    Tampa, Florida
    I believe the HCH uses the 51R battery.
  5. fileaudio
    fileaudio Member
    109
    58
    El paso texas
    And the prius wich one uses? Different number and size?
  6. dolj
    dolj Senior Member
    8,634
    4,388
    Wellington, New Zealand
    The Optima part number DS46B24R.
    fileaudio likes this.
  7. srivenkat
    srivenkat Active Member
    596
    93
    IL
    I contacted Exide thru the web contact form and received the following reply confirming the existence of the vent hole and the elbow. Perhaps it vents from only one side and the side you looked in is not the venting side?:
    Good Morning xxxxx,
    In response to your question below:
    Message: I have a question regarding Exide Edge FP-AGM51JIS for the 2010 Toyota Prius. Does this battery come have a vent hole that I can attach the Prius vent tube to? If it does have a vent hole, can it take the OEM elbow that connects the vent tube to the vent hole on the battery or does the battery come with its own elbow? Thanks.
    The Exide Edge FP-AGM51JIS does have a vent port. The battery does come with a vent elbow to connect to the existing vent tube.
    If you have any more questions feel free to let me know.
    Thank you
    Xxx Xxxxx
    OE Product Engineer
    Exide Technologies
    Office: xxxx
    Fax: xxxx
    #27 srivenkat, May 29, 2014
  8. srivenkat
    596
    93
    IL
    In response to my query about vent holes, the rep said all Exide Edge batteries have vent holes on both sides of the battery.
