Optima Yellowtop Breather Tube
Discussion in 'Gen 3 Prius Audio and Electronics' started by tallest420, Jan 15, 2024.
  1. tallest420
    tallest420 New Member
    Chicagoland
    Hello- I have a Gen.3 Prius and I just installed a new Optima Yellow Top AGM Battery (BCI Group Size 24R 450 CCA 46B24R). The Prius breather hose that fit the previous battery doesn't fit properly. It's too small, thus doesn't fit snugly and falls out. I was wondering if there's an aftermarket part that'll make the too-small hose that doesn't stay in the battery to stay in there. I understand the breather hose is "just for the lawyers," etc. but I'd really like that little thing to stay in the battery properly. (without duct tape) Any help?
    52,819
    you have the fitting at the end of the hose?
  3. tallest420
    Chicagoland
    Yep. It’s on there. Just doesn’t fit in there nice and snug.
  4. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    I replaced a 12V in my 2011 with a Yellow Top. The fitting in question is, if I remember correctly, a 90 degree elbow with the end that inserts into the battery vent port keyed to insert and then turn to a locked position. What I don't remember is if that fitting was the OEM Toyota one or something that came along with the new battery. I am certain though that the elbow is inserted into the keyed battery port and then rotated probably clockwise a quarter turn or less to a locked position.
  5. bisco
    52,819
    It’s interesting, because I don’t recall anyone ever mentioning it as a problem , and there have been a lot of yellow tops installed over the years.
    Maybe a call to them?
  6. Mendel Leisk
    42,315
    My yellow top vent works ok with the stock vent tube connection. It was purchased in September of 2015 though; could be something has changed in the interim.
  7. tallest420
    Chicagoland
    The elbow is connected on the tube still & it fit the Bosch battery that was removed nice and snugly. It just doesn’t fit the same in the Optima. It’s a loose fit, like the elbow needs to be bigger.
