Optimal Cell Phone Placement
Discussion in 'Prius c Main Forum' started by RichV, Feb 24, 2021.
  1. RichV
    RichV Junior Member
    Decatur TN
    Is there an optimal place to put a cell phone for navigation?
    Where do you put yours, and what holder are you using? I love the magnet holders, but am new to my 2013 Prius C. I did a quick search and nothing came up in this forum, so hopefully it will be beneficial to others as well.
  2. grayfox
    grayfox Junior Member
    Wisconsin
    I have a 2012 Prius C. I bought this on Amazon:
    Mpow Car Phone Mount, Dashboard Windshield Car Phone Holder with Long Arm, Strong Sticky Gel Suction Cup, Anti-Shake Stabilizer Compatible iPhone 12 11 pro/11 pro max/XS/XR/X/8/7,Galaxy, Moto and More
    You can place it as you want - but I have it snaked around the right side of the radio. I don't have the large display that I see yours has. You may be able to figure out a way to place it.
  3. topshot
    topshot Member
    141
    56
    Midwest
    2015 Prius c
    I'm using a holder that sticks in the CD slot, which also works for the standard size Gen 3 Prius.
    Steves895 likes this.
  4. Steves895
    Steves895 Member
    48
    68
    Concord, NC
    I am also using a phone holder that fits in the CD slot and I find it works great for navigation
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,780
    2017 Prius c
    "Optimal" probably would be on the dash, about the middle of the windshield.
    But that isn't a good place because it might block your view.
    We haven't had any trouble with phones located anywhere inside the car........most often sitting in the cup holder.
    Try it and see.
  6. topshot
    topshot Member
    141
    56
    Midwest
    2015 Prius c
    I guess I didn't fully answer the OP. "Optimal" to me is as high as possible without obstructing any portion of the windshield or dashboard display. Mine does block a portion of the console display and a center vent, neither of which is a concern to me.
    There are some dash-mounted ones that would likely work fine, but I didn't want to permanently fix something to my dash though.
    I suspect you could also do a suction-mounted one to the tiny window on the side. Those seemed more expensive and more likely to fail over time as the cup is exposed to UV and temp extremes.
    Almost all cupholder ones I've seen require you to look down too far. That would certainly be true in the c unless the holder had a really long "neck". It's not as bad in the Gen 3. We also use the cupholders so it's not an option I've considered anyway.
    I'm not sure how true vent-mounted ones remain stable. The one from Proclip isn't attaching to the actual vents. It is likely the best overall mount, but you pay a high price for it, too. Thus, I went with the CD option. (y)
  7. RichV
    RichV Junior Member
    Decatur TN
    Thanks for the responses, I completely forgot about cd-mounted ones, to me that looks like the perfect placement, so I opted for this one at Amazon: Bestrix Magnetic (Amazon Item B01KT786O0 ), should be arriving tomorrow. I've had the windshield and dash mounted gels before (On windshield they eventually melt, on dashboard they become permanent fixtures)
  8. sam spade 2
    7,035
    2,780
    2017 Prius c
    Well yes BUT he specified "for navigation".
    In my opinion, the ONLY safe way to use a nav application is with voice prompts only.
    I never look at the screen while moving; well almost never. :)
  9. StealthMode
    StealthMode New Member
    PA, USA
    I have mine mounted directly behind the steering wheel where the speedo would be in most cars. Means whatever navigation I have can be looked at with a quick glance.
  10. Peter Danlyn
    Peter Danlyn Junior Member
    Here's mine. And I can still move the vent slightly up and down. Don't have to take my eyes off the road and easy reach.
