Optimum Highway Speed
Discussion in 'Gen 4 Prius Fuel Economy' started by Zardoz, Sep 22, 2017.
  1. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
    In Pennsylvania, USA most of the company owned trucks are GPS limited to 69mph. Private owner/operators don't seem to have that same restriction.
  2. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    Excellent point, and some states have a lower speed limit for trucks. I have friends, with perfectly healthy cars (including the Prius), that insist that they cannot get good gas mileage. I'll offer to take a ride with them on the freeway, with the condition that they follow an 18 wheeler without passing it. The driver will go crazy as the 18 wheeler will avoid braking and quick starts at all costs. At the end of the round trip, my friend will see good mpg. He'll also be extremely frustrated from driving slower and unable to accelerate hard for an hour- and will often return to the driving style in the fast lane that results in lower mpg.
    That's why I've always suggested for people, struggling to increase their mpg, to follow huge trucks. The independent operators are even better, because they have to pay for their own fuel costs and this has a huge impact on their profit margin.
    pjm877, Tande, Tyfly and 4 others like this.
  3. Tideland Prius
    16,631
    Not to mention paying less out on maintenance as brake pad wear will be slower (on non-hybrids anyway) because they're not accelerating then having to brake to adjust their speed again.
    fuzzy1, pilotgrrl and RCO like this.
  4. Mendel Leisk
    42,048
    Not trying to be trite, but I don't understand the question. "Optimum" means, well I'm not sure what.
  5. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
  6. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    Around here, I don't mind following semis on the tollways. It's LDA (Loony Detection & Avoidance), more than anything else.
    If the posted speed limit is 75, it seems the natives will push it to 90.
    Tideland Prius, kithmo and RCO like this.
  7. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    That must be everywhere grrl!!!
    pilotgrrl likes this.
  8. KV55
    KV55 Member
    126
    43
    Northamptonshire, UK
    Excel
    I will second the mention of 52mph, not sure on the actual mpg achieved at this speed but yesterday in good conditions it looked like around 90mpg UK. I was busy using warp stealth but having set the multi screen to the hybrid system energy arrows I saw this speed on a flat dry road gave direct drive, ICE to wheels only, no EV. With the Gen 2 this used to be 47mph and it would give 75mpg UK.
    DLC82SV and RCO like this.
  9. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    My goal is get 60 MPG on my trips. I don't always achieve it but I try. I have found that in no wind level conditions, 65-70 MPH will yeild 60 MPG if I apply basic hypermiling techniques. Any hill or headwind will give a lower result.
    A big adavantage on the gen 4 is the ability to glide up to 72-74 MPH. This allows for P&G (pulse and glide) in the 65-70 MPH area.
    Over 74 MPH my MPG is reduced, as the ICE (gas engine) constantly turns.
    Note: Generally, with the cruise control engaged above 65 MPH, the ICE will not turn off. This significally reduces MPG.
    #29 bestmapman, Sep 25, 2017
  10. benkhanobi
    benkhanobi Member
    123
    50
    SW Florida
    Back in the mid 80's I owned a Chevrolet Chevette diesel/5speed. It always got 45-50mpg. On a trip to Florida I got stuck in 150 miles worth of slow lane 50 mph road construction ( they were adding that 3rd lane on I-75) and after 3 hours or so of 40-50 mph I needed a pit stop. I fueled up and checked my mileage= 62 mpg. Keeping it under 50 mph sure made a difference
    Tyfly, krmcg and RCO like this.
  11. Zardoz
    Zardoz Member
    86
    52
    Show Low, AZ
    It sounds like THIS is the info I was looking for! "Over 74 MPH the ICE constantly turns".
    Thanks for this tidbit!
    DLC82SV likes this.
  12. bestmapman
    1,289
    242
    Check pg. 120 of the 2017 owners manual.
    "EV indicator *2, 3 (This is on the Hybrid System Indicator display)
    The EV indicator comes on when the vehicle is driven using only the electric motor (traction motor) or the gasoline engine is stopped."
    The green EV indicatior (on the Hybrid System Indicator display) is what I use to know when the ICE is stopped. You can get the ICE to turn off very easily by letting off the accelerator pedal for a moment. The green EV light will come on, then come back on with the accelerator pedal gently until the bar disappears. That is the glide position in the pulse and glide maneuver.
    The 74 MPH figure is what I have observed. It is not in the owners manual.
    #32 bestmapman, Sep 26, 2017
    RCO and pilotgrrl like this.
  13. first_superior_prius
    76
    115
    Michigan
    Can't believe nobody's posted the chart from CleanMPG yet
    highker, pjm877, Tyfly and 5 others like this.
  14. Mendel Leisk
    42,048
    ^ This is why I don't understand "optimum" speed. It's really a matter of picking your poison. There's a very linear correlation between speed and mpg, no flattening out sweet spots in that graph. FWIW we stick to secondary highways wherever possible, 50 mph max.
    Tideland Prius, RCO and fuzzy1 like this.
  15. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Mendel is right, but for me a quicker journey over a couple of hundred miles is more important occasionally...
    .. OK, most of the time! :cool:
  16. bestmapman
    1,289
    242
    Original post was
    Good point. Just what type of optimization. Speed, fuel ecomony, ride, etc..
    RCO, Mendel Leisk and pilotgrrl like this.
  17. Tyfly
    Tyfly Member
    65
    94
    I live near the DFW and can vouch for the poor driving. Speeding, tailgating, not signaling, it's no surprise our insurance is so high! Sorry to get off topic here!
    pjm877, RCO and pilotgrrl like this.
  18. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Thank goodness that doesn't refer to the sky above DFW. Yikes!
    pilotgrrl and Tyfly like this.
  19. bbald123
    386
    275
    Harrisburg, PA
    I call BS on the chart unless they are talking Imperial Gallons. I get nowhere near 78 US mpg at 50 mph
    Threej, pilotgrrl and RCO like this.
  20. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Whoa! You mean there's another gallon out there in the wild West?
