Orange engine light and orange triangle on due to pulling and replacing under dash fuses
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jack 84, Jul 23, 2026.
  1. Jack 84
    Jack 84 New Member
    iowa city
    My engine light came on after I was testing for what circuit was causing a persistent cherp sound. In order to find the under dash fuse I left the accessory ignition on so I could hear the cherp sound. Now the warning triangle and engine light will not reset. No warning lights were on prior to this attempt and car was running fine. I'm wondering if there is a do it yourself way to reset. Any thoughts?
    Tombukt2 likes this.
  2. ChapmanF
    19,034
    The best way I can think of is the usual way: find out what codes the lights are telling you about first. Your activity might have caused one of the ECUs to think some kind of condition exists, and when you know what it thinks is happening, you have the best shot at resolving it.
  3. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    Read the codes then clear them I guess you're saying you don't have a scanner in this day n age man.
  4. Jack 84
    Jack 84 New Member
    iowa city
    Thanks for the suggestions. Google AI seems to have solved the warning lights problem. Disconnected the 12 V battery, 5 min wait, reconnect, warning lights reset. I still have the persistent 1.8 sec chirp inside the cabin whenever the ignition is On and about 5 chirps after shutdown. Like trying to find a chirping cricket. AI hasn't been able to solve that issue which likely means an expensive visit to the dealer.
