Orbital debris reentry
Discussion in 'Environmental Discussion' started by tochatihu, May 7, 2021.
  1. tochatihu
    tochatihu Senior Member
    9,975
    3,847
    Kunming Yunnan China
    2001 Prius
    In an EV thread, orbital debris is discussed. This re awakening might be more appropriate.
    It may seem paradoxical that increased CO2 in atmosphere could extend debris durations (lifetimes seems like the wrong word). It works like this: Troposphere heats, leaving less outgoing infrared. Then stratosphere cools (those parts are well studied). Stratosphere contracts, allowing the (further out) thermosphere to contract. At any given altitude thermosphere becomes less dense, so debris gets less frictional slowdown, and persists for longer. That increases probability of bumpercars.
    All of that is counteracted by solar charged-particle fluxes. Notably when sun has lots of spots. Those have an opposite effect on thermosphere. Low earth orbit cleans itself a bit better of debris.
  2. ETC(SS)
    7,534
    52,832
    Maybe the asteroid that is going to hit us will solve the problem
    Trollbait likes this.
  4. tochatihu
    9,975
    3,847
    2001 Prius
  5. frodoz737
    frodoz737 Top Wrench
    4,798
    2,560
    33
    But...wouldn't it just bounce off the pollution? :rolleyes:
    #45 frodoz737, Mar 14, 2025
  6. bisco
    52,832
    that would be someone trying to dive into the seine
  7. tochatihu
    9,975
    3,847
    2001 Prius
    https://arstechnica.com/space/2025/11/landing-postponed-for-chinese-astronauts-after-suspected-space-debris-strike
    China's Tiangong orbital station has 3 on board who won't be re entering just yet. Their downgoer seems to have been hit by orbital debris and may not be fit for that purpose.
    I would have thought that another 3 would go up and replace then but apparently that was not the plan. Instead if the re-entry vehicle not used, another rocket will send one up uninhabited.
    There may be some irony in this. Space-launch nations have contributed unequally to the amount of orbital debris, and this nation has contributed quite a lot :eek:
  8. bisco
    52,832
    what we need is a uge magnet, like the one on the front of bwilson's car
    hill likes this.
  9. tochatihu
    9,975
    3,847
    2001 Prius
    Most orbital debris is not ferromagnetic Encountering schnutz with high relative velocity could disassemble a Wilson magnet, so this is not a great plan, sorry.
    Ars article linked above says that Taikonauts' 4 EVAs have been to add shielding against highly energetic little bits. Maybe it could not be launched with enough wrapping / shielding. Or risk from damage from such was underestimated? Talking here about not the most 'transparent' space agency.
    It is also well to note (again) that <1 cm orbital debris are not trackable from earth surface. By any disclosed way.
    I reckon that 3 current Taikonauts will over stay their planned 6 months by not much, and that they have adequate oxygen, water, food stores on board to wait it out. I reckon that this inconvenience won't figure highly in media reporting - there is so much else to talk about!
  10. fuzzy1
    10,705
    One fairly effective method for small bits seems to be a layer of thin foil, or multiple such layers, with significant gaps between each and the vessel shell. The high speed bit and the piece of foil it hits first are all vaporized on contact, the plasma spreads out in a cone before it reaches the next layer, where it hits a much wider (and more mass) impact zone with less penetrating power, getting slowed and spread even more. By the time this hot gas cloud reaches the vehicle's pressure shell, it is much less able to puncture it.
    This sort of structure is too light and fragile to withstand the atmosphere and wind of a ground launch, so must be either behind a fairing, or deployed in orbit. Might the space agency be installing something such as this?
    A 1 cm impactor will blow through this structure and not vaporize much until hits something much heavier. Though a similar concept, of heavier layers and wider gaps, might do the job.
  11. fuzzy1
    10,705
    Actually, a number of asteroids have been calculated at 100%, first in 2008, then 2014, now numbering several per year. Impact warnings have all been under 24 hours, some as short as a couple hours. So far, all these have been of nice fireball size, nothing approaching the Chelyabinsk event, just gnats compared to 2024YR4.
    Here is a list of them:
    List of predicted asteroid impacts on Earth - Wikipedia
    These were detected late because they were so small. Larger ones can be detected from farther away. The intent of the search is to find and catalog as many of the dangerous ones as possible, as far in advance as possible. As the equipment improves, the detection rate of the small ones keeps increasing, while finds of new large ones keeps shrinking, statistically suggesting that most of the large ones have already been found. But plenty of mid-sized ones, still hazardous, remain un-discovered.
    #51 fuzzy1, Nov 5, 2025
  12. tochatihu
    9,975
    3,847
    2001 Prius
  13. tochatihu
    9,975
    3,847
    2001 Prius
    Potential collision risks of debris with low-Earth-orbit (LEO) satellites are promulgated by Leo Labs among others. Satellite operators nudge their items further from harm by expending fuel. This happens a lot and is what onboard fuel is for (besides finally aiming re entry towards Point Nemo). Links below consider situations if solar storms prevent satellite operators from nudging:
    2.8 Days to Disaster - Why We Are Running Out of Time in Low Earth Orbit - Universe Today
    [2512.09643] An Orbital House of Cards: Frequent Megaconstellation Close Conjunctions
    This study has not yet been peer reviewed. I (always) mention that because as a journal peer reviewer, I consider it an important part of science.
    Trouble with orbiting satellites can arise in various ways. Undetected (because too small) debris can damage satellites. Satellites can be nudged away from detected debris when everything works well. This new study considers another situation if solar storms interfere.
    LEO is 160 to 1600 km up there, and is by far the most populated now. Geosynchronous orbits are 35786 up there, and other satellites are at intermediate altitudes. These high orbit regions have much larger volumes and have much less stuff that could come into contact.
    If the dreaded Kessler Syndrome occurs, it will begin in LEO.
    Not only Starlink has plans to further populate LEO, and this is where bad times could happen.
  14. ETC(SS)
    7,534
    Almost as bad as times would be if we had zero mass in orbit? ;)
    I'm fairly satisfied that even though SpaceX's CEO actually shook hands with Hitler that they are not only abiding by the 21 measures adopted by COPUOS but they are making a good faith effort to make their satellites less bothersome to the star-gazers of the world which is probably the REAL motive for the recent additional "LEO Sustainability" concerns 'else, WHY bother with the latest "population bomb" crisis?
    Starlink has some 9K satellites in their constellation with stated plans for over 40k. They use multiple orbital shells from roughly 200 miles to 350 miles. They seem to be using the lower 'altitudes' for direct-to-phone ops.
    They have a POWERFUL incentive to be LEADERS in "LEO Sustainability" not only because they have to play 'Asteroids - 2026' to avoid losing satellites, but getting a satellite negated by a skin-to-skin kill is.......messy.
    It results in zillions of ADDITIONAL orbital debris, all clamping along at orbital SPEEDS which can result in additional satellite negations.
    Lather, rinse, repeat.
    For the 'math challenged' in the room.....they call it 'space' for a pretty good reason, but people who are USING space to make money may actually have a much more powerful incentive to use it wisely than entities who do NOT have to worry about profit and loss.
  15. fuzzy1
    10,705
    Back when we zero mass in orbit, weather events such as what my Pacific Northwest region has been experiencing the past ten days, would kill large numbers of people. Before eyes were placed above the Pacific Ocean, these major events arrived without warning.
    History shows many CEOs more focused on short term results than long term. If the long term implodes, they already have a very good pot of gold.
  16. tochatihu
    9,975
    3,847
    2001 Prius
  17. fuzzy1
    10,705
    These "orbital shells" are not defined or enforced in a manner similar to electron orbital shells. Plenty of other satellites cross multiple or even all those "shells", and debris clouds from strong collisions will not be bound to particular "shells".
  18. tochatihu
    9,975
    3,847
    2001 Prius
    I do not favor an analogy with electron orbital shells. Electrons' locations are Heisenberg-unknowable for being so tiny. Locations for every orbiting item is knowable, but with (many) <1 cm bits evading current radar tracking.
    " ... debris clouds from strong collisions will not be bound to particular "shells"." First may we remove that word 'strong"? There may be few or no weak collisions up there.
    Years ago I read about on-orbit collisions sending debris into elliptical orbits. Thus some go down and into atmospheric drag. Other go up and may cause trouble in higher orbits that are so far cleaner.
