Original 12v battery?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PA Prius, May 27, 2020.
  1. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    NO. Way PAST TIME.
    kenoarto likes this.
  2. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    I replaced it this afternoon. $231.71 + tax. OEM from Toyota. I was right, it was only 75% charged and filled up to show 14.2 miles. More recently it has maxed out at 9.8. I drove 11.5 very cautious miles now before the ICE came on. 40°, snow tires, max 45 mph. I want to believe it went a bit further than what it has the past month or two, but that is probably not the case.
  3. Mendel Leisk
    42,271
    You’re talking about your plug-in Prius hybrid battery displayed charge, and range estimate? Not sure that correlates to the 12 volt battery replacement. If you didn’t use a memory saver during the replacement the displays will revert to defaults if I’m not mistaken; that could be what you’re experiencing.
    kenoarto and PA Prius like this.
  4. PA Prius
    762
    251
    SE Pennsylvania
    Mendel Leisk, exactly. I had read on some other threads where at least one person was claiming to get more actual miles after dis- and re-connecting his 12v battery and so does that occasionally. That would be nice, but I don't think it is the case.
    Yea Right and Mendel Leisk like this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    I guess so!
    PA Prius, pghyndman and kenoarto like this.
  6. DonJa
    DonJa Junior Member
    Montana
    2013 Prius Plug-in
    Is the 12V battery on a 2013 PIP sealed or should I be checking the levels?
  7. Mendel Leisk
    42,271
    The stock battery is an Absorbent Glass Mat style, not readily fillable, and I don’t think necessary either.
  8. DonJa
    DonJa Junior Member
    Montana
    2013 Prius Plug-in
  9. DonJa
    DonJa Junior Member
    Montana
    2013 Prius Plug-in
    Good to know. Thanks! 2013 0nly has 45K miles and not driving a lot since working at home.
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    IF......it has the original battery, you are likely due for a replacement.
    7 years is a good run but it won't last forever.
    Especially if not used much.
  11. jerrymildred
    11,517
    14,164
    Tampa, FL
    Un-checkable and unfillable except maybe with a syringe through the vent. Maybe. I cut open a dead AGM battery from a UPS one time. No lead plates and no liquid acid (or any other liquid) came out of it.
  12. sam spade 2
    7,035
    2,804
    2017 Prius c
    That is a misleading statement.
    AGM is just a special variety of a lead-acid battery.
    There IS lead and acid in there. Has to be to work.
  13. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    410
    2013 Prius Plug-in
