Original Prius 2010 commercial #1 (blue man crew)
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by SyCo, Dec 11, 2008.
  1. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    btw, if you look at instrument cluster, you see mph engraved there... HUD would never be only option for mph, just additional option.
    As 2010 RX is getting HUD then it makes sense than Prius is getting one too...
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Sorry, I meant the height of the car is lower / shorter. Just compare the roof lines between the two.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Ah...I see what you meant.
    I think the only hesitation I have there is that we can't be certain that the height/width ratios are the same for the compared images...those videos looked pretty distorted.
  4. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    After looking back, the current iconic Prius wheels don't look round.
    I made another comparison and the wheelbases are about the same. I think I have spent enough time on this.
  5. ManualOnly
    ManualOnly New Member
    193
    28
    A little history recall in that one of the many "concepts" 3-gen Prius that we had seen in the past, one has an uncanny resemblance.
    Notice the angular-tail light and slicker overall.
    Source: Imagine the 2010 Toyota Prius - Inside Line
  6. efusco
    19,891
    1,196
    Nixa, MO
    Indeed you're right...even the headlight/front end are remarkably close...and that taillight assembly is VERY close.
  7. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    The new one looks more sporty. I can't wait to test drive it!
  8. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    usbseawolf2000,
    Thanks for all the work. Maybe I can induce you to continue a bit longer...
    I found the direct comparison pix most interesting. In fact, they lead me to
    an as yet unexplored line of considerations:
    Would anyone care to comment on the probable frontal area and Cd? The
    reduction of the break angle between hood and windshield could be
    meaningful. As could be the generally smoother curve from front to rear
    with the reduced humpiness of the roof and the flatter run aft of the high
    point.
    Also, of what purpose was the sequence with the "boomerang?" -- I kept
    waiting to see if it came back and, you guessed it, hit one of the BMG on the
    head, a cosmic dope slap. Boomerangs "work" on aerodynamic principals.
    (Help me here patsparks!) Is there meant to be a suggestion that the rear
    spoiler is especially aerodynamically significant given that it appears the
    roof line at that point is higher than the GenII?
    Has anyone found any other apparent aerodynamic/cleanliness elements?
    [Edit] I wonder what happened to the radio antenna(s, or is that "ae")...
    in the rear hatch glass? Or perhaps just omitted due artistic license.
  9. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Very interesting... Gotta look up any connection between the boomerang principle and the new Prius.
  10. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    It turns out the boomerang works because of the Bernoulli's effect.
    I found a cool video that explain how such effect can lift the airplane to fly. That's got to do with the shape of the Prius but not how it arc in the tail.
    YouTube - airdynamics
  11. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    usbseawolf2000,
    OOps! Sorry, I think I may have sent you off on a wild goose chase. I don't
    think the mechanics of how the boomerage flies/comes back is the
    message...
    That would more likely be the dope slap on its presumed return saying in
    effect, "It's aerodynamics, dummy." The question then becomes, Just what
    is the relevant or special aerodynamics in play at/around the new spoiler.
    FWIW, here's one of the many results from Googling, "How do boomerangs
    work?"
    Boomerang Physics - The Naked Scientists January 2008
  12. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
  13. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    usbseawolf2000,
    As I live and breathe, that is one unworldly cool simulation.
    You're The Man!
    I hesitate to ask, but I must... can you do one for the Gen II so we can see
    what it's airflow/pressure patterns look like? By comparing the two, perhaps
    we can see the result of improvements, if not the improvements themselves.
    [Edit] The second one is even better! Well done.
    [2nd Edit] I can't get over that simulation. It even shows counterflows behind
    the car as the simulation proceeds towards steady state conditions. I love it!
    I take it that velocity is one of the input/initial conditions. What are you using?
  14. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I plan to do Gen II (iconic Prius) as well as the Insight II and the Volt! If not tonight, more will come tomorrow.
  15. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Go git 'em tiger!
    Many, many thanks.
    I know this is outside the scope of your investigation: at 2:32 in the BMG
    clip, you can finally see the arc of the roof from side to side. There doesn't
    appear to be the weird cenerline flatness that the Gen II has -- thought by
    some to induce counter-rotating, drag reducing vortices.
    Lastly, I've looked more closely at the "boomerang" sequence. The action is
    of throwing something away. Possibly a reference "throwing away the book"
    on aerodynamics? Or maybe even more subtlely, "prius" means goes before.
    But a boomerang comes back to where it began its flight. The messaage
    then is something there is not a rehash, not a gimmick, but something
    entirely new.
  16. patsparks
    10,664
    567
    Adelaide South Australia
    Using science which dates back 40,000 years the boomerang and the Prius share aerodynamic qualities. Now I have a Prius, I don't need this boomerang.
    Moving forward, it doesn't matter if you understand how it works, the boomerang comes back, and the new Prius, just like the old one, just works.
    In reality I thought it was just put in for a laugh.
  17. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    I agree, that flow simulation is the coolest thing I've seen in a while!!
  18. bwilson4web
    16,196
    Here's your tractor beam:
    As for photon torpedoes, well 50 cal will do:
    Road rager, Huntsville style.
  19. bwilson4web
    16,196
    Thanks!
    What we need now is both the NHW20 and NHW11, which has a slotted spoiler with a vortex generator on the underside of the spoiler.
    One of my first efforts was an attempt to measure the after body vortexes. Now I'm inspired to go back and complete the experiment.
  20. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    Is it possible that THAT'S the "Night Vision" button?
