Original Prius 2010 commercial #1 (blue man crew)
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by SyCo, Dec 11, 2008.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I just added the Iconic 04-09 Prius Aerodynamic video in my post #132.
    The Icon Prius tail points down while the 2010 Prius tail is pretty much level flat. Other than that, there isn't much difference.
    BTW, I use this free online tool to make these videos.
  2. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Ok, I will do the Classic Prius next. I need a clean side view pic of the Classic Prius. I googled the image it but did not find the one I am satisfy with. If anyone can PM me the link or the pic, it will definitely help.
  3. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    What type of radar are the auto manufacturers using? The reason I ask is because I hope it doesn't interfere with my radar detector, and I'm sure the police agencies are just as concerned that it doesn't interfere with their equipment either. :mod: :confused:
  4. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    they way things work, they would be on different frequency than your police radards, everyone got their piece of the spectrum... otherwise they would be forbidden to sell it.
  5. spwolf
    3,156
    440
    Eastern Europe
    that particular button is radar distance control... night vision is button on the side of the steering wheel on crown hybrid (on dash, like mirror buttons)... Avensis wont have it though so I am not sure if Prius gets it... I mean radar distance control+line keep is quite expensive, not sure if people want Prius to become even more expensive :)
  6. Rybold
    2,760
    322
    Southern California
    Aerodynamics? Aptera wins that award.
    I thought the boomerang was an allusion to the hybrid synergy drive. You throw the car forward with the accelerator, then you recapture the energy back with the regenerative braking. :D
    I sure hope you are talking about accident prevention and not cruise control. If they coupled radar distance with cruise control, the statistics of people falling asleep at the wheel would skyrocket. How lazy are people, anyway? If I was the head of the NHTSA, I would call for a ban on such functionality. For accident prevention though, it is an excellent life-saving technology.
    Oh, and fyi: I though "photon torpedoes" referred to flashing your brights at someone. Isn't that what was implied by that?
    (how about a device that detects an imminent collision from an irresponsible SUV driver, and fires a missile at them?) :D
  7. bwilson4web
    16,196
    OWCH! I have to scamper off to work. When I get home tonight, I'll take my NHW11 to the side of building with light colored wall and take a photo. I'll trim it down into a "white background" and "black body" including the slotted spoiler.
    I look forward to adding some tuft testing and other techniques to actually photo graph the air flow and compare to the model.
    BACKGROUND
    When I first got my NHW11 Prius, I soon learned there was a terrific mileage hit at ~70 mph. At 65 mph, I get 52 MPG all day long but 75 mph drops it to 39 MPG. My first hypothesis was flow separation. Later I realized the problem is in part the MG1 rpm limitation that forces the engine to run faster than idle at all speeds. This also combines with the bad habit of going into poor BSFC regions. So I put aside my aerodynamic studies.
    Now I'm interested in completing those studies to compare an aerodynamic model versus the actual vehicle. I'm not expecting any great revelations but I would like to submit two outlines, one showing side skirts and an air dam.
    THANKS!
  8. spwolf
    3,156
    440
    Eastern Europe
    you need to read a bit about radar cruise controls... basically it slows and speeds up your car according to traffic. I dont see hows that any worse than normal cruise control - in fact it is a lot better.
    However it will not work without cruise control... it will not slow down your car unless you have it and cruise control activated.
    Pre-crash system will do its thing regardless but precrash will not slow down your car, just prepare it for the crash :)
  9. patsparks
    10,664
    567
    Adelaide South Australia
    Pre-crash, sounds like a crash is inevitable once it starts working.
    Should it be collision avoidance?
  10. spwolf
    3,156
    440
    Eastern Europe
    thats what radar based cruise control is... pre-crash is when crash is going to happen :)... it tightens your seat belts, closes windows/sunroof, boosts brake assists and ESP so they will react much quicker, things like that.
    radar based cruise control will slow your car down if someone stops in front of you and things like that.
    lane keep assist will warn you when you are going into different lane, and make slight adjustments so going back to the lane will be easier.
    VSC+ is VSC/ESP on steroids, which also makes slight power steering adjustments so you will fell what is better way of turning your wheel to get car under control.
    Quite few modern systems in there, all state of the art - precrash and radar cruise control in this form were introduced less than 2 years ago with LS... and this is improved system.
  11. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    The 'VSC+' here is called VDIM, a linkage to the EPS as you explained. The TCH and the HH both have it now.
    The Avalon here has had the Radar Cruise Control for several years now as well.
    None of the Toyota's have the Accident Avoidance nor Lane-Keeping technology...yet.
  12. Tideland Prius
    16,549
    No kidding. It's an expensive option on the ES350 sold in the US (radar cruise control and PCS cost as much as the navigation/backup camera option). It's also a special-order option as not many dealers stock cars with that option. I'm thinking that if it does get offered, it'll be a US option and will not be offered in Canada. Very few cars up here have a PCS-type system.
    In addition to what spwolf said, A-PCS (Advanced Pre-Collision System) has a forward facing camera to complement the radar so the computer can get a better idea of what's in front and can also:
    • stiffen the front suspension
    • bring the brake pads closer to the rotors
    • quicken the steering ratio
    • warn you if you're not looking ahead (with a rearward facing face detection system)
    It also has a rear-facing radar to detect incoming vehicles. It's linked to active front headrests that pop up and bring the headrest closer to your head (if it's not touching it already) in preparation for a rear-end collision.
  13. spwolf
    3,156
    440
    Eastern Europe
    there are 2 different systems - VSC+ and VDIM, for some reason Toyota is not calling them the same. New Rav4 and new Avensis got VSC+...
    As to the radar, few newer Toyotas have it as expensive option, but only new Avensis is coming with the latest version which i guess Prius will have, and that is actually cheaper because they expect it to sell to wider audience.
    It will be standard at higher spec Avensis, which will probably bring the cost of system down. It sure helps that new EuroNCAP regulations mandates for cars to have such system available if they are to get 5 stars rating.
  14. Tideland Prius
    16,549
    Question:
    Do you think for a moment that maybe that forward facing camera above the rearview mirror is actually for the automatic high beam feature found on the new Venza?
    Cause if that's for the PCS, that means Toyota is going to put the A-PCS that's found only on the Lexus LS460/600h L (in North America). That seems a little too fancy for a car that's for the masses.
    So my thinking is that it's for the automatic high beam (and I wonder if that goes for the sneak peek that we all thought was a HUD display camera).
    Now, I think it's not a necessary feature (kinda redundant really but there are ignorant or just plain stupid folks that have their high beams on for no apparent reason).
    What sayest thou, Prius Team?
  15. Rybold
    2,760
    322
    Southern California
    Okay, I immediately see your point. Thank you.
    In response to the second quoted paragraph: Actually, some of the newer systems from BMW and Mercedes apply the brakes if a rear-end collision is imminent. One of the demo commercials shows a vehicle following another vehicle and the vehicle in front has slowed but the driver in the back is either distracted, not looking, or fell asleep for a second or two, and the vehicle automatically applies the ABS brakes once the vehicle is within a certain distance from the car in front. It's a last attempt effort. The video shows the vehicle stopping just inches away from impact. This system is either brand new, or will not be available until the 2010 models.
    I assume it also works with brick walls and cows. :D
  16. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Remember, the Prius had voice activated nav, BT phone, SKS (aka smart-start/smart-entry when it came out), and VSC, all in 2003 when only one or two other luxury vehicles had those features available. If the Prius is still their "To Go Before" vehicle it would surprise me not at all that they keep the technology at the cutting edge.
  17. patsparks
    10,664
    567
    Also remember the fully optioned Prius may not be the car you choose to park in your garage due to the price of the options. Just because you think a range of accesories will raise the price beyond what you are willing to pay does not mean no one will be willing to pay the price.
    The price difference here between the standars Prius and the iTech (top if the range of 2 trim levels available) is $9000AU or about 25% of the price of the standard Prius.
    In the US you can pay MSRP of $22,000 for a basic Prius up to $29,000 for a fully optioned Touring Prius package #6 or an increase of about 33% so there is plenty of room for a basic to full range of options 2010 Prius.
    I'd love to see what we will be able to buy in Australia.
  18. spwolf
    3,156
    440
    Eastern Europe
    Prius will get more advanced system than PCS in LS600h.... It is simply newer version of the system that also integrates like keep assist/warning.
    We already know it is coming for Avensis, and same system will be in Euro prius (again for EuroNCAP 5 stars reasons).
    It is simply newer technology, introduced this year on new Crown...
  19. spwolf
    3,156
    440
    Eastern Europe
    yes, but only if radar cruise control is on - it will not slow down by itself without it being on... it could cause crash if you were just driving fast.
    And of course, Toyota had first version of the system on actual sale in LS430 (MB advertised it buy you could not buy it)... that first system could slow down up to 40km/h. Then latest S600 got system that could stop completly, and LS460 got the same system.
    Now latest systems also integrate line keep/change system, so what Prius will get is the latest tech that just came out on high end Crown Hybrid in Japan.
    LS will probably get updated at the facelift, as will every Toyota in Europe when it is redesigned as no car will be able to get 5 stars without such system.
    And in Europe, 5 stars crash protection is pretty huge deal. New system comes in place in 2009, and pretty much makes manufacturers integrate pre-crash system into their cars, as every good older car already got 5 stars... so it is bad advertising that your new Golf got 4 stars while old one had 5, even though new one is more secure :).
    It is just awesome, under the belt, move by EuroNCAP :).
  20. jprates
    jprates https://ecomove.pt
    387
    42
    Moita, Portugal
    2017 Prius PHV
    Not true.
    NCAP test standards for 2009 make mandatory to have ESC alone.
    There is nothing said about pre-crash, automatic cruise control or any other system. Electronic stability control of any kind is the only thing asked for.
    "In particular, it will be impossible for a carmaker to achieve five stars in the tested vehicle without the standard fitment of electronic stability control (ESC) in the majority of variants sold."
