Original shocks and struts and 250,000 miles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ktthomas, Feb 28, 2015.
  1. ktthomas
    ktthomas Junior Member
    Ohio
    I believe the 2005 Prius I just bought with 250,000 miles on it remarkably has the original shocks and struts (and I believe the original brakes too) on it. The ride is not real loose and bouncy feeling however, but the exact opposite. Its tight and I can feel every bump in the road. Feels more like a race car than a luxury car. My question is if there are options when purchasing shocks and struts to make the ride looser or tighter or should I just replace with original OEM ? I'm not much of a performance guy so I don't care for the stiff ride. My wife's Honda Odyssey seems to glide across the rode like its floating on air and that would be the ride I prefer if I had a choice :) Since I don't know what the ride of the Prius felt like when it was new, I have nothing to compare to when replacing with OEM.
    Keith
  2. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    The Prius is known for it's 'choppy' ride, as expressed by some critics. You might want to do a search on this site for some aftermarket shocks, struts that offer a softer ride. I don't think oem is going to help much...
  3. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    The Gen 2 Prius suspension is bargain basement. MacPherson struts up front and a torsion beam in back. So you're just going to have to learn to grin (great fuel economy!) and bear it.
  4. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    You may be able to improve the ride with some quality tires and air pressure adjustment. What tires do you have now? Brand, size, how much tread is left? Are they evenly worn? What is the PSI?
  5. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    if the shocks are oe, inspect them for signs of leakage. most likely 1 or more have the oil coming out if them. or just go ahead and replace them cause they're worn out. the prius is really an econobox, and it rides that way. good tires should help some too. once you get used to it, you will love it.
  6. frodoz737
    frodoz737 Top Wrench
    4,535
    2,438
    33
    Struts/shocks at 250,000 are worn out. You will feel a difference with stock replacements. Doing custom "for feel" is going to be hit and miss.
  7. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    KYB is the Original Equipment maker for Toyota. Most here seem to go KYB when time for replacement.
    A buddy of mine went w/ a complete set of Monroe's, and he's happy. I would say his car seems to ride a little softer then mine w/ KYBs.
    Both KYB and Monroe have "lifetime," warranty on the struts. However, in order to use the "lifetime" warranty, the struts/shocks will need to have completely failed (lack of gas pressure, oil seeping out, or other covered conditions that each manufacture specifies). This means you will have been using the struts way past their design life, using the car w/ less than ideal suspension ride/handling ability. As one mechanic best stated it, lifetime warranty means when the part fails, that is the life of the part. Most people don't make "lifetime" warranty claims b/c they don't have the car anymore, lack documentation, etc. Manufactures know this and count on this; it probably helps that they have a laundry list of exclusions to deny claims of lifetime warranty.
    All strut manufactures stress 5 year/50,000 mile replacement interval to maintain OPTIMUM ride/handling quality. After swapping out my fronts and rears, I'm a believer in the strut manufactures claim. Before I had thought this was their attempt to get people to change the parts out unnecessarily; kinda like some shops still saying 3months/3,000 mile oil change intervals (absurd given vast improvement in oil quality and engines). To convince yourself:
    Read post #48 for fronts. Hints Regarding Replacement of 2G Front Struts | Page 3 | PriusChat
    Read post #3 for rears. Replaced Rear Shocks | PriusChat
    You will likely have other suspension components that need to be replaced beyond the front struts and rear shocks.
    Good luck.
  8. frodoz737
    4,535
    2,438
    33
    I purchased Monroe with lifetime warranty for my Wife's now retired Durango. I just brought them into the original Parts store and exchanged them as needed. Receipt is in the computer and they kept the new boxes for return shipping. Shocks/struts are not lifetime, just like fluids are not.
  9. valde3
    valde3 Senior Member
    2,002
    746
    Finland
    That’s probably reason here we don’t have anything with lifetime warranty. Peoples normally safe their receipts and would probably advertise that car has lifetime warranty parts in it when selling it.
