Original Spark-Plugs are ''stuck',like welded on= What do you do to break them loose?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Apr 30, 2018.
  1. Fredsimm
    Fredsimm Active Member
    188
    117
    Tupelo MS
    Well, did you have any luck removing the plugs?
  2. Kenny94945
    Kenny94945 Active Member
    846
    422
    Sausalito
    2016 Prius v wagon
    OP, did you get the plugs out?
    Summary:
    1- Soak with Liquid Wrench etc for 24 hours.
    2- Run the engine to get any carbon build up weakened from heat.
    3- Have the correct socket/ tools for the job.
    4- Counter clockwise to loosen, clock wise to tighten...confirm/ memorize this
    5- Use high pressure air to blowout any debris in the spark plug area before fully removing the spark plug so debris does not fall through the spark plug hole into the engine.
    6- Do not use an impact gun; only hand tools.
    Installing is another thread. Start by hand/ fingers, plug brand, reach-heat range-gap, wire & boot inspection, anti-seize debate, torque wrench, di-electric grease.
    Or perhaps, penny wise and pound foolish - let a professional shop do the repair.
  3. fotomoto
    fotomoto Senior Member
    5,632
    3,809
    So. Texas
    Yeah, not reporting back after asking for help is..... frustrating (I'll leave it at that). Said OP is back today asking for more advice in another thread about taking a prius (I assume the same car) on a long trip. If answering that question, it would be good to know if the plugs got changed.
  4. ski.dive
    ski.dive Active Member
    963
    242
    Hutchinson Island,FL. Mt. Snow,VT
    NO,I did not want to break the plugs!!
    I'm still driving with the original plugs!!!
    Prius has 98k original miles, runs great!!
    I'll have a mechanic change them when I hit 120k
    fotomoto likes this.
  5. golfmk681
    golfmk681 Active Member
    264
    105
    los angeles, ca
    Yes! I leaned that trick at 18yrs old working on cars and still use it later when I’m tightening specific areas that are sensitive to over tightening
  6. golfmk681
    264
    105
    los angeles, ca
    I’ve read that there’s a debate whether to use anti-seize. I for one am a bit old school and use them on my any install such as the brakes, or spark plugs. When I worked on my spark plugs this weekend, cyclinder three was super difficult to remove.
