Our 2008 Prius Dies in a Fire
Discussion in 'Gen 2 Prius Main Forum' started by Joekc, Jul 3, 2010.
  1. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    I'm surprised that the tires aren't more burned up... maybe that's why the others you looked up looked worse... once the tires catch fire they burn long and smokey. It looks like what burned up more on this one is the rear bumper cover which looks completely consumed. Maybe some ignited matress got up under it before you got stopped. That may then have ignited the rubber gaskets around the back door to get inside the car.
    Not surprised that the tank didn't blow since there's no air in there until it starts to leak and then it'll just burn at the leak not explode.
    I was tempted to say this'll buff right out but I'll leave that for someone else.
    Let us know if there's a weird story in the local press about it.
  2. Joekc
    Joekc Member
    265
    16
    A picture I didn't post shows the rear tires clearly burning, and although they don't look that bad in the posted picture, they disintegrated when the tow driver hauled our car up the ramp. I'm beginning to think the fire went from mattress to tires to interior, but it's still hard for me to imagine enough heat from the mattress to start anything under a car on fire. Maybe there's some lucky kid out there who doesn't have to sleep on this ratty, flammable mattress.
    Since the EXIF data from a camera can act as a stopwatch, I was able to piece together a timeline. From the time the firefighters arrived until the fire appeared to be completely out was an astonishing (to me) eight minutes. The burning tires may have been part of that, since the fire kept flaring up just when it seemed to be out. I think much of the interior damage occurred after the fire squad arrived, but it didn't matter because by then it was going to be a total loss.
    I might post more pictures in my album, but gee it's a chore to resize a 7MB picture down to 97kb. GRR!
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Sorry to hear, and I have no doubt a conventional car would have caught fire in a similar way due to the mattress snagging underneath
    A leaking coolant hose can start a pretty spectacular fire under the hood, especially a semi truck. So can a ruptured power steering hose
    If you had had MANY fire extinguishers on hand, perhaps you could have kept the flames down until the pros arrived. Otherwise a couple of extinguishers will only help occupants escape a burning car
  4. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    Joekc,
    I'm glad to hear that you and the Missus got out unscathed.
    I'd bet that that the fire path to the interior was through the ventilation
    exhaust openings behind rear wheel wells. The rectangular HV battery
    vent exhaust is clearly visible in the third picture in the OP. It is
    normally hidden behind the rear bumper cover.
    There is a similar opening on the driver's side. It just vents the interior.
    I would guess that the burning tires ignited the bumper cover then the
    plastic door on the vent openings. The HV battery exhaust ductwork
    immediately inside the vent is thin plastic and easily ignited. The tire
    fire and burning mattress would be heating up the various bits of
    plastic and carpeting which would out-gassing pre-ignition flammable
    vapors needing only an open flame to ignite.
    Poof!
    At this point, the interior fire would pull fresh air through the exhaust
    vents and possibly the supply vents under the windshield wipers that
    are never really closed all the way, even with air conditioning on
    recirc.
    Once the tail light assemblies began to melt/distort/ignite, there
    would be two additional large openings into the interior.
    As to the gas tank, I would expect that the myriad of plastic pipes that
    make up the fill pipe, etc, were melted/caught fire early on. At that point
    heated gasoline vapors would be freely venting from the gas tank under
    the car and burning violently. I think this would explain the fire ball effect
    in the first picture.
    External heating of the metal body structure would increasing the
    out-gassing from plastic parts inside the car and intensify the burning inside
    the car. If somewhere in this scenario one or more windows broke, that
    would only make the interior fire more intense due increased oxygen supply.
    At sometime it is probable that the spare tire -- small volume but 60 psi --
    probably exploded, and may have b;pwn out the hatch glass. Lots of new
    oxygen...
  5. Optimus
    Optimus Member
    274
    25
    Glad to hear everyone was ok. Agreed with everyone else, the fire likely started by the cat' starting the mattress on fire. Grass fires can easily be started the same way by vehicles pulled over into tall grass (even pickup trucks in a field). As for how the fire got into the cabin and what could possibly burn underneath the car, there are a few things. One, the fire probably spread to the cabin either by what has been mentioned already, or by means of spreading through the various grommet holes in the body under the car. Every Toyota and any other car I have ever seen (though I have not looked underneath a 2008 Prius) has rubber and/or plastic grommets that plug holes in the body/floor pan. These grommets can be for various things, such as drain holes or access holes where a wire harness passed through. Additionally, not all fasteners/threaded holes contain boats (particularly if there are different seat configurations in a vehicle such as bench seat vs. buckets). Rubber/plastic grommets will easily burn through even if made from fire-resistant materials. There are also plenty of things under a car that will ignite, such as plastic channeling/retainers for electrical wiring, brake line retainers, electrical wire sheathing, rubber/plastic bushings, seals, paint, seam sealer (caulk), electrical tape, plastic electrical harness connectors/plugs, and more. Plenty of stuff to burn.... And once it gets hot enough to melt metal, then liquids start burning.
    Again, glad everyone is safe, and also glad you didn't do a "Sikes" and cause additional (false) panic over Toyota and the Prius. We just bought our second Prius this weekend, so we are now a 2-Prius family (and a long-standing Toyota owner) and I also stand by Toyota.
  6. DemonSlayer
    DemonSlayer White Belt
    KC
    Hey Joe it's Chris from Lenexa. After we spoke about my Prius (and your ex...Prius) yesterday I thought I would do a search for your thread and check it out. I can't believe how many people have responded to this thread!
  7. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Awww...that'll buff right out. The FIREWALL between the cockpit & engine compartment is designed to keep the fire from spreading.
    Caddys used to have quite a bit of cockpit shielding. AFAIK the only survivor of an ignition accident was a Las Vegas businessman.
    The moral of the story is to leave enough distance so one can avoid flying debris or stop.
  8. bisco
    52,822
    you are now the proud owner of the crispy critter?:rolleyes:
  9. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Wow! Glad everyone is ok. A mattress huh.. makes sense, the catalytic converter and exhaust pipes runs very hot. I do know however not to park in a grassy field or this same thing could happen. Sorry you lost a good prius, but you will get another one soon. Again Glad everyone is ok.;)
  10. Joekc
    Joekc Member
    265
    16
    Yeah, in an ideal world that's what would happen. In my world when I leave the suggested space someone always cuts in and fills it. And although I was able to slow considerably before I ran over it, stopping in the middle of a 65mph highway would probably have made things worse. At 65 mph you're travelling 95 ft per second and the stopping distance is 345 ft. It was just one of those situations where there were only bad options. :(
  11. Sarge
    Sarge Senior Member
    1,325
    785
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Wow... some pretty dramatic pics and story, glad everyone is ok. Same colour, but different year from mine. :eek: Never really gave it much though how much of a threat a wayward mattress could be!
    ... This reminds me of a guy I saw driving on the Hwy401 in Toronto just yesterday; he was driving an older (~2003?) Sienna with a double or queen mattress strapped down to the roof rack. Now, he did use decent straps with those locking latches (not sure what they were called), but the guy was driving in the fast lane and doing about 60MPH (yeah, I know, we'll discuss driving courtesy at another time). Keep in mind, the 401 through Toronto is the heaviest travelled road in North America, with 8 lanes in each direction... and this was at the beginning of the afternoon rush.
    With each MPH he climbed, the mattress bowed higher and higher acting almost like a parachute, til the middle was about 3, maybe 4 feet in the air at about 60MPH! I was so sure if he went even a bit faster, he was going to rip that flimsy roof rack right off and ignite a trail of destruction as a result.
    Of course, I watched this from my REAR VIEW mirror... I wasn't stickin' around behind him! Though there was a Windstar following him pretty closely - almost tailgating - most of the time. Insane.
    Anyway, I kept my eye on him for a good 10 minutes until he exited, so I guess it was his lucky day...
    Sorry for the slightly OT post, but thought I would share...
  12. Joekc
    Joekc Member
    265
    16
    Thanks for the story. I see the same thing you describe. I think people don't understand the force of wind on a mattress --it's pretty much like a sail. In my area of the world, especially on weekends, you always see overloaded pickups with poorly secured loads. With no view to the rear they have no idea they've dropped anything.
  13. Patrick Wong
    18,210
    6,517
    In my area of the world it is customary to see overloaded pickups which appear to contain all of a family's material possessions loaded within. Those of you who watched TV in the 60s and recall the Beverly Hillbillies and the overloaded truck pictured in the intro clip can relate to the scene - except that these trucks driving around southern AZ usually have Mexican license plates.
  14. dogfriend
    7,512
    1,191
    Carmichael, CA
    I once saw a half-ton Ford pickup traveling on I-80 in West Sacramento with two full size cows riding along in the back. The front tires were barely touching the pavement. :madgrin:
  15. Optimus
    Optimus Member
    274
    25
    Did everyone moooooooooo-ve out of the way???
  16. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    It's also possible the friction of dragging the mattress against the pavement at highway speeds could have been enough to ignite it, either from the fabric directly or the wires getting red hot and/or sparking.
    Once you have something burning under your car, it's going to spread to the car itself.
  17. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    This is just another example of the danger from quiet hybrids. If the Prius made more noise, the mattress could have gotten out of the way.
    Tom
    2 people like this.
  18. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    OMG :eek:
    Are you saying that in addition to being a quad-amputee,
    the mattress was also blind?
    Was the mattress wearing headphones?
    If not, it was probably deaf as well.
    I demand a joint NTSB/NASA investigation.
  19. bredekamp
    bredekamp Member
    569
    Somerset West, South Africa
    :Cry:
    I wish people would secure their loads properly. I've had stuff flying off pickups nearly hit my car too.
  20. Joekc
    Joekc Member
    265
    16
    If anyone is interested I've posted a complete sequence of pictures in my Picasa Web album. Some of the post-fire closeups of the interior are really interesting. Also, I'm in the process of buying a replacement 2008 Prius from a forum member. It's very nice and well taken care of.
    Picasa Web Albums - Joe - Fire
