Our Solar Electric Panels: Done!
Discussion in 'Environmental Discussion' started by hill, Jan 9, 2009.
  1. icarus
    icarus Senior Member
    4,884
    976
    earth
    "If there were no utility or tax incentives, the solar power system payback would be ~33 years, which exceeds my personal planning horizon and consequently I would not make the investment now."
    Unfortunately, the 33 year time horizon is an argument that is often made by solar naysayers. I do understand that it may not make much financial sense, even though it makes great social and environmental sense. It just illustrates how other energy sources are not paying their entire costs. (see also,,, oil spills!)
    As a salve against worrying about 33 year pay backs, one must consider that at a bare minimum energy prices are going to go up over the course of the 33 years. An investment in PV at least insulates one from huge rate increases.
    Thank god, (in spite of what the right wingers would argue) for the subsidies! One other thought for those that are considering Pv, (that we have mentioned on other threads). If you can't justify investing in PV/RE on your own house, consider a coop investment in PV/RE such as green power through your utility. A coop is a way to make ones PV/RE dollar go much farther, if the goal is to create the biggest out put for the buck.
    Icarus
  2. jcgee88
    jcgee88 Member
    181
    23
    Maryland Heights, MO
    Here are some real numbers to go along with this
    argument...
    My April 2010 energy usage was 18% less than my
    April 2009. This reduction was due to a number of
    improvements I made to my home, plus April was a
    mild month weather-wise in Missouri.
    However...my April 2010 utility bill was not 18% less
    than my April 2009; it was only 12% less. This was
    because the kWh rate increased by 8%. The rate
    increase erased a good portion of the cash value
    I hoped to recoup by lowering my energy usage.
    By the way, the rate increase the year before that
    was 11.6%, for a breathtaking total of 22.6% rate
    increase over the last two years!
    P.S....Icarus, good pun, "insulates..." :-D
  3. icarus
    4,884
    976
    earth
    And it will only get worse. The problem is we are (collectively) like the frog in the stew pot. The price rises fast enough, bur not quite fast enough for us to act and change our behavior. When gas was ~$4/ couple of years ago, there was a waiting list for Prius's. Now that it has dropped a bit, we are back to buying big SUVs again!
    I am currently in the UK, and I just bough petrol for 1.31 L/litre, the USD equivalent of ~$8! No one complains! They drive small cars, car pool, and have a robust public transport system. Even on the remote outter Hebrides Island, you can get a public bus nearly any time of the day to nearly everywhere. You can take trains to connect to ferries to connect to busses so you really don't ever NEED a car! When they do, they drive models not available in N. America. Small TDI Diesels that get ~50+ mpg, even the gas VW Golf I hired gets ~40 mpg, and it is a HUGE car by UK standards. Even the big BMWs are Diesel powered.
  4. Patrick Wong
    18,210
    6,517
    There are 6.57 average sun hours/day, according to:
    Solar power insolation for U.S. major cities
    The inverter is SMA 5000US Grid Tied, with online data monitoring.
    SUNNY BOY 5000US / 6000US / 7000US / 8000US.
    According to that datasheet the inverter efficiency is 95.5%. I'm also very interested to see what the actual power output will be.
    Yes, you are right regarding the $3/watt rebate.
    Congratulations on also taking the plunge regarding a home PV system.
    To all of the contributors who have installed PV systems: let's see some photos!
  5. Cacti
    Cacti Poleikleng
    193
    Massachusetts
    Here's a picture of our 5.28 kW PV ground mounted array.
  6. Patrick Wong
    18,210
    6,517
    Thanks. Pls say more about that. Looks like you added 9 panels to the original installation of 16?
  7. Cacti
    Cacti Poleikleng
    193
    Massachusetts
    Had the first 2.88 kW array installed in May 2008 and then followed up with the 2.4 kW array in May 2009. Our last payment to the utility was $2.40 on 06/26/2009. We will be purchasing a BEV (Nissan Leaf) and the 2.4 kW array was based on this.
    Cacti
  8. hill
    9,038
    Patrick, asking PV users for photos is like asking a grampa to show pic's of his 6 month old grandson (and daughter ... & son in law). Ok, you twisted my arm.
  9. hill
    9,038
    The above pic's: 2 sunpower inverters rated 4Kwh each, 36 sunpower panels, rated 225watts (front & rear view) ... and I just got back from visiting the kids in Nashville. You got me curious now. I'm going to go out to the garage & see how the average production is doing, after 1.3yrs.
    EDIT
    15,130Kwh (woah! ... that's a 1.5 megawatt hour!) ÷ 400 days since we powered up ...
    that ≈ 37.8Kwh per day ... so between winter/summer daylight (maybe) 5.8hrs of sun average, which comes out to about 6.6Kwh on an average day - somewhere between long & short days.
    That actual production amount, versus the actual 7.1Kwh rating intrigues me. It results from cloudy days, Panel alignment that's less than ideal, productivity loss on hot days etc.
    Funny how no one considers the "break even point" on a hydro electric dam ... or a nuke facility. The cost of these projects, from planning, to legal battles with environmental groups, to building ... cost over-runs, to decommissioning also takes decades to break even. But 33 years? doesn't that fail to take into account the cost of money? Each year, most utility companies pass on a 5%-10% cost increase for inflation & operational costs. So each year, a PV user's system gains that much savings. Additiionally, your PV system gives you another 15%-30% freebee. You'd pay your electric bill with after tax dollars. So if your system that generates 10,000Kwh per year, that may be $3,000 of power that you didn't have to work to include income tax ... maybe an additional $450-$900 per 10,000Kwh per year system example. That knocks another substantial sum off the total, doesn't it?.
  10. jcgee88
    jcgee88 Member
    181
    23
    I got my figure from this map:
    Solar Insolation Map
    But, the official NREL map here:
    http://www.nrel.gov/gis/images/map_pv_us_annual10km_dec2008.jpg
    does supports your higher figure. Good for you!
    The Enphase inverters I am getting are also 96%
    efficient. But, the entire process of capturing energy
    with solar panels and inverters yields ~80% of the
    theoretical maximum, according to my installer.
    My installer has four customers whose PV power
    generation statistics are publically viewable in realtime,
    these four sites use different brands of inverters and
    solar panels, and in all cases on perfect weather days
    the best they get is about 80% of their nominal DC
    wattage rating. And often, this peak of 80% is only
    achieved for the couple of hours around noon.
    StraightUp Solar Projects | Solar Electric Systems | StraightUp Solar FAQs
    I'll ask my installer for additional detail where this
    loss is actually occurring. I'd bet that at least part
    of it is from the fact that fixed-mount PV arrays
    obviously cannot track the sun for the optimal
    power-generating light angle, in addition to the
    loss coming from DC to AC conversion.
  11. jcgee88
    jcgee88 Member
    181
    23
    Hill, what direction is the photo showing? I was
    surprised that you had arrays on both sides of
    the roof! Normally, one side of the roof is far
    superior to all the other sides.
  12. hill
    9,038
    Of COURSE it would be ideal to have all panels facing south, or slightly south west ... or for that matter, on a tracking array. But you gotta know when enough is enough (financially). Our home is bacon shaped ... skinny & long. We only have so much roof area ... and as you can see, we used the lion's share of it mounting the system. So, one side is more productive in the morning, and the other side (the one with more panels) produces more in the afternoon. I thought about building frames on jacking screws, so the opposing side could tilt up flat ... sort of track a bit more juice. But in reality, the loss is only about 15%. That's acceptable for us ... for now. And, this way, our neighbors won't feel like we've got some kind of Rube Goldberg thing going on.
  13. icarus
    4,884
    976
    earth
    Different facets=two inverters to keep efficiency up.
    An 80% average would be considered great over the course of the day. Between temperature, haze partial shading, etc to get 80% average is pretty good. I think PVwatts uses a ~77% derate for most locations
  14. jcgee88
    jcgee88 Member
    181
    23
    Patrick and Icarus:
    I mis-understood my installer's characterization of
    what the 80% efficiency figure is comprised of. I thought
    the 20% loss was attributable to the DC-to-AC conversion
    by itself. Here is clarification he just sent me:
    >When I referenced 80% that was in relation to total system
    >efficiency - that accounts for each point in the system and
    >their additive losses - for example panel output is typically
    >10% less than their DC rating, inverters are 94 - 96% efficient,
    >line losses are typically 1- 2%, panels are not always
    >perpendicular to the sun's rays, dust on the panels etc... So,
    >in good sun in the middle of the day, at one point in time,
    >we often see approximately 80% output relative to the DC
    >rating -- so a 3 kW (3,000) system may produce
    >approximately 2400 watts at one time.
    Also remember that centralized inverters sync to the lowest
    performing PV panel, thereby creating another form of loss.
    Hill's use of two inverters for two differently facing sets of
    panels is a strategy to avoid this loss. The Enphase de-
    centralized inverters takes that strategy to its exteme.
  15. icarus
    4,884
    976
    earth
    You have it about dialed. For those that are taken unawares, they can get horrible efficiency if they chose a system with different facets and yet only install one inverter. I saw one system that the panels were on 3 roof facets, through a single inverter, and when suggested in the design/build stage his performance was going to suffer big time he scoffed at a couple of world experts. 3 months later, upon completion his performance was ~1/2 of what it should have been. In addition to multiple facets, his array got shadowed by wires, by chimneys, and by plumbing stacks!
    Before one invests in PV, make sure you at least hire an installer who knows the details, and/or educate yourself as to the simple what not to do things!
    Icarus
  16. drees
    drees Senior Member
    1,782
    247
    Actually, that's 15 MWh. :)
  17. jcgee88
    jcgee88 Member
    181
    23
    More fuel for the fire...
    The Missouri Public Service Commission just approved
    another electricity rate increase for my utility. It is
    10%, effective June 3rd.
    That's ~10% rate increase for each of the last
    three years, or an aggregate increase of 35% over
    that time. At that rate of increase, which believe
    me I hope does not continue, the base rate will
    double every seven years.
    When people use payback period to decide whether
    to do PV, they compare the known cost of the installation
    against the expected cost of future consumption. The
    gotcha is that the latter cost is an impossible-to-predict
    moving target.
  18. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    How about a Youtube video - where we see - and you explain - the setup, and the Uber-Cool spinning backwards dial.
    Then geocode your location (in the video).
  19. jcgee88
    jcgee88 Member
    181
    23
    Our solar panel installation completed a couple hours ago,
    and I just experienced the same thing you did: seeing
    my meter spin backwards!
    Tomorrow, I get to see the production during the prime
    hours. Can't wait!
  20. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Please show a picture of your solar panel array installation (or PH/EV refueling station?) if you don't mind.
