Out of juice 2002
Discussion in 'Generation 1 Prius Discussion' started by depriusoto, Oct 13, 2013.
  1. depriusoto
    depriusoto Member
    113
    17
    Albuquerque, NM
    2002 Prius
    My 2002 project car is in need of HV juice. In trying to get the ice to start I ran down the HV to the point where it won't turn over the motor. Working with the Auto Enginuity reader, I found the Delta SOC to be at %20 and my ScanguageII puts it at 16%. So I need to charge up the HV to 60%
    Doing research I found the PriusChat thread to the 2010 outofjuice articleby Paul Cortes of Arts Automotive in Beserkely about the ELCon HV Charger.
    Has anyone ever used one?
    I then came across this right up the road from me in Santa Fe:
    Hybrid High Voltage Charger
    laser propulsion systems and Prius HV chargers, my o my!!
    Ed
  2. bwilson4web
    16,010
    I would probably pull the traction battery and survey the modules. Excessive discharge might have killed a couple. I'm partial to per module balancing and capacity testing but it takes a little time.
