Out of this Solar System
Discussion in 'Environmental Discussion' started by RCO, Oct 28, 2017.
  1. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
  2. fuzzy1
    10,724
    From another source, I believe the orbital parameter 'e' was being curve fit to about 1.19. I.e. hyperbolic orbit, on an escape path, so it is not bound to the sun.
    For those unfamiliar, objects in bound orbits have e < 1. Circles have e = 0, ellipses (ovals) have numbers between 0 and 1. (Earth at 0.017, all other major planets except Mercury less than 0.1) E = 1 is a parabolic path, those with e > 1 are hyperbolic paths.
    Some comets have been thought to be hyperbolic, but they were likely being ejected by a gravitational dance with other bound objects, and e would have only barely been above unity. (Some may be been reclassified to sub-unity, barely bound to the sun, based on later observations.) But this one appears to be moving much too fast for that. Thus it must be a 'visitor'.
    PS. Some discussion:
    Pseudo-MPEC for A/2017 U1
    PS2. Here is what should be the best list of known objects with e > 1, i.e. on escape paths from the sun. #2 on the list, with e = 1.0577, is mentioned in the above link as having been ejected from the Solar System by a close encounter with Jupiter. Prior to that encounter, it had e < 1, just barely. Other bodies either should be in similar situations, or had significant observational uncertainties.
    JPL Small-Body Database Search Engine
    #2 fuzzy1, Oct 28, 2017
    RCO likes this.
  3. fuzzy1
    10,724
  4. bwilson4web
    16,554
    fuzzy1 and RCO like this.
  5. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    You guys should read "Slabworld" and all would become clear....
    .. or not!
  6. bisco
    52,927
    it's probably mork from ork.
  7. Fester
    Fester Active Member
    201
    198
    Ohio
    In the Doomsday department, we don't need any help...
    RCO likes this.
