outside beeper mod
Discussion in 'Gen 2 Prius Accessories & Modifications' started by HAMMER55, Apr 15, 2006.
  1. HAMMER55
    HAMMER55 New Member
    Lufkin, TX
    Has anyone got info on how to make the outside beeper (which sounds just like the inside reverse beeper) sound off when in reverse?
  2. Godiva
    Godiva AmeriKan Citizen
    10,339
  3. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    actually I think there is *some* kind of beeper under the hood as
    part of the SKS warning system, but I don't recall exactly where.
    Presumably if such a thing is there, a mod could send it signal
    from the reverse output -- not that it does a lot of good because
    it's near the FRONT of the car, but whatever..
    _H*
  4. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(Godiva @ Apr 14 2006, 10:05 PM) [snapback]240056[/snapback]</div>
    The link will not download. Says file is damaged and cannot be repaired?
  5. Bill Merchant
    Bill Merchant absit invidia
    4,096
    82
    <div class='quotetop'>QUOTE(seasalsa @ Apr 15 2006, 05:52 AM) [snapback]240121[/snapback]</div>
    The link/document above is damaged, the real PDF is a little over 1 MB to download. You can get the original from the Knowledge Base. It includes instructions on how to turn off the inside beeps and wire in a buzzer that can be heard outside the car. With Pictures!
  6. Godiva
    10,339
    <div class='quotetop'>QUOTE(seasalsa @ Apr 15 2006, 07:52 AM) [snapback]240121[/snapback]</div>
    Thanks for letting me know. I've edited it to link to the PDF in the Knowledge base. That one works. (And thanks Bill for doing that.)
