Over $1000 of repairs needed...legit?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AMC02, Jun 27, 2013.
  1. AMC02
    AMC02 New Member
    Hi Everyone,
    I took my '09 Prius in to the dealer for servicing today because it was making a strange noise...turns out the wheel bearing needs to be replaced (what I was hearing). I just passed the 100,000 mile mark.
    While there, they also informed me that the drive belt is cracked ($121), the engine water pump is leaking ($356), and 2 side lights are out ($51). The wheel bearing (with alignment) will be $506. All together, it adds up to $1074! Hence the reason for my first post on PriusChat. Do these prices seem normal?
    My poor baby. It seems like everything is needing to be replaced at once. Two weeks ago, my hybrid water pump went out...thankfully it was a recalled part! The 12v battery was replaced 2 weeks before that. Ay yi yi.
  2. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    What city are you located? There are good independent repair shops that specialize in Hybrid that can save you money. Not much but some money.
  3. Kurzweil
    Kurzweil Member
    109
    34
    Atlanta
    A drivebelt is a $15 item and any mechanic is qualified to replace it. It's also an easy DIY job. Side lights, even more so. They are so easy that the owner's manual generally shows you how to do it. Those other two jobs, the wheel bearing and the front end alignment are routine automotive repairs. None of this stuff is Prius specific and hence does not really need to be done at top-of-the range parts and labor rates, as provided by your dealer. The forum can advise you, if you give a general idea of your location, or you can ask family and friends for recommendations on locating a good independent mechanic. Once you establish a relationship with one, they often throw in little things like bulb replacement, at least the labor.
    JMD likes this.
  4. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    Is this the same dealer that said you needed to replace the 12v, and at what cost?
  5. AMC02
    AMC02 New Member
    Ok...Thanks for the feedback. I'm in Alabama and will ask around for a recommendation.
    I'm not sure about the battery...I've been overseas doing mission work so my grandfather has been caring for my car. I believe he said the battery was around $350.
  6. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    Dealer cost on the battery is around $150 and normal retail is $199 so they must have charged $150 for installation. (20-30 min. job for experienced tech)
  7. N.J.PRIUS
    N.J.PRIUS Member
    140
    50
    Fort Lee, NJ
    2013 Prius Plug-in
    Always check on dealer website for coupons. Possible 10-15% savings if you decide to let the dealer do the work. Good luck!
  8. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  9. bisco
    52,855
    certainly seems legit for 100,000 miles, question is whether you want to shop around for better labor rates. any competant mechanic can do the work. all the best!(y)
