Over Bob's Car loses communication with...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by douglasjre, Oct 27, 2020.
  1. douglasjre
    douglasjre Senior Member
    2,236
    745
    Null, NL
    ...the key fob but only for a moment. I get an orange triangle and left side of the dash key not detected in the center of the dash and itself resolves period any ideas?
  2. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Did you try changing the key fob battery? It's borderline low my initial guess. I don't know anyone who gets in and straps their key into a fixed position relative to the receiver so slight movement plus weak battery could cause intermittent connection.
    moto g(7) power ?
    orenji likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    I thought that the ignition function was RFID and not dependent on the battery in the FOB.
    Wrong ??
    Does it do this with both FOBs ?
    Might want to check the 12 V battery in the car too.
  4. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    It will still start with a dead key battery, IF you put the key in the correct spot. That's very limited range. "Key not detected" comes when you remove the key from the car like at the valet and I forgot. Many senior moments and I'm 44 wonder what's going to happen as I get older....
    moto g(7) power ?
  5. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Check the mailbox outside without underpants on?
  6. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Who’s Over Bob?
  7. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I'll let you know from the jail cell if they have internet access and let me keep my phone, but not yet.... . But I might also forget to!...
    moto g(7) power ?
    Grit likes this.
  8. douglasjre
    2,236
    745
    Null, NL
    Sry for voice dictation typos. I even tried a new fob...
  9. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    So title should be "New Fob...
    Please elaborate on what steps you took so we don't blindly recommend steps you've already taken...
    moto g(7) power ?
