Overfilling oil: Just let it be, or take it back?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Preeeus, Feb 7, 2018.
  1. Preeeus
    Preeeus Member
    258
    60
    Just read all(?) the threads on overfilling oil. So confusing.
    We brought our Prius into a mom and pop shop to have the oil changed. We told the owner (who is also the tech) that we are burning about 1qt of oil per 1000 miles, so make sure to fill it to the top dot on the dipstick.
    We got home, let the Prius sit for a day, and then checked the dipstick. It's over the top dot by about half the distance from the bottom dot to the end of the dipstick.
    Given that we should burn off that excess oil within a month, is it necessary to drive back to the shop and have them drain the excess?
    We love our Prius and don't want to jeopardize the engine, but also don't want to waste half a day going back to the shop if it's not necessary.
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Yes take it back. You paid for service and should get the proper service. Wait too long and they'll think you're trying to pull a quick one of them. Engine will have to work harder to move the excess oil that you provided info on and cause it stress. I'm old school and want the best bang for my buck :whistle:
    NutzAboutBolts likes this.
  3. JC91006
    16,939
    8,647
    I don't think that little overfill will affect anything. Just let it burn off. When bisco had his gen2, this was a regular occurrence with him, no harm, no foul
  4. Mendel Leisk
    42,383
    The place maybe had a hard time reading the dipstick? Best ploy is to just refill with the specd 4.5 US quarts (with filter change).
    For best read, remove dipstick and wait a good 5 minutes before checking.
    Raytheeagle likes this.
  5. bisco
    52,915
    if you're never going to change it yourself, get a cheapo vacuum. takes ten minutes to suck out the excess through the dipstick.
  6. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Overfill stresses the gaskets and seals, which leads to oil leaks. Your call...
    Grit and Raytheeagle like this.
  7. Mendel Leisk
    42,383
    I'd guess they put in 5 quarts?
  8. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    That's what they did when I gave them a 5 qt jug. :rolleyes:
    Now I give them 4 qts and tell them I'll top it up myself.
  9. exstudent
    exstudent Senior Member
    2,214
    906
    Torrance, CA
    I guess I am the only one who remembers horror stories vividly. Reread this members experience w/ an overfill; granted its a Gen2 engine, but your Gen3 is designed to operate w/ oil between the two marks.
    Another Walmart oil overfill, Toyota is hinting at new ICE | PriusChat
    What's confusing? The oil is to be kept between the two marks for optimal operation; ideally keep the oil level at the top mark.
    If oil is below the bottom mark of the dipstick, early engine death.
    If oil is above the top mark of the dipstick, bad stuff might happen like the poor guy above.
    Think lug nut. It has a specified torque value.
    You under tighten it, the nut will likely work itself loose, BAD.
    You over tighten it, the stud may break off b/c it is being overstressed, BAD.​
    Just tighten the lug nut to the specified torque value and all will be well.
    KEEP your oil level between the two marks, and all will remain well.
  10. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    The problem with dipsticks is they can't measure the oil that isn't in the pan. When you put fresh (and cool) oil into an engine that may also be a bit cool, a lot of it is going to stick to the metal in the upper parts of the engine. This could be an extra half quart or more that isn't in the pan. So when you check after an oil change the dipstick reads full. Go on a long drive to get everything warmed up, then leave it parked overnight, and check the oil and it will be above full.
    There will also be variations in readings if you're not parked on a flat surface.
    With all this uncertainty, I would think a well designed car should be able to handle up to a quart of overfill without a serious problem.
    On some of the new F-150s, you're not supposed to check the oil until after the truck has been sitting for 15 minutes. One guy did his own oil change and had 10 quarts come out of his 6 quart capacity engine and wrote about it here: Easy DIY Oil Change Holds a Minefield of Potential Screw-Ups - 2015 Ford F-150 Long-Term Road Test Note that a new engine was not required even though it had 166% of the specified amount of oil.
    Preeeus likes this.
  11. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    How? It doesn't increase oil pressure. That is set by a spring in the oil pump. If you overfill enough you can end up with "hydraulic lock". This requires you to almost fully fill the engine with oil. The engine will not turn over. Since he drove it home we know it's just fine running with a little extra oil. The only possible downside is if there is enough extra oil it can increase drag in the engine and the "splashing" of the extra oil can cause it to seep past vents etc a little more than usual. The amount reported doesn't sound like that will happen.
    I would leave it. He actually got better value (extra oil for no extra cost). ;)
    Preeeus likes this.
  12. padroo
    padroo Senior Member
    2,763
    2,253
    GrGramps, Tande and tpenny67 like this.
  13. Mendel Leisk
    42,383
    Yeah I've found the level reading low, just after a fill. Being near-clear, and the smearing dipstick: doesn't help. Again, just drain well, put in the spec'd amount, check it more carefully a day or two later, first thing in the morning.
    I think OP's instruction to the the "mom and pop" garage to get the oil on the top mark, coupled with the above vagaries, caused the overfill.
    tpenny67 likes this.
  14. bisco
    52,915
    when my local guy overfills, he swears he puts in the spec. why would i put in more? it just costs me money.
    but what he doesn't do is put in less, and check the dipstick.
    most mechanics believe a little extra doesn't hurt anything, even though most manuals repeatedly warn against it.
    Preeeus and Mendel Leisk like this.
  15. tpenny67
    464
    403
    Massachusetts, USA
    I've heard this too, and it happens when the oil level reaches the crankshaft. However, it's not really an all or nothing thing, as you're driving up and down hills, going around corners, and hitting bumps, and all that is going to make the oil slosh all around. So the higher the oil level the more likely and more frequently the crank will hit the oil up until the point where the level is so high the crank is sitting in the oil with the engine off.
    Of course, there's things you can do in the design of the engine to prevent this, such as baffles in the oil pan to limit the oil from sloshing around, or a windage tray under the crankshaft to limit oil splashing onto the crank (I was shocked to find out that our old Taurus had one of these, it also probably helps with aerodynamics inside the engine).
    padroo and Mendel Leisk like this.
  16. padroo
    2,763
    2,253
    I'm sure a lot of people that have their oil changed never catch the overfill because that's the oil changes job right? (sarcasm)
  17. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Get yourself a Mityvac and you can easily solve problems like this yourself in about 5 minutes.
    Raytheeagle and padroo like this.
  18. cipsaz187
    cipsaz187 Member
    150
    43
    I usually overfill my Gen3 by about 1/4. Its tough to get it right. I put 4.4qt and it measures correctly. But then I drive around and on the next day it shows about 1/4 above.
    I always get it right on the Gen2.
  19. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    I have a difficult time reading the level, so with the 5 qt. jug I pour out the amount needed to get to the 4.x qts as noted in the manual. I wait a long time during draining, lower the car so it is flat on the floor, to make sure I get as much as possible out, and fill as prescribed. I don't waste time trying to read what I can't.
    If you can read the level, and it would take a long time to bring the car back, I'd take it upon myself to drain about 0.5 qt out and measure the level again...
  20. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    The Prius dipstick. Hard to read. Hard to see the oil. Never had a problem with any other car. Is it because the oil is so thin? I check the oil twice a month, in the morning, after the car has been sitting all night.
    So Mendel, the secret is to pull out the stick, wait 5 minutes, then reinsert and check? I never see a distinct level on my dipstick... I just see kind of a blotchy smear. And I can't tell if it's overfilled, low, or what.
    #20 Starship16, Jul 8, 2018
