Overfilling the gas tank
Discussion in 'Gen 2 Prius Technical Discussion' started by Eddie Brown, Mar 15, 2013.
  1. Eddie Brown
    Eddie Brown Junior Member
    26
    Chicago
    I was at the gas station returning from a road trip and the pump didn't shut off.
    The result was a overfilled gas tank with 8.3 gallons and 2 pips left.
    My question is, can this damage anything?
    The first pip didn't go away until 160 miles which never happens for me.
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    While it has happened that people have gotten the fume absorbing canister soaked by overfilling, and setting a warning light on the dash, it doesn't always happen. With the Prius bladder tank, filling is always a little bit of an adventure. Search for "bladder" on this site for lots of discussion about it.
  3. uart
    uart Senior Member
    4,220
    1,212
    Australia
    That's happened to me too Eddie. It's not ideal, but as long as you don't make a habit of it then it doesn't seem to hurt anything. :)
  4. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    There is a filter toward the top of the filler neck. If you overfill too many times, this will clog and need to be replaced. It will cost over $200.00 at the dealer. Best to avoid that. I am not saying that YOU did this intentionally, but, people who force more gas in after the first click damage that filter.
  5. boppo
    boppo Active Member
    799
    139
    Owego, NY
    I all ways top mine off so you can't put another drop in and never had a problem. One time I ran it down to fume and it took 11.8 gallons. I guess I have been just lucky.
  6. Malcolm338
    Malcolm338 Junior Member
    27
    Carlisle uk
    I do the same and never had a problem
  7. LDPosse
    LDPosse Member
    35
    27
    Hershey, PA
    Knock on wood.... I am kind of OCD about making sure my tank is filled to the brim, regardless of warnings not to... No problems yet, luckily, and I've gone over 200 miles before dropping the first PiP. Biggest fill up I ever had was 12.76 gallons. Not sure how it all fit in there!
  8. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    I sometimes do the top off. It also seem no issue for me. Touch wood.
  9. boppo
    boppo Active Member
    799
    139
    Owego, NY
    Wow, I can do 11.8 but never ever went over 12 on a 11.9 gal tank.
  10. boppo
    boppo Active Member
    799
    139
    Owego, NY
    LDposse, maybe someone took your bladder.
  11. LDPosse
    LDPosse Member
    35
    27
    Hershey, PA
    LOL. I have wondered how so much fuel fits in the tank. The first time it went over 12 gallons, I was thinking the gas pump wasn't accurate, but I've put over 12 gallons in at enough different stations to rule that out. The Prius isn't the only car I've gotten to hold more gas than it's advertised to hold. My '71 Buick Skylark has a 20 gallon tank and I've fit almost 20.5 in it, and the '01 Chevy 2500HD pickup I just sold is rated at 34, and I've fit 34.1 in that. I guess maybe the manufacturers don't count the filler tube, or they have an allowance for a minimal amount of airspace in the tank.
