Overheat and coolant loss from reservoir, how to tell if water pump or head gasket
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by QuinnVee, Jul 7, 2025.
  1. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,693
    1,739
    Bay Area
    :ROFLMAO::ROFLMAO::ROFLMAO: Well, when that time comes, I’ll deal with it. I’m always up for a challenge (y)
    Also, the Aisin wp on Amazon, they scratched the word “Toyota” off, so you know it’s a genuine part.
  2. ASRDogman
    ASRDogman Senior Member
    7,571
    3,905
    Well, the case might be... Unless there is some other marking they use that doesn't get
    ground off.
    But that doesn't mean the insides are the same.... Is there anything inside that indicates it is
    the same as the ones they send to Toyota?
    There has to be something, right?
  3. NutzAboutBolts
    1,693
    1,739
    Bay Area
    Part numbers match up, brand name match up, parts match up. The company sells parts to Toyota and consumers, they keep the Toyota name on the part if they’re selling it to Toyota and if they’re selling it to consumers, they will grind the Toyota logo off of the parts. I’ve bought aisin parts before and that’s how it’s been.
    you can test the parts if the internal is working like oem on techstream if you want to test it out.
    frodoz737 and ASRDogman like this.
  4. Andy Pants
    Andy Pants Member
    36
    28
    WIsconsin
    I got mine off amazon as well, and it was identical in every way to the one I took off. As long as you get an Aisin brand with the ground off Toyota stamp like he says here you'll be good to go. If you want the extra peace of mind and don't want to potentially monkey around with returning to amazon (if it gets delivered and looks fishy to you) then pay the extra $$ at the dealer.
    NutzAboutBolts likes this.
  5. CR94
    CR94 Senior Member
    2,692
    1,173
    Northwestern S.C.
    What prevents a counterfeiter from grinding a corresponding spot to make it look like an Aisin to fool you?
    ASRDogman likes this.
  6. NutzAboutBolts
    1,693
    1,739
    Bay Area
    if it’s from Aisin, they’d have their logo on there…
    If there’s no label that indicate it’s from Aisin, I wouldn’t buy it.
    frodoz737 likes this.
