Overheated Prius Motor, Have some questions.
Discussion in 'Gen 3 Prius Technical Discussion' started by michaud85, Jan 19, 2020.
  1. Mendel Leisk
    42,372
    I used a scangauge II, it's one of the basic built-in gauges (you can also program in more esoteric ones). It was great for filling the info gaps, but after about 3~4 years constantly connected to the OBD port, I started getting Check Hybrid System warnings and return-to-basics brakes. Dealership ultimately suspected the Sangauge, and I think they're right: when I disconnected issues went away.
    Cosmo Tigato likes this.
  2. Cosmo Tigato
    Cosmo Tigato Active Member
    201
    363
    Oregon, USA
    Started it up in the morning
    The engine first shut off at 103
    Then when I got to work, I parked and it showed 159 right before I pressed the power off
    Sweet, the scangauge II is great.
    Robert Holt likes this.
  3. Cosmo Tigato
    201
    363
    Oregon, USA
    I think maybe I will only use it on long trips ;)
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    159F. How far is work drive? Catch can is a must if that was your peak temp.
  5. Cosmo Tigato
    201
    363
    Oregon, USA
    3 miles
    Installing the OCC today or tomorrow after work
    What should the Peak temp get to?
  6. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    Thermostat in the Gen 3 is 195F. Car will eventually run at that doing highway speeds and will hit 200 climbing grades then come right back down.
    Robert Holt and Cosmo Tigato like this.
  7. Cosmo Tigato
    201
    363
    Oregon, USA
    Great,
    This will be fun to monitor on the ScanGaugeII, while I drive around
    Thanks
  8. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    "This will be fun to monitor on the ScanGaugeII, while I drive around"
    Among many other parameters, you can also monitor the coolant temp of the inverter/converter.
  9. Vman455
    Vman455 Senior Member
    540
    556
    The Middle
    I've had mine continuously connected from 32 miles--when I bought the car new--to 82,000 miles six years later.
  10. Cosmo Tigato
    201
    363
    Oregon, USA
    That is good to know,
    Thanks
  11. Robert Holt
    Robert Holt Senior Member
    1,313
    890
    I first had the chips in our old Scangauge II updated, then programmed in some Prius-specific codes and have been using it continuously since 2013 and currently have 95,000 miles on it. Personally, I would avoid repeatedly plugging and unplugging the Scangauge into the OBDII connector socket, as that repeated action may damage the connecting socket.
    I routinely monitor coolant temp and can confirm the 103-degree F engine cutoff and the stabilizing at 195-200 degrees. I have a lower inlet airblock with movable doors, and with those doors closed and climbing mountains in warm weather, I briefly got over 200 degrees and thereupon pulled over to open the doors, which solved the overheating problem.
    But be advised that if you have a really old Scangauge you may have to get updated processing chips installed inside so that the Scangauge can be successfully programmed with the full set of Prius-specific codes.
  12. fuzzy1
    10,722
    This is another good reminder that most humans are generally not as good at multitasking and interrupt handling as they think they are.
    I have an advantage here in knowing that my such skills are below average. So I can get feisty in pushing back when others insist that I perform at the level they believe (often wrongly) that they can do themselves. This pushback has significantly reduced my rate of errors and eff-ups.
    michaud85 and ASRDogman like this.
  13. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    I wouldn't consider 200 overheating at all. A 5 degree temp swing is a pittance and most cars run well above their thermostat setting, especially in summer. My truck will run in the 220 range hauling up a hill and a Camry I had floated between 190 and 205.
    212 is boiling for water but the engine coolant loop is also under pressure so true BP is higher. 200 is nothing for an engine, even in the Prius.
    103F is the first temp target for engine shut off if not calling for heat. 154F is when the car considers itself at minimum operating temp to allow you access to all it's modes.
    For those not familiar with them, the stages of warmup are described here. Gen3 warming up stages | PriusChat
    #33 Mdv55, Jan 23, 2020
  14. davecook89t
    davecook89t Senior Member
    1,093
    832
    Washington State, Florida
  15. michaud85
    michaud85 Member
    75
    51
    Maine
    2018 Prius
    Alright I just bought a 2016 motor on eBay from LKQ with 43k miles on it. They even gave me the VIN and I saw some pictures of the totaled car. Looks like the engine shouldnt have been affected from the accident it was in . I will make a separate swap thread to share anything new I learn along the way.
  16. fuzzy1
    10,722
    Even absent extra pressure, the common antifreeze coolant mixtures push the boiling point a dozen-ish degrees (F) higher than the boiling point of pure water.
  17. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    Yes, a coolant mixture of 50% water and 50% ethylene glycol has a boiling point of 223 degrees at atmospheric pressure.
    References for how this increases with pressure vary, showing as high as 3*F/psi. Truth is probably below that.
    At one atmosphere of gauge pressure with 50/50 mix, you can probably count on a boiling point north of 250*F.
    fuzzy1 and Ragingfit like this.
  18. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I would recommend an obd2 extender cable, and never worry about damaging the car’s obd2 port
  19. Cosmo Tigato
    201
    363
    Oregon, USA
    It's actually Super easy to do a engine swap on the gen 3
    Check out this thread.
    Just Bought a 2012 For $700 with a Blown Head Gasket | Page 2 | PriusChat
    And this Video On YouTube
    #39 Cosmo Tigato, Jan 25, 2020
  20. michaud85
    michaud85 Member
    75
    51
    Maine
    2018 Prius
    You guys have been enormously helpful so far .I have only been through the first 4 or 5 videos and i do plan on watching them all and combing through the posts. I was wondering though if anyone can tell me a list of what exactly needs to be done differently when swapping 4th gen into 3rd.
    I know you need to:
    swap fly wheels
    reroute one of the large coolant lines
    modify egr tube
    I havent seen exactly how to do any of those things but im just trying to track down the big time modifications so i can make sure i know what to do and be prepared as the engine arrived today!
    edit: i just inspected the motor and it seems to be in good shape. oil looks good and theres no damage, hoping i dont need the wiring harness in tact because it appears to have been sawzalled in a few places lol. theres 2 motor mounts present the back one and the side opposite the trans. Thankfully the flywheel and damper are present as well.
    #40 michaud85, Jan 29, 2020
